Monitor calibration 101 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-03-2012, 12:37 PM - Thread Starter
jrehage's Avatar
I have successfully got mu i1Pro spectrophotometer to read data using the HCFR colorimeter software...WooHoo
The problem I have now is what do I do with all this data and I'm confused on when I should actually start adjusting my monitor setting or do I create a profile and use it. I apologize but I am really new to this. I purchased an i1Pro at an extremely great price and just now trying to learn the whole calibration process.
I can use the i1Pro to gather data but how is that actually used to calibrate my monitor and other devices?
Any help will be greatly appreciated....Joe
jrehage is offline
post #2 of 4 Old 08-03-2012, 12:48 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 333
You can use some of the RGB data to tune your displays cuts and gains.
If you really want to calibrate a monitor complete with your video card LUT and an ICC profile for ICC aware apps, you'll need better sofware, HCFR wasn't designed to calibrate PCs.
There are a number of these X-Rite makes a pretty good app, there is also BasICC Color and ColorEyes. I worked on the team that made CalPC at SpectraCal so I'm sort of partial to that one.
If you like the command line you could also use argyllCMS.
sotti is offline
post #3 of 4 Old 08-04-2012, 12:14 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 352
If you just want to learn about Calibration, generically, go to the Calibration for Dummies thread. It covers the topic fairly well.
If you want specific help with the software you are using, there's probbly already a discussion thread for that software, just seach for it.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #4 of 4 Old 08-04-2012, 12:41 PM
Smackrabbit's Avatar
Quoted: 119 Post(s)
Liked: 296
You can also download DispCalGUI for free, which uses the ArgyllCMS libraries, and see how that works for you. I've had good experiences with it so far myself.
Chris Heinonen
Staff Writer, The Wirecutter, a NY Times Company
Founder/Editor, ReferenceHomeTheater.com
ISF Level II Certified Calibrator
Previously: Secrets of Home Theater and High Fidelity, AnandTech.com, HDGuru.com and Electronic House
Smackrabbit is offline
Reply Display Calibration
