CalMan 5 Release Notes and Discussion - Page 119 - AVS Forum | Home Theater Discussions And Reviews
 343Likes
post #3541 of 3774 Old 03-10-2017, 12:50 PM
Oppo Beta Group
RichB's Avatar
Quoted: 1036 Post(s)
Liked: 684
Is there a recommended luminance level for meter calibration?
For example, will 40% be better 70% or visa versa?
- Rich
Oppo UPD-205 | Sonica DAC | BDP-105D | HA-1 | PM-1 | Emotiva XMC-1 | ATI Signature AT6002 x 2 + AT6006 | Revel Salon2s, Voice2, Studio2s | Velodyne HGS-15 | LG 65C7 | Lumagen 2020
RichB is online now
post #3542 of 3774 Old 03-10-2017, 01:46 PM
ConnecTEDDD's Avatar
Quoted: 1347 Post(s)
Liked: 1851
Originally Posted by WiFi-Spy View Post
It was fixed.
Originally Posted by ConnecTEDDD View Post
Glad to see you on-line.
Can you fix my license issue also, I can't install CalMAN 2016 R2. (Customer ID: 2240)
When I login to the portal, I don't see there my annual maintenance paid @ 2 June 2016: Order Confirmation #12436214
License Serial Number: 16618304
Maintenance End-Date: June 2017
I just want to report that all are fine now, Tyler managed to solved my license issue in a few minutes. Thank you
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #3543 of 3774 Old 03-10-2017, 05:55 PM - Thread Starter
WiFi-Spy's Avatar
Quoted: 386 Post(s)
Liked: 725
Originally Posted by RichB View Post
Has this issue been investigated and replaced?
- Rich
We are working on a fix right now.
RichB and AVfile like this.
Tyler Pruitt - Technical Liaison at SpectraCal
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #3544 of 3774 Old 03-11-2017, 01:10 PM
Oppo Beta Group
RichB's Avatar
Liked: 684
What is the recommended method for profiling and measuring an LG OLED?
The I1Display OEM is profiled by an I1Pro2 Spectro.
When Profiling the choices are:
  • Stimulus Level
  • Display Type
When measuring with a profile, there is:
  • Meter Mode (Target Display Type)
With a profile, should I be using RAW mode for both display types.
Playing with different profiles, measurements can vary by 10% in red.
Three profiles are attached with some differences that look significant.
- Rich
RichB is online now
post #3545 of 3774 Old 03-13-2017, 01:10 AM
<^..^>Smokey Joe's Avatar
Quoted: 71 Post(s)
Liked: 95
Choose the display that matches your display type. Although when profiling it neutralizes the type, just don't change it after you profile.
Profile with the i1Pro as the reference device
Make sure the Colorimeter is running with the correct profile.
The 4 colour matrix only corrects at the luminance set point.
Try 75% luminance, this balances the weaker luminance colours with higher luminance targets.
Attached is my newly created profiler test workflow, just the pre tests. The image is of simulated, but I spent the last few days testing with a Jeti1211 and iD3 and found less than 2% XYZ error with the Calman profiler routine. But as I have always stated the 4 colour matrix is only at one luminance. If you devices do not track to each other you will get deviation away from the luminance set point.
The Calman routine may require refining (I believe they are following up according to previous examples in this thread), however it is still under 2% for XYZ for what I have tested in the last few days.
Masterpiece Calibration Ltd
Lincolnvilleshire
New Zealand
<^..^>Smokey Joe is offline
post #3546 of 3774 Old 03-13-2017, 04:00 AM
Light Illusion's Avatar
Quoted: 351 Post(s)
Liked: 662
The best approach to OLED calibration (actually, any display that suffers Metamerism issues) is to use Perceptual Matching.
This is how many professional OLED calibration is performed.
See: http://www.lightillusion.com/percept...our_match.html
(The Guide is for LightSpace CMS, but 'should' work with any calibration system.)
This approach has been developed in partnership with Flanders Scientific, a major professional display manufacturer.
(See: http://flandersscientific.com/tech-r...htSpaceCMS.pdf)
Hope that helps.
Steve
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
post #3547 of 3774 Old 03-13-2017, 04:19 AM
Liked: 1851
- Rich
H Rich,
Usually, during meter profiling, we use 75% or 100% (Stimulus Level) Luminance patches (with 100% Saturation).
