CalMan 5 Release Notes and Discussion - Page 100 - AVS Forum | Home Theater Discussions And Reviews
 412Likes
post #2971 of 3932 Old 10-17-2015, 11:13 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 333
it's just a driver that's packaged with many of our bundles.
You can uninstall it afterwards if you don't use the meter. It takes up like 1MB of disc space and literally does nothing if you don't have a C3.
sotti is offline
post #2972 of 3932 Old 10-18-2015, 09:21 AM
W3Rman's Avatar
Quoted: 158 Post(s)
Liked: 131
Ok, i have always just installed it but this time I was too curious to let it go .
I thought maybe there were other components like for the simulated hardware wrapped up with this.
W3Rman is offline
post #2973 of 3932 Old 10-21-2015, 06:50 AM
eganz1's Avatar
Quoted: 79 Post(s)
Liked: 65
I'm now getting some success with my 3-D LUT.
I'm using the latest version of Calman 5.6 which includes corrections for Plasma drift, Amazon fire TV stick with MobileForge as a source, and I1D3 sensor.
First of all, would like to thank Ted and many of the members on this forum for their invaluable assistance.
I completed a run with 1800 color patches in 80 minutes. Colors are much improved, I will post snapshots soon.
Thanks all,
Eric
ConnecTEDDD likes this.
eganz1 is offline
post #2974 of 3932 Old 10-21-2015, 08:34 AM
p5browne's Avatar
Quoted: 3059 Post(s)
Liked: 2381
Have also gone back to using AutoCal for 21 Point and 125 3D LUT. Much improved! MOST Natural looking PQ, EVER!
Just reach out, and touch some one - it's that real looking!
Just wish that there was more selection for Sample rate for the i1Pro 2 - 1 sample is not enough when the Samsung UN65HU9000 takes several samples before it settles down after every change. I was able to set the C6 to 10 samples which covered the 4 to 7 samples before settling. The i1Display Pro, has no sample selection, only a setting of max of 2 seconds. Again, not enough for set to settle.
Since my C6 is currently out of commission, I now have only the other 2 choices.
UN65HU9000 with SEK-3500U - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 up for sale
p5browne is online now
post #2975 of 3932 Old 10-21-2015, 10:14 AM
ConnecTEDDD's Avatar
Quoted: 1559 Post(s)
Liked: 1999
Thanks all,
Eric
You are welcome Eric, glad to hear that you had good results
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #2976 of 3932 Old 10-21-2015, 01:49 PM
eganz1's Avatar
Quoted: 79 Post(s)
Liked: 65
3-d lut
So, this is my current result with 1800 color panels.
I'm using a gamma of 2.2, which is close to the original gamma.
I'm doing better, but still could improve substantially.
Before I start doing longer runs with more color panels, I thought I would check to see if I can improve my technique and or settings.
When I First started, I was having a lot of trouble with posterising at very dark levels. I was able to mostly eliminate this by increasing the low-level sample time to 2 seconds (up to 10 cd), and setting the black level to 0.
currently the color response and accuracy is good, and much better than before the calibration. skin tones are improved. However, my grayscales are not all gray, and have some small banding visible in test patterns. I also see occasional banding in light blue sky
I have been using user-defined ABL patterns to compensate for the plasma's unusual response. I've been setting them to roughly 18, 18 for size and average intensity.
at one point, I tried to do a 1D LUT first, and although this improved the grayscale and Gamma tracking, it caused an overall reduction of intensity of roughly 10%. Also, it seemed that this one the LUT was acting across all six storage areas in the box.
so, I have various questions:
Is it correct to set the black level to 0, or should I use the measured black level (0.017 with ABL patterns)? There is also a checkbox to use the 0 black level with the auto measure. How should this be set?
Is there a way to use the 1-D LUT without losing so much intensity?
Is there another way to improve my grayscale performance and reduce banding?
I assume that I need to recalibrate my TV inside Calman using the current set up, but the last time I tried this things got worse.
