New Apartment Screwed up My LCDs Custom Calibrations! WHY?!! PLEASE HELP!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-20-2012, 06:19 PM - Thread Starter
5hifty's Avatar
So, I just recently moved into a new place, and I just set up my Sharp LCD in my room. When I went to turn it on? It looked great! Though, when I started playing games, and watching Netflix/ movies (I use my Xbox360 for everything)? I started to notice the contrast and brightness were way out of wack!
The contrast was over saturating the whites, and my blacks were so hard/ dense... Thinking, at first, "Oh, my settings must have gotten messed up from unplugging the TV from my old place, and reset to default." I check to see if that was the case? It wasn't!
I'm so confused by this because I calibrated my TV like an art at my previous place. everything looked great at the setting they were at, and now they look like garbage! Not only do I have to drop my contrast ratio, but I also have to raise my brightness up to over the 50% marker! Everything's washed out now! Though, using the calibration tools I have from this site, this is the correct setting its supposed to be at now?! Am I missing something?? I'm at a huge loss here as to why my TV's calibrations are all out of wack!
Is it the voltage coming out of the wall? Did the Xbox360 recently update the Source material for color coding to something outrages now? I'm kind of bummed...
If anyone has an answer, or can at least speculate whats happened? Id love the input!
Thanks you.
Posting my before/ after Custom calibrations and my Sharp LCD model number below:
Sharp Aquos LC-42D64U
Before Custom Calibrations (old house)-
Mode: Dynamic
Backlight: +0
Contrast: 32
Brightness: -1
Color: +0
Tint: -11
Sharpness: -4
Color Temp: Low
Active Contrast: Off
Fine Motion: Off
Film Mode: Off
*NEW* Custom Calibrations (new house)
Mode: Dynamic
Backlight: +0
Contrast: +26
Brightness: +11
Color: +2
Tint: -11
Sharpness: -4
Color Temp: Low
Fine Motion: Off
Film Mode: Off
5hifty is offline
post #2 of 8 Old 07-21-2012, 12:23 AM
gregzoll's Avatar
Liked: 33
Unless you actually used proper calibration equipment, your tv was only visually changed to your liking in the prev. residence. So looks like you have to go back through your settings and make the basics fit the new place. Has nothing to do with voltage, all it has to do, is with the changes in the menu. In order to do a proper calibration, you have to get into the Service menu to make those changes.
gregzoll is offline
post #3 of 8 Old 07-21-2012, 01:35 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
It really looks like your video levels changed from video to PC.
I'd suspect a setting in your xbox changed.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #4 of 8 Old 07-21-2012, 09:40 AM
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 562
+1; sounds like the most likely explanation, given that the issue is white level and black level related
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #5 of 8 Old 07-21-2012, 10:29 AM - Thread Starter
5hifty's Avatar
Lol, yes I'm aware I need to change the settings in the menu. If you read my post it states i did that for the new place. Dur.
See, Thats what i thought too! The xbox settings r all calibrated to there default settings. I dont understand why it has made the black levels so washed out
5hifty is offline
post #6 of 8 Old 07-21-2012, 10:33 AM
Liked: 562
is there a black level setting on the TV as well?
in any case, I'd toggle back and forth between video and PC levels on both devices to see if it reverts back to its correct state (sometimes these controls can be a bit buggy)
post #7 of 8 Old 07-21-2012, 11:45 AM - Thread Starter
5hifty's Avatar
No, theres just the gimmick "Dynamic Contrast" setting and "film mode". There's no black level like they have on the samsung LCDs.
5hifty is offline
post #8 of 8 Old 07-25-2012, 05:00 AM
Quoted: 1394 Post(s)
Liked: 588
Check your HDMI color space in the XBox.
Sounds like it thinks you're hooked up to a PC rather than a TV. Might want to try RGB.
JimP is online now
Reply Display Calibration
