CalMan 5 Release Notes and Discussion - Page 106 - AVS Forum | Home Theater Discussions And Reviews
 243Likes
post #3151 of 3492 Old 01-25-2016, 06:07 AM
Bloodwound's Avatar
Quoted: 85 Post(s)
I just bought a NEC display bundle with Basiccolor and the NEC version of the I1display Pro. Are there any plans for Calman to support this meter? I figure since Basiccolor supports it, it's not something that X-rite would forbid? Now that I have an both an I1Pro2 and the NEC I1Display Pro, I could see the value of using Calman for future calibrations and not just the ColorMatch part.
Bloodwound is offline
post #3152 of 3492 Old 01-25-2016, 11:43 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
NEC controls the support of their meter.
Unless you can convince them to share their meter codes with us, our hands are tied.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #3153 of 3492 Old 01-25-2016, 12:33 PM
Bloodwound's Avatar
Quoted: 85 Post(s)
the code is 0xa9119479, 0x5b168761
post #3154 of 3492 Old 01-25-2016, 12:58 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
We are an X-Rite licensee, we have to play by the rules.
Joel Barsotti
SpectraCal
sotti is offline
post #3155 of 3492 Old 01-25-2016, 01:25 PM
Bloodwound's Avatar
Quoted: 85 Post(s)
I understand. Guess Basiccolor have made a deal with NEC since they are able to interface with the hardware LUT on the NEC displays. Makes me wonder if I should get an Eizo instead and go with Calman
post #3156 of 3492 Old 01-27-2016, 03:54 PM
Calby's Avatar
Quoted: 13 Post(s)
One thing that are really irritating is that you can't use client 3 on Mac if you don't have English as main Launge on OS X.
Calby is offline
post #3157 of 3492 Old 02-05-2016, 06:44 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
This is a pic of the built in pattern gen 0 black.
notice the border is o black not the pattern.
I have not read any posts about it.
I work around it but want it addressed.
Loving D65
CalWldLif is offline
post #3158 of 3492 Old 02-06-2016, 09:30 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
The ring is bit level 0,
Think of it a little bit of pluge in every pattern, if it's too visible you have the wrong levels, or miss set brightness.
Joel Barsotti
SpectraCal
sotti is offline
post #3159 of 3492 Old 02-06-2016, 09:40 AM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
setting video scale in calman, either vid 16-235 or pc 0-255 is what causes the border to show. setting the level to vid, not using the pattern in Full window, then levels are correct.
BUT, maximizing pattern window shows 16,16,16 pattern while the border is 0,0,0/
setting calman to 0-255 pc and pattern window full, then no border appears.
SO, I use vid levels and don't maximize the window. laptop set to YCcbcr 4;2;2 output.
Since there are so many sets with FALD and dimming, I really need the APL feature which only shows at Maximize window.
Setting to pc levels, allows the use of APL but that doesn't explain why using vid levels has a crossed up 0 black.
the pic is from tv set to proper levels, with proper input signal and
the pattern is jacked.
Loving D65
post #3160 of 3492 Old 02-06-2016, 11:51 AM
p5browne's Avatar
Quoted: 2810 Post(s)
Liked: 2134
http://calman.spectracal.com/downloads.html
Build # 2241 - Version 5.6.1b
We just put out a 5.6.1b release. While there were no changes that affect our Home Theater customers, we went a head and put up a new build of Home Theater as we know some of you will sometimes mix and match licenses and installers.
UN65HU9000 with SEK-3500U - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 up for sale
p5browne is online now
post #3161 of 3492 Old 02-07-2016, 09:14 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
The reason video levels doesn't work with your setup, is because using 4:2:2 from your video card compresses everything your computer outputs.
You either need to use PC levels in CalMAN, enable the expand video levels to PC checkbox, or use RGB Full range from your video card.
There are many different ways to skin this cat. Many of them work correctly, many of them don't work.
Joel Barsotti
SpectraCal
sotti is offline
post #3162 of 3492 Old 02-07-2016, 01:18 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
Super bowl day, I don't expect you to be waiting for a reply.
I have read countless threads bout HTPC and WHAT IS RIGHT.
I also a few years ago rented a TPG from one of Calman divisions to test my card.
