HTPC + projector. Which one do I calibrate? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-24-2012, 07:00 AM - Thread Starter
EazyM3's Avatar
My htpc is using media player classic home cinema with ffdshow to watch all my media content. Do I need to calibrate my video card and projector's settings or just one of them?Does it matter which one I do first? I believe ffdshow does all the rendering so do I ensure to turn it off on the video card?
EazyM3 is offline
post #2 of 2 Old 07-24-2012, 09:54 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
Both, but do the projector first.
You will need software to calibrate the video card, if you don't have something that can tweak the video card lut, then don't adjust the HTPC at all. The controls in the video driver do more harm than good.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
Reply Display Calibration
