Noob Question - profiling i1 display pro against and i1 pro - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By airscapes
  • 1 Post By LarryInRI
post #1 of 7 Old 07-18-2012, 04:11 AM - Thread Starter
ndaa75's Avatar
HI all,
bit of a noob question here - i already have an i1 display pro which i want to profile off my brand new i1pro - question is how do i do this???
Cheers for any help.
Benq W1080ST Projector, Panasonic TXP55VT30 plasma, Yamaha RXA3020 AVR, Denon DVD-2500BT, Q Acoustics 1010i in 7.1, i1 Pro spectro, i1 Display Pro, Calman 5 Enthusiast, PS3, Xbox 360, Wii
Calibration Management Disc
ndaa75 is offline
post #2 of 7 Old 07-18-2012, 05:04 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
It depends on the software you are using.
What are you using, you will get more detailed help if we know.
ndaa75 likes this.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 7 Old 07-18-2012, 06:18 AM - Thread Starter
ndaa75's Avatar
OK, cheers for that - using HCFR and Calman 4.
ndaa75 is offline
post #4 of 7 Old 07-18-2012, 08:40 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Did a quick search ..
http://www.avsforum.com/t/1274056/profiling-how-to/0_60
Doug
post #5 of 7 Old 07-18-2012, 09:00 AM - Thread Starter
ndaa75's Avatar
Cheers - i did google but couldnt find the answer - thanks very much!
ndaa75 is offline
post #6 of 7 Old 07-18-2012, 09:38 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
With calman there is info on the spectracal site, you can call tech support or email them as well. Thing that is no obvious is you have to turn on pattern prompt (before you tell calman it to do the profile ) so it will let you change the pattern. Have your disk ready to provide Red Green Blue and White at 75% luminance. If you have specific questions after reading the posts and help files please ask.
As to searching, at the top of each forum main page is a "Search Forum" link, choose that to search the forum rather than use Google.
Doug
post #7 of 7 Old 07-18-2012, 03:51 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 186
For HCFR, profiling a colorimeter to the i1 Pro is a simple matter. I'll use the i1 D2(LT) as an example. The object is to create a correction color matrix which is to be used with the LT. It's explained, not too clearly, in the HCFR Help Menu/Advanced/XYZ Adjustment/Compute section.
1. Set up the calibration DVD to display the primary (red, green, blue) colors and white windows sequentially. The AVSHD disk has a submenu choice just for this.
2. Put both the LT and the Pro on the TV panel so the meter sensor holes are vertically in the center of the window and right next to one another.
3. Set up HCFR for the Pro meter and do a normal sensor black level calibration (Measures/Sensor/Calibrate...)
4. Run the primary colors and the white windows reading the data with HCFR set up for the Pro meter. Save the run as something like "pro meter calibration.chc"
5. Set up HCFR for the LT meter and do a normal sensor black level calibration (Measures/Sensor/Calibrate...)
6. Run the primary colors and the white windows reading the data with HCFR set up for the LT meter. Save the run as something like "LT meter calibration.chc"
7. Display the Pro results on your computer and check the "Reference measure" box in the upper right hand corner.
8. Display the LT results and click Advanced/XYZ coordinates adjustment matrix/Compute conversion matrix from reference document.
9. You will be asked if you want to apply a correction to your LT readings, Click yes.
10. Click Advanced/XYZ coordinates adjustment matrix/Manually edit XYZ conversion matrix...
11. A conversion matrix will be shown. Save it with a name like "LT calibration matrix 07-19-2012"
Now when you use HCFR, make sure that the correction matrix is loaded. If not, load it using the same steps as in item 10.
Larry
Stereodude likes this.
LarryInRI is offline
Reply Display Calibration
