CalMan 5 Release Notes and Discussion - Page 117 - AVS Forum | Home Theater Discussions And Reviews
 243Likes
post #3481 of 3500 Old 02-10-2017, 04:16 PM
ConnecTEDDD's Avatar
Quoted: 1079 Post(s)
Liked: 1555
Originally Posted by dlj11 View Post
Can someone tell me why the meter-profiling does not work (AGAIN)????
Had this issue a few weeks ago, the meter-profiling did not work. Profiled my EODIS3 against an i1Pro, but then when I check the profile with TED´s workflow the readings of the profiled EODIS3 are all over the place. The whitepoint is somewhere near the wanted target, but RGB are completely wrong. Both meters are 100% OK, when I measure with the EODIS3 with its inbuilt-profiles it works like it should. Only with the added profile it does not work.
TED gave ma a few hints how to correct the issue (deinstall CalMAN, delete some folders and registry-entries), that worked for a few sessions but now I have the same issue again. Deleted every calman-entry on my laptop and reinstalled it again - but it did not work.
How can I completely delete EVERYTHING so that CalMAN thinks that it is installed on a completely new laptop??? The last time I deleted the entries I had to add my license-key after reinstalling CalMAN, but this time I did not have to. So that means CalMAN has an entry somewhere where the license is stored...
Pretty gutted this time, happened while calibration at a "customers" house. Needless to say that I was really pissed off and lost a lot of time. I was lucky that the built in LED-Profile of the EODIS was pretty accurate in comparison with my i1Pro (DeltaE ~0.5), finished the calibration with very good results.
Hi, there is a hidden folder: C:\ProgramData\SpectraCal\CalMAN 5 Home Theater with some subfolders, your license is here: C:\ProgramData\SpectraCal\CalMAN 5 Home Theater\License
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #3482 of 3500 Old 02-11-2017, 07:23 AM
Quoted: 1397 Post(s)
Liked: 911
I just don't understand why there is so much issue with profiling using Calman?
We have a lot of experienced folks here who have proven evidence that you can get a better profile using software other than Calman so the question is why hasn't Spectracal made the necessary changes after all these years to improve the accuracy of the profiling? Does someone have a patent on the process? Maybe the slight difference in the results doesn't make a difference?
Can anyone from Spectracal or familiar with this topic comment?
John
LG 55OLEDE6P
55HU9000 / SEK-3500
Marantz 7009
Ohm Walsh Speakers
ISF Level II Certified
jrref is online now
post #3483 of 3500 Old 02-11-2017, 07:29 AM
Liked: 911
In regards to profiling, I forgot to mention, wouldn't it be "more necessary" to profile every panel you work on due to the fact that even if two sets, for example, were the same panel technology, over time, if it's a back lit LCD or a WRGB OLED, I would think that the spectral power distribution would change over time as the panel aged. Especially for OLED, from what I understand, Blue will change the quickest compared to R& G due to the current technology.
John
LG 55OLEDE6P
55HU9000 / SEK-3500
Marantz 7009
Ohm Walsh Speakers
jrref is online now
post #3484 of 3500 Old 02-11-2017, 07:52 AM
Chad B's Avatar
Quoted: 509 Post(s)
Liked: 1212
I usually do not have any problem using CM's built in profiling to get verified accurate profiles using the method I described.
chunon and jrref like this.
Chad B is online now
post #3485 of 3500 Old 02-11-2017, 10:21 AM
Rolls-Royce's Avatar
Quoted: 250 Post(s)
Liked: 374
I really think that what we are seeing here is more an issue of meter, placement and display variability than a problem with a specific software package. There have only been two or three users complaining about this, which hardly makes it a case of "so much issue". Yes, Ted has created a profile verification workflow (thanks, Ted ), but I think this points more to making sure that variability is having minimum impact on the profile in use than it does to an issue within CalMAN.
ConnecTEDDD and jrref like this.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #3486 of 3500 Old 02-11-2017, 11:39 AM
frumenzio's Avatar
I have the same problem to get a correct profile with xrite i1d3 and Calman (more detail in post 3454)
I take the patch measurement with JetiLival for Reference Jeti1211L and with Calman for i1d3;if I insert these values (xyY) in Ligthspace program I obtain a correct profile but if I use the Four ColorMatrix app I have more error on red x and green y
I have done these profile test a lot of time and I always had the same problem
Display: Panasonic TH-65VX300 BD Player: Cambridge Azur 651BD Video Processor: Lumagen Radiance 2021,TruVue eeColor Meters: Klein K10-A,Xrite i1Display Pro Spectroradiometer: JETI Specbos 1211-L Calibration Software: Calman Ultimate,LightSpace HCC,HCFR Pattern Disk: Ted's LightSpace CMS Calibration Disk Device Control Software: DeviceControl
frumenzio is offline
post #3487 of 3500 Old 02-15-2017, 10:30 AM
Carbon Ft Print's Avatar
Quoted: 301 Post(s)
Liked: 272
Does anyone know how to set the clip point (1100nits) for HDR10 workflow. Just renewed my ultimate license and cannot find any option for the setting the clip point ... whether it's in % or nits. Thx.
Carbon Ft Print is offline
post #3488 of 3500 Old 02-15-2017, 10:41 AM
frumenzio's Avatar
do you mean how to set in workflow the white level?