For a 2.2 Gamma display, the Luminance of 75% Stimulus Patterns have about 50% of the luminance of 100% Stimulus Patterns, for selecting 75% or 100% It doesn't matter if you have a JETI / Photo Research / Minolta...where they are accurate at low luminance. but If you have i1PRO 1/2: these meters are returning chromaticity but may not be so accurate reading low Luminance levels.
Since you are using CalMAN, you may have seen that it has enabled the LLH (Low Light Handler) for i1PRO1/2 by default; and has a selection for 5,10,20 there.
Because consumer spectro's like i1PRO1/2 are not so good to low luminance readings, for example below 10nits; software will take more than one measurements to patches below 10nits (during meter profiling the Blue patch usually need that) trying to provide a more trusted readings.
For example if you select LLH with 20 samples, CalMAN will start taking measurements, but if will see that there very small deviations between these measurements, it will not measure 20 times in total, maybe 5 will be required only or less, but if there measured larger differences, then it will sample as many times as you have selected (20) and give your the average.
This is the reason that it takes less time at some patches and more at some others. If you have the i1PRO2 LED on, you can count how many times it measures each patch.
It's related also about what peak output you have during the meter profiling, for example if you have a display with 120nits peak output:
If you have a Display with White @ 120cd/m2 with Gamma 2.2:
If you perform profiling with 100% (Stimulus Level) Luminance Patterns then you will have:
100% White @ 120 cd/m2
100% Blue @ 8,6 cd/m2
If you perform profiling with 75% (Stimulus Level) Luminance Patterns then you will have:
75% White @ 63,5 cd/m2
75% Blue @ 4,5 cd/m2
If you have a Projector with White @ 14fl = 48cd/m2 with Gamma 2.2:
100% White @ 48 cd/m2
100% Blue @ 3,4 cd/m2
100% Red @ 10,2 cd/m2
75% White @ 25,4 cd/m2
75% Blue @ 1,8 cd/m2
75% Red @ 5,4 cd/m2
After some of my post and discussion at past in CalMAN 5 Topic, CalMAN changed the default software Stimulus Level from 75% to 100% for that reason.
When you use 100% Stimulus Level patterns for meter profiling you have to check first if all are fine to the levels near the 100% Luminance of the colors, using Contrast pattern (to check near White) or Color Clipping patterns (to check near R/G/B 100% levels). If you have clipping, then this can affect the profiling.
Here are some images I designed to showcase what you are checking when are you looking when you check contrast and color clipping patterns using an RGB Cube Space for presentation.
Using the Advanced Contrast Flashing Bars Pattern it's checking that area:
Using the 7-Color Clipping Bars Pattern to prevent clipping of each color channel (WRGBCMY), this sometimes can be fixed be removing some additionally clicks from the contrast control also, you are checking these areas:
post #3548 of 3774 Old 03-13-2017, 04:28 AM
Liked: 1851
  • Stimulus Level
  • Display Type
- Rich
Hi Rich,
The Meter Type menu of CalMAN is basically useless for spectro's and it's confusing the users.
For i1PRO1/2, it doesn't matter what display type you will select, except:
1) If you need to take Illuminance readings (labeled as Facing Projector options) where you will have to attach your i1PRO1/2 diffuser for that.
2) In case that you have bought your i1PRO1/2 from SpectraCAL ''called as i1PRO1/2 Enhanced' which is a WRGB matrix offset for White-LED...if it helps or not, it's unknown. There so much different White-LED spectra's, many panel variations year-per-year, brand/model etc...
All that long meter table list is just for cosmetic reasons all these years for i1PRO1/2, it will be simpler for these spectro users if there only 2 modes: luminance / illuminance...for the spectro's that are capable for both....for example Colorimetry Research CR250RH is not capable for illuminance readings.
About the meter list of i1Display PRO, it's some factory corrrection X-Rite is adding to the native meter table (the generic). So selecting any of them when you profile it using a spectro, it doesn't matter which you will select (just select the default or RAW). Since CalMAN has Sync mode selection and exposure time also, you can find which combination gives more stable results before staring the measurements each display.
post #3549 of 3774 Old 03-13-2017, 10:24 AM
Oppo Beta Group
RichB's Avatar
Liked: 684
Hi Rich,
The I1Pro(2) as the measurement meter is clear in Calman.
However, when you use the I1Pro is the reference meter for a I1D3, there is a Meter type.