Eric
Theater: Sony A1E OLED 4K Ultra HD, Oppo-205, Anthem AVM60, B & W CM 7 LR,CDM-cse, CM 1, Silverline minuet , SVS SB13 Ultra, Rotel RMB 1555, Parasound A23, Naim NAP 100, EEcolor lut box. Calman, MobileForge, I1D3 & I1pro 2
Stereo: Aurender N100H, Auralic Vega DAC, Focal Chorus 836 W, BAT VK-3ix, Pass XA 30.5, PPP.
eganz1 is offline
post #2977 of 3932 Old 10-22-2015, 07:37 AM
eganz1's Avatar
Quoted: 79 Post(s)
Liked: 65
I spoke to Tech support at SpectraCal, they were very helpful.
They suggested using 6% size and 20% intensity ABL patterns, and considering a gamma of 2.4
They suggested putting the meter close to or touching the screen and potentially using black fabric covering over the front of the TV during the day.
They said to not check the auto calibration from zero black check box, the zero black setting is used only for the BT.1886 Gamma.
For plasma, they recommend a one second pattern delay.
They recommend five second low light time, for values below 1 cdm.
Once I have everything working smoothly, they recommend at least 3000 color panels or more in order to get accurate and smooth results.
Can run overnight, or during the day.
They agree that using the 1-D lookup table can reduce intensity.
They suggested that I calibrate the display using Calman accurately before running the lookup table.
Last night I thought about this and it looks like one can add more gray levels into the color panel selection in the advanced menus. [ edit: but this is not correct]
E
eganz1 is offline
post #2978 of 3932 Old 10-22-2015, 07:46 AM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1064
zoyd is offline
post #2979 of 3932 Old 10-22-2015, 08:40 AM
eganz1's Avatar
Quoted: 79 Post(s)
Liked: 65
Originally Posted by zoyd View Post
I've seen banding in plasmas when the iRP option 16-235 is used so use 16-255.
Zoyd,
I'm not sure where exactly you want me to set this [do you mean in the IRP area of the auto Box?], but the instructions in Calman say to use 16-235 for the 3-D lut construction. Please elaborate on your comment.
When I run the dynamic range testing Calman, it clips at 235 using my current set up (mobile forge TV stick to OPPO to EE color box to plasma TV).
I'm new to this, but I'm also concerned about the digitizing effect of being limited to 16-235 (eight bit video input) on my particular plasma screen potentially causing the occasional banding in very pale sky areas when these areas are modified. I wonder if one could simply not modify certain pale colors…
Eric
eganz1 is offline
post #2980 of 3932 Old 10-22-2015, 08:49 AM
zoyd's Avatar
Liked: 1064
You're right you should use 16-235 if you are clipping above white. But that does produce visible banding on my plasma in the blue channel. I've just recently sent my findings to Joel.
zoyd is offline
post #2981 of 3932 Old 10-22-2015, 09:33 AM
eganz1's Avatar
Quoted: 79 Post(s)
Liked: 65
well I think that my TV can adapt to either configuration, but I my primary and target source is my OPPO Blu-ray player.
so you think that there may be a potential problem with the handling of the blue channel…
E
eganz1 is offline
post #2982 of 3932 Old 10-22-2015, 10:31 AM
p5browne's Avatar
Liked: 2381
With 4K, UHD, HDR, (8K ?) etc coming, I'm afraid the Plasma is in it's death throws. Good while it lasted, but my 64" F8500 is now in the basement so my wife has something to watch while doing laundry! (Also keeps the place warmer in the Winter.)
post #2983 of 3932 Old 10-23-2015, 07:45 AM
zoyd's Avatar
Liked: 1064
E
Confirmed problem here and looks like you may be seeing the same thing. It might be helpful if you email your profile (.cpfx) file to spectracal support.
zoyd is offline
post #2984 of 3932 Old 10-23-2015, 07:50 AM
chunon's Avatar
Quoted: 2446 Post(s)
Liked: 2195
Hey Zoyd strictly a plasma issue?