Using "vid" setting in Calman to get the proper triplets.
Used a LCD without any fancy backlight trickery.
The pattern gen and vid card were bit on.
That is using both 4:4:4 and 4:2:2. 10 percent windows, no apl.
I found an old workflow session where I found a plasma was reacting differently to different Hz 30, 24, 60 etc.
I used both my laptop vid card, (notice 29 Hz Not avail on Bluray) and Bluray set to 60i and 24P. The gamma curve changed.
No changes were made to TV.
0 black was repeated and .005 is as black as it gets. I used THX and Custom mode also. Point, bluray and vid card agreed for the most part and mainly 0 black/16,16,16 was 0. (Since AVS rounds wrong, a little off is expected)
This work flow was made in vid 16-235 setting in Calman.
If you change the mode to PC 0-255 the data disappears. Kind of a lucky break to show how no trickery was done by me.
I took a little time and ran 3 measures on the LCD mentioned.
Card set to Ycbcr.
1 run was made by media player mp4 patterns with calman set to vid 16-235. 0 black agreed with a run using the pattern generator
set to PC 0-255 but 10 percent up was way wrong.
1 run was made with pat gen PC mode
1 run was made with pat gen vid mode
none agreed.
why will media player (windows) show 0 black and up correct but not Calman?
Frankly I don't know what happened or when. Windowws update? maybe. Don't have time to get into it.
All I know is at one time my vid card and a rental pat gen agreed.
the calman session is too large to upload. pm me an address.
ID:	1236881   Click image for larger version
ID:	1236889   Click image for larger version
Loving D65
post #3163 of 3492 Old 02-07-2016, 02:05 PM
Bloodwound's Avatar
Quoted: 85 Post(s)
Because media player expands videolevels to full levels, then the full levels get compressed to videolevels in the gpu. Reread the second line in the answer from sotti.
post #3164 of 3492 Old 02-07-2016, 02:16 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
hmm, so window microsoft gets it right and calman doesn't.
OK. why have a vid levels in Calman if it don't work.
Loving D65
post #3165 of 3492 Old 02-07-2016, 02:53 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
I am not getting thru.
here are two screen caps from end of 14/ of a real cal session
notice the gray scale is 5%. there is no way I had any 5% patterns other than the calman generator.
notice the setting is Vid 16-235
tell me why 0 black is what it is. geez.
ID:	1237081   Click image for larger version
Loving D65
post #3166 of 3492 Old 02-07-2016, 03:05 PM
Bloodwound's Avatar
Quoted: 85 Post(s)
Neither are doing anything wrong.
Mediaplayer expands levels out of neccesity, but will introduce banding (if not dithered) and will not provide bitperfect output.
Calman is by default bitperfect, it's your settings that are wrong.
post #3167 of 3492 Old 02-07-2016, 03:12 PM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1052
CalMAN video levels are correct so the problem is most likely in YCC over HDMI which for most video cards forces a scaling of the levels sent to the card. To verify either set CalMAN to "expand to PC levels" - which will then get compressed correctly by the card for YCC out, or set the video card to full RGB out (preferred) and leave CalMAN set to video levels.
zoyd is offline
post #3168 of 3492 Old 02-07-2016, 03:13 PM
Bloodwound's Avatar
Quoted: 85 Post(s)
You didn't reread the second line of sotti's answer.
post #3169 of 3492 Old 02-07-2016, 03:16 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
so you have no answer.
Loving D65
post #3170 of 3492 Old 02-07-2016, 03:19 PM
Bloodwound's Avatar
Quoted: 85 Post(s)
That was an answer to your wrongful assumptions that "Windows" getting it right and Calman getting it wrong.
Wake up. You have been spoonfed the answer 3 times already. What else do you want?
post #3171 of 3492 Old 02-07-2016, 03:30 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
lol, yeah. for 4 years i got it wrong.
posted up screen grabs that are just made up.
it is obvious you can't read.
Loving D65
post #3172 of 3492 Old 02-07-2016, 03:48 PM
Bloodwound's Avatar
Quoted: 85 Post(s)
Why are you twisting words and and behave rude to people that try to help you?
Nobody said you were wrong for 4 years. You were wrong in your assumption regarding Windows vs Calman. (Which in itself is a strange comparison, since Windows is an OS and Calman is an application running on Windows).