Carbon Ft Print and jrref like this.
post #3489 of 3500 Old 02-15-2017, 10:47 AM
Quoted: 301 Post(s)
Liked: 272
Originally Posted by frumenzio View Post
do you mean how to set in workflow the white level (the default for HDR10 workflow is 10000 nits)?
I spent 20 minutes trying to figure out where this was at ... thanks!!!! I've have not been in the forum for a long time (years). Thanks so much!
post #3490 of 3500 Old 02-19-2017, 09:05 AM
Quoted: 301 Post(s)
Liked: 272
I'm trying to use ultimate for HDR10 calibration and have a couple of questions:
1. Meter Profiling: I've notice meter profiling does not include the wht or blk pt reads btwn spectro and color meter. Is there someway to do this? Maybe an option missed? Need this for HDR10.
2. HDR10: Want to create a custom PQ then run dE's off of that PQ with BT.2020. Can CalMAN Ultimate do this?
Thx!
post #3491 of 3500 Old 02-19-2017, 09:35 AM
Rayjr's Avatar
Quoted: 175 Post(s)
Liked: 214
Send a message via AIM to Rayjr Send a message via Yahoo to Rayjr Send a message via Skype™ to Rayjr
Thx!
You have a PM
RayJr
Rayjr is offline
post #3492 of 3500 Old 02-22-2017, 08:05 AM
p5browne's Avatar
Quoted: 2812 Post(s)
Liked: 2136
New Calman , BUT, may require renewing licence
http://spectracal.com/forum/viewtopic.php?f=94&t=6206
For Home Theater version 5.7.2 RC2 is available for download.
CalMAN 2016 R2 does require updated maintenance. The cut off date for the purchase that maintenance or initial license key is October 2015.
There is currently an error in the installer which identifies keys from September 2015 as valid. They will not work.
Keys from between October and December 2015 will not be able to activate themselves automatically on upgrade. Your will need to enter your new License ID and License Password after the upgrade has completed.
You can retrieve your information by going to https://aquaman.portrait.com/custome...thorID=2451871, choose the "I forgot my password" link, and enter your email address. Your information will be automatically sent to you within a few minutes.
If you have any problems with this process, you can either contact customerservice@portrait.com, post here, or send me a PM. I will be monitoring the forums all weekend.
Melissa - SpectraCal Quality Assurance
Be prepared for hoops, hurdles, warnings, etc to install the new licencing system.
NOTE: ONLY `one' licence to `a' computer. (NO more multiples.)
UN65HU9000 with SEK-3500U - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 up for sale
p5browne is online now
post #3493 of 3500 Old Yesterday, 02:30 PM
shoman94's Avatar
Quoted: 1366 Post(s)
Liked: 1155
Someone posted in another thread that the update breaks DV calibration? If so when will it be fixed?
...sent from my Axon7 using Tapatalk
My P75-C1 Calibration Settings (3.0.12.2).
My P75-C1 Beta Calibration Settings (3.0.13.5).
Vizio P75-C1 (fw-3.0.12.2), Pioneer Kuro 5020, Pioneer VSX-1131, XBox One
TiVo Roamio OTA, TiVo Mini, Antennas Direct DB4e w/Dipole OTA antenna
shoman94 is online now
post #3494 of 3500 Old Yesterday, 05:16 PM
Quoted: 1395 Post(s)
Liked: 589
I think I'm already in trouble. I've already downloaded it to my internet computer to take a look around. Does this mean I can't download it to my calibration computer?
JimP is offline
post #3495 of 3500 Old Yesterday, 06:19 PM
sillysally's Avatar
Quoted: 835 Post(s)
Liked: 850
Now that you have a Klein K10, Why not use Klein's ChormaSurf.
ss
"Don't worry be happy"
Setup dispcalGUI, 2nd link settings for 65EF9500
http://www.avsforum.com/forum/40-ole...l#post35174522
http://www.avsforum.com/forum/40-ole...l#post39870898
sillysally is offline
post #3496 of 3500 Old Today, 12:31 PM - Thread Starter
WiFi-Spy's Avatar
Quoted: 355 Post(s)
Liked: 677
We have a fix for that bug. Should be released early next week.
Tyler Pruitt - Technical Liaison at SpectraCal
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #3497 of 3500 Old Today, 03:16 PM - Thread Starter
WiFi-Spy's Avatar
Quoted: 355 Post(s)
Liked: 677
I sent you a PM.
WiFi-Spy is offline
post #3498 of 3500 Old Today, 04:15 PM
cadett's Avatar
Quoted: 38 Post(s)
Liked: 98
This is a little concerning as this breaks my chain of in-home calibration. I've always calibrated my PC monitors & then used my laptop to calibrate with. Very disappointed in this move.
cadett is online now
post #3499 of 3500 Old Today, 04:39 PM
Chad B's Avatar
Quoted: 509 Post(s)
Liked: 1212
Also bad for pros who keep a backup laptop.
post #3500 of 3500 Old Today, 04:46 PM
AnotherDude's Avatar
Quoted: 25 Post(s)
Liked: 36
They should allow 2 - even Adobe does!
Sharp Elite PRO70X5FD
Lumagen Radiance 2143
OPPO BDP-105D
AnotherDude is online now
Reply Display Calibration