chunon is offline
post #2985 of 3932 Old 10-23-2015, 07:57 AM
Liked: 1999
Zoyd, is this affecting only CalMAN 5.6.x or you see that problem with 5.5.x or older versions?
post #2986 of 3932 Old 10-23-2015, 11:01 AM
zoyd's Avatar
Liked: 1064
zoyd is offline
post #2987 of 3932 Old 10-23-2015, 11:02 AM
zoyd's Avatar
Liked: 1064
Current version and Have not checked previous.
zoyd is offline
post #2988 of 3932 Old 10-23-2015, 11:04 AM
chunon's Avatar
Liked: 2195
I don't know.
Willing to test on my JS9500 what am I looking for ?
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #2989 of 3932 Old 10-23-2015, 11:14 AM
zoyd's Avatar
Liked: 1064
Any visible banding or anomalies in single channel saturation ramps when using an eeColor LUT where iRP profiling is limited to the 16-235 range
zoyd is offline
post #2990 of 3932 Old 10-23-2015, 11:18 AM
chunon's Avatar
Liked: 2195
Oh didn't realize this was specific to the EE color, sorry can't oblige.
65C6 OLED
chunon is offline
post #2991 of 3932 Old 10-23-2015, 11:42 AM
Liked: 1999
Hi, it's a current issue of CalMAN's Cube Generator, if the users that seeing this send the required data to SpectraCAL, then it will be solved in future release.
post #2992 of 3932 Old 10-23-2015, 11:46 AM
Liked: 1999
E
Hi, can you look inside CalMAN folders to locate a 14-16MB file with *.txt extention and upload it to take a look? It's the eeColor 3D LUT correction file that CalMAN is uploading to eeColor memory.
post #2993 of 3932 Old 10-23-2015, 12:11 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 333
None of the code is specific to hardware (5 point lumagen excluded).
Of course the final cube output size has an effect on the algorithm.
We are taking a look now at what may be causing this issue.
sotti is offline
post #2994 of 3932 Old 10-23-2015, 04:32 PM
stash64's Avatar
Quoted: 278 Post(s)
Liked: 97
Cal RGB Profile Turns OFF
I'm running Win10 Home on my laptop and my Cal RGB calibration does not hold. It turns off after an hour or two and always turn off after the laptop display goes to sleep. It never did this with Win7, so I think it is some display setting in Windows 10. Does anyone have an idea what might be causing this profile to drop off ? It's really getting to be irritating.
Sean
stash64 is offline
post #2995 of 3932 Old 10-24-2015, 05:41 AM
Thunderduck's Avatar
Quoted: 54 Post(s)
Liked: 25
Hi Sean,
In the Settings area of Windows 10, check under System. There are some power settings (Power and Sleep) there for your laptop.
Steve
Thunderduck is offline
post #2996 of 3932 Old 10-24-2015, 06:58 AM
PlasmaPZ80U's Avatar
Quoted: 2231 Post(s)
Liked: 682
I haven't been using CalMAN much in the past year since I've been focusing more on audio these days and I haven't bought a new display in a few years.
If I don't renew my CalMAN 5 Enthusiast license maintenance this year (by November 10th I think), and I want to do so next year or a couple years later, will there be an additional fee or anything else I should be aware of?
PlasmaPZ80U is online now
post #2997 of 3932 Old 10-24-2015, 07:05 AM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
I called up well in advance of my expiration date and was quoted 300 for maintenance.
Loving D65
CalWldLif is offline
post #2998 of 3932 Old 10-24-2015, 07:08 AM
Liked: 682
For Enthusiast?
post #2999 of 3932 Old 10-24-2015, 07:43 AM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
For Enthusiast?
yes.
I had been buying the maintenance for a few years and then wham,,,
Loving D65
post #3000 of 3932 Old 10-24-2015, 08:34 AM
AVfile's Avatar
Quoted: 282 Post(s)
Liked: 138
It is $69
http://calman.spectracal.com/store/p...intenance.html
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
Reply Display Calibration