Nobody are saying your screengrabs are just made up, it's quite the contrary: They show that your settings are wrong.
The solution to your probem has been posted 2 times already, and this is the third time I'm referencing that the solution lies in sotti's second line in his previous answer to you. (plus zoyd basically told you the same thing).
Really, what else do you want?
post #3173 of 3492 Old 02-07-2016, 10:35 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
wrong settings? where?
never mind, you have adopted that belief. no help.
I did some testing. seems a microsoft update is the best guess at this point.
Since I have been a MCSE for 20 years, I do have trouble shooting skillz and tools.
Putting in a new hard drive, imaged with the original OS before any cal stuff, I loaded every version of calman and tested.
Problem solved.
Something changed the triplet call out.
So thanks for your help
Loving D65
post #3174 of 3492 Old 02-07-2016, 10:50 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
Windows 10 is acting the same way.
I try and report an issue and I am met with, "you are doing it wrong".
Fine, I can fix my issues.
Feel bad for all the others.
Loving D65
post #3175 of 3492 Old 02-08-2016, 09:13 AM
Kilgore's Avatar
Quoted: 727 Post(s)
Liked: 435
The reason for the response you are getting from everyone is that "you are doing it wrong".
When I see someone like zoyd, a highly respected and extremely knowledgeable person on AVS, giving you advise on how to address the problem you are having, I would listen to him.
Kilgore is offline
post #3176 of 3492 Old 02-08-2016, 10:34 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Actually the shipping defaults for CalMAN 5 has expand video levels to pc range checked.
This would've given you the expected results with CalMAN software. At some point it got unchecked on your install, which caused your issues.
Joel Barsotti
SpectraCal
sotti is offline
post #3177 of 3492 Old 02-12-2016, 12:24 AM
Bloodwound's Avatar
Quoted: 85 Post(s)
Regarding the NEC meter: Did the support for this meter go unnoticed for both of us?
I accidentally started Calman when the meter was plugged in and it was recognized, but it was in red so I couldn't use it. Looking at the changelog it seems support for it was added in 5.6.1 but only for ultimate.
I thought Colormatch was supposed to support all hardware? It's still recognized, but in red. Are there any plans to add support for the meter to, say, Calman Control?
post #3178 of 3492 Old 02-12-2016, 05:24 AM
AMartin56's Avatar
Quoted: 1041 Post(s)
Liked: 426
Two questions I'm hoping someone can help with. But feel free to tell me to research some more...I haven't be able to find these answers so far.
I went from the basic 'tutorial version' of Calman about two years ago (the one they sell with the their entry level meter) but eventually graduated to HCFR and the additional control over things it gave me. But after seeing an upgrade deal to Enthusiast I'm back and would like to mess with Calman a bit more (Although I still love HCFR). I don't think my 'figuring out HCFR' would have been possible without the previous Calman experience with workflows etc.
Finally the questions:
HCFR sees my Colormunki Photo spectro just fine. Calman 5 does not. Any tips on getting it to work? I'm running Windows 8.1 if it matters.
I use the the AVS 709 HD and GCD calibration discs (These may not be the best discs available but they are what I use,,,and Calman sent me the former with my original purchase). Is there a menu selection that has Calman prompt you through the patterns in the same format they are presented on these discs? Out of the box it's very annoying to have to jump around so much....especially with saturation passes and how Calman saves yellow for last.
Home Theater: JVC RS 420, Yamaha RX-V673, NHT Super Ones/Zeroes w/Ten Sub,
Sony BDP-S5500 and Monoprice 130 inch 2.35:1 White Material Screen
Living room: Sony 60NX720, VIZIO SB4051-C0 Other: Samsung 51F8500
Displays calibrated with HCFR, i1DisplayPro, and Colormunki Photo.
AMartin56 is online now
post #3179 of 3492 Old 02-12-2016, 05:26 AM
AMartin56's Avatar
Liked: 426
post #3180 of 3492 Old 02-12-2016, 05:28 AM
Bloodwound's Avatar
Quoted: 85 Post(s)
I think CM use the Argyll drivers. You need to change it back to use Xrite drivers. You can do this from Device Manager.
Reply Display Calibration