So the question is when using a profiled colorimeter, should the meter type be set or should it be RAW in the profile and when using the I1D3 and a profile.
- Rich
RichB is online now
post #3550 of 3774 Old 03-13-2017, 12:02 PM
Liked: 1851
- Rich
Hi Rich, if you re-read my above post, I have replied for meter type for i1DisplayPRO also.
It doesn't matter what table you will select, since the final results will be the same, just the offset will be different, the meter correction calculation will make your meter read these WRGB patches like the i1PRO you used as reference, just currently there is a bug in the CalMAN's meter correction calculation which add some errors during meter profiling, but once this will be fixed you will have better meter profiling verification results.
Rolls-Royce likes this.
post #3551 of 3774 Old 03-15-2017, 01:14 PM
p5browne's Avatar
Quoted: 2963 Post(s)
Liked: 2277
Build 5.7.2.61 R2 now available.
http://calman.spectracal.com/home-video-download.html
There's only one change from RC3
Resolved issue which caused incorrect value for *u*v gamut area coverage.
UN65HU9000 with SEK-3500U - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 up for sale
p5browne is offline
post #3552 of 3774 Old 03-15-2017, 02:49 PM
Oppo Beta Group
RichB's Avatar
Liked: 684
Is that the profiling fix?
- Rich
RichB is online now
post #3553 of 3774 Old 03-15-2017, 03:05 PM
Liked: 1851
- Rich
No, this is a fix only to Color Gamut Coverarage Calculation when you had selected the 1976 uv coordinates.
post #3554 of 3774 Old 03-15-2017, 05:59 PM
Chad B's Avatar
Quoted: 539 Post(s)
Liked: 1296
That screencap looks interesting. Have you made that workflow public?
I usually get accurate results from CalMAN's profiling, though I have a tough time with it (or at least verifying it) on displays that are unstable over time like the B6 OLEDs. On those I have a hard time getting verified accurate Klein Chromasurf profiles as well, most likely due to the display drifting in between test runs despite my efforts to keep it steady, which are hampered by Chromasurf not controlling my pattern generator.
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS500 and 600, JVC RS400, LG 65C7P, JVC RS420
Copied settings measured, older LG OLED calibration tips, Review index
Chad B is offline
post #3555 of 3774 Old 03-15-2017, 11:39 PM
Quoted: 71 Post(s)
Liked: 95
Chad I was planning on it, although I want more formal statistics as part of available options. Asked SC about it awaiting info on that.
I built it to look deeper into the previous discussion about profiling.
PM me with your email, I'd like another tester of it, still needs more work.
Chad B likes this.
Lincolnvilleshire
New Zealand
post #3556 of 3774 Old 03-16-2017, 01:56 AM
Liked: 1851
Hi Chad, when you use JETI LiVAL and Klein ChromaSuft, you can keep open with a smaller window your CalMAN where you will have connected there only your pattern generator.
I resize the 3 program windows to fill the entire screen, having LiVal at Top-Left half side, Chromasurf Bottom-Left half side and CalMAN at the whole half right side.
In CalMAN I open this page of my workflow where it has 4 buttons for quick forcing the connected pattern generator to display each pattern required during meter profiling:
And the meter profiling is very quick and always accurate.
Chad B, OMARDRIS and jrref like this.
post #3557 of 3774 Old 03-16-2017, 11:28 AM - Thread Starter
WiFi-Spy's Avatar
Quoted: 386 Post(s)
Liked: 725
- Rich
The fix will be in the first beta of CalMAN 2017, coming very soon
RichB, Mark_H, Rolls-Royce and 2 others like this.
WiFi-Spy is offline
post #3558 of 3774 Old 03-16-2017, 01:18 PM
Liked: 0
Can I ask how very soon?
I have a spectro loaned until next week and I would like to know if I have the time to create the profile of my colorimeter with the next beta
tecnezio is offline
post #3559 of 3774 Old 03-16-2017, 02:01 PM
Oppo Beta Group
RichB's Avatar
Liked: 684
I have a dedicated HTPC for my main display and a notebook for my other displays.
Will existing users be able to install on two systems?
- Rich
RichB is online now
post #3560 of 3774 Old 03-16-2017, 03:56 PM
Bloodwound's Avatar
Quoted: 111 Post(s)
Liked: 31
Now that Spectracal has confirmed that there indeed is a bug with profiling, the question is: Are you going to backport the fix this to previous versions?
A bug with the profiling is after all something that affects the fundamental core of a calibration program, and should be fixed in v1.1, not v5.8 or 6.0. I know of people that are still using V3.x since it does everything that they need. The same people have no reason to upgrade until HDR calibration is a reality (rather than mostly being the joke it is today), but in the mean time it would be great to actually know that something you paid top dollars for is able to do profiles, since being able to make accurate profiles are the very raison d'être of calibration.
AVfile, ConnecTEDDD and ivan2011 like this.
Bloodwound is offline
post #3561 of 3774 Old 03-17-2017, 11:24 AM
cadett's Avatar
Quoted: 42 Post(s)
Liked: 102
So I downloaded the new stable version & it asks for a license id & license password. I have a license that has a maintenece end date of March 2017, that contains only a license SN & license key. How would one go about obtaining the new licensing info? I emailed Calman twice in a week, but have not received a response, pretty pathetic if you ask me.
cadett is offline
post #3562 of 3774 Old 03-17-2017, 11:33 AM
frumenzio's Avatar
Liked: 24
in the site http://calman.spectracal.com/faq-on-...016-rev-2.html you can find more information
you should log on the site https://aquaman.portrait.com/customers/Default.aspx and you can find the info required in "License & Activations" section
Display: Panasonic TH-65VX300 BD Player: Cambridge Azur 651BD Video Processor: Lumagen Radiance 2021,TruVue eeColor Meters: Klein K10-A,Xrite i1Display Pro Spectroradiometer: JETI Specbos 1211-L Calibration Software: Calman Ultimate,LightSpace HCC,HCFR Pattern Disk: Ted's LightSpace CMS Calibration Disk Device Control Software: DeviceControl
frumenzio is offline
post #3563 of 3774 Old 03-17-2017, 11:43 AM
cadett's Avatar
Quoted: 42 Post(s)
Liked: 102
Thank you sir. This resolved my issue. I must have overlooked the section the FAQ's
cadett is offline
post #3564 of 3774 Old 03-17-2017, 02:24 PM
cadett's Avatar
Quoted: 42 Post(s)
Liked: 102
So we only get one activation per license still?
cadett is offline
post #3565 of 3774 Old 03-17-2017, 07:25 PM - Thread Starter
WiFi-Spy's Avatar
Quoted: 386 Post(s)
Liked: 725
We can make exceptions to this on a case-by-case basis. I added an extra activation to your license.
We are more than happy to give somebody an extra activation if they have a legitimate reason.
If anyone else is in the same situation don't be afraid to reach out to me.
StevenPK likes this.
WiFi-Spy is offline
post #3566 of 3774 Old 03-19-2017, 02:55 PM
cadett's Avatar
Quoted: 42 Post(s)
Liked: 102
Thank you sir. I'll put it to use.
cadett is offline
post #3567 of 3774 Old 03-22-2017, 10:27 AM
N3W813's Avatar
Quoted: 40 Post(s)
Liked: 77
RE: Meter profile error
Just curious, how large of an effect will the errors introduced by the meter profiling process have on a calibration?
For instance, if I have a calibration that has less than 1 dE average across the board, will the errors affect the calibration by a degree of 1-3 dE or something like 5-10 dE?
galonzo likes this.
My ArgyllCMS/MadVR 3DLUT Creation Workflow
My Sharp Elite Movie THX AV Mode Settings
--Aug 2011 Set, 2.2 gamma [ link ]
--Nov 2012 Set, 2.2 gamma [ link ]
N3W813 is online now
post #3568 of 3774 Old 03-22-2017, 05:16 PM
cat6man's Avatar
anyone running calman on a linux/ubuntu laptop?
i should be able to get it running under 'wine' but no success yet.
cat6man is offline
post #3569 of 3774 Old 03-23-2017, 02:11 AM
Jeroen1000's Avatar
Quoted: 37 Post(s)
I suggest using a virtual machine. That should work.
My gear: Panasonic TH-42PF11EK pro plasma display + TX-P55VT60E -- Iscan Duo video processor -- i1 display 3 colorimeter -- i1 pro 2 spectrometer
Jeroen1000 is offline
post #3570 of 3774 Old 03-24-2017, 01:22 PM
cat6man's Avatar
that will be my backup option if i can't get it working under wine
cat6man is offline
Reply Display Calibration
