CalMan 5 Release Notes and Discussion - Page 131 - AVS Forum | Home Theater Discussions And Reviews
 410Likes
post #3901 of 3916 Old 07-18-2017, 01:01 PM
p5browne's Avatar
Quoted: 3026 Post(s)
Liked: 2352
Calman 5.8.1 RC3
http://spectracal.com/forum/viewtopic.php?f=94&t=6424
CalMAN 2017
Version: RC3
Official Release: July 18th, 2017
New Features
- Auto Calibration for Samsung 2017 QLED televisions.
- Auto Calibration for Panasonic 2017 EZxxx series OLED televisions.
- New Color Volume Workflow – allows you to quickly measure the color volume of any display.
- New Color Volume Visualizer - three-dimensional graphing engine that displays the measurements of the Color Volume Workflow. To access, follow the link in the Color Volume Workflow
- New HLG Workflow – support for the hybrid log gamma version of high dynamic range that is rapidly gaining acceptance for live video production
- New Dolby Vision Custom Workflow – adds support for displays that support the new Dolby Vision Configuration File. - CalMAN uses a new type of Dolby Vision metadata to put the color volume mapping engine into bypass mode. CalMAN then calibrates the display and generates a new Dolby Vision configuration file that is loaded into the supported TV via USB stick.
New Hardware Support
- SpectraCal VideoForge Pro 4K HDR pattern generator
- SpectraCal C6 HDR2000 Colorimeter
- Photo Research PR653 spectroradiometer
- UPRtek MK550T spectroradiometer
- AccuPel DGA-6000 pattern generator
- Datacolor Sypder 5 colorimeter
Improved Hardware Support
- New display type characterizations for SpectraCal C6
Projector (Laser Phosphor)
Projector (Laser Phosphor) - Panasonic RZ12K
Projector (Laser Phosphor) - Panasonic RZ970
- Added 4-40 pattern support
4% window, 40% background
Added to VideoForge HDMI, Murideo SIX-G
- Enhanced capabilities added to Murideo SIX-G
Changed default output to be YCbCr
Added resolution drop down
Added FW check. V1 of the Muridio 6G will need to be the following FW versions
6G v2 - 2.40
6G v1 - 1.87
- Added support for the SpectraCal Video Forge Pro
Resolved Issues
- Resolved an issue with meter profiling.
- Resolved an issue when disconnecting from the Murideo Prisma as a Display.
- Resolved an issue which would cause CalMAN to improperly identify an x-rite OEM i1Pro2 as an i1Monitor.
- Resolved an issue with the Radiance Pro where the wrong LUT could get assigned to the pattern generator.
- Resolved an issue where CalMAN would display an inaccurate error message which attempting to connect to the Murideo 6G.
- Resolved an issue with LUT file formatting for OSEE displays.
UN65HU9000 with SEK-3500U - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 up for sale
p5browne is offline
post #3902 of 3916 Old 07-18-2017, 01:03 PM
skschatzman's Avatar
Quoted: 428 Post(s)
Liked: 313
So what changed from RC2?
Sent from my SM-G955U using Tapatalk
My P65-C1 Beta Calibration Settings (3.3.18.1)
skschatzman is online now
post #3903 of 3916 Old 07-18-2017, 01:50 PM
BertL's Avatar
Quoted: 120 Post(s)
Liked: 306
From the link provided:
Changes from RC2
Added support for the C6 HDR2000.
Ultimate, Video Pro, ISF, Studio, Home Enthusiast, RGB
Resolved an issue with the Color Volume workflow where values were always being displayed as relative.
Changed text on data points drop down for Samsung QLED displays to HDR instead of 17 HDR.
Bert
Denon AVR-X4300H | Sony XBR-55A1E OLED | Def Tech 7.2: Mythos 2 *2, Mythos 3, DI 6.5R *4, SC4000 *2 | OPPO UDP-203 | Apple TV 4th Gen | Nvidia Shield TV (16GB 2017) | DirecTV (1080) HR44 & C51 | Panamax M5300-PM | Logitech Harmony Elite | Monoprice 6' Cert Prem Hi Speed & BJC 25' Series-1 Cert Hi Speed HDMI Cables
BertL is offline
post #3904 of 3916 Old 07-18-2017, 05:53 PM
njfoses's Avatar
Quoted: 147 Post(s)
Liked: 97
So much for the RC2 being final.
njfoses is online now
post #3905 of 3916 Old 07-19-2017, 07:27 AM
p5browne's Avatar
Liked: 2352
New version 5.8.1.34, or is it 8. Eyesight not to good in the dark.
p5browne is offline
post #3906 of 3916 Old 07-19-2017, 09:24 AM - Thread Starter
WiFi-Spy's Avatar
Quoted: 454 Post(s)
Liked: 864
We could always just leave stuff broken
RichB, Mark_H, Rolls-Royce and 6 others like this.
Tyler Pruitt - Technical Liaison at SpectraCal
10 Bit Gradient Test Patterns (HEVC) - Free Download
WiFi-Spy is offline
post #3907 of 3916 Old 07-19-2017, 09:56 AM
njfoses's Avatar
Quoted: 147 Post(s)
Liked: 97
Touche. What i meant was that the email went out over a week ago announcing Calman 2017. I would figure the final would have been released before the email.
post #3908 of 3916 Old 07-19-2017, 02:18 PM
johnvnross's Avatar
Quoted: 22 Post(s)
Hi folks. Quick question:
(Background - no HDR DV projectors yet so I'm hanging around waiting for one)
Until then:
Can you use the OPPO 203 to do the following:
Output 1080p
(In SDR - does the 203 convert bck to rec709 - does anybody know - When it converts HDR to SDR?)
Retaining
10 bit signal
and
the rec. bt 2020 container.
If this is possible - I'd like to hook up a 203 (I have a 103D at the mo) to an integral4k60 and watch 1080p 10bit Wide colour gamut UHD's until and suitable projector comes along.
Cheers
John
johnvnross is offline
post #3909 of 3916 Old 07-19-2017, 11:33 PM
chhanthony's Avatar
Quoted: 57 Post(s)
Liked: 55
Until then:
Output 1080p
Retaining
10 bit signal
and
Cheers
John
Use strip HDR metadata function
Anthony Chan
AV Blog: http://www.avnewbie.com
System: 5.3.4
Panasonic DMP-UB900EBK, Egreat A5, Anthem AVM60, Krell KAV2250 X 2, Theater Amplifier Standard, M&K S-150 X 5, SS150 X 4, Martin Logan Descent-i and Thiel SS 2, SS2.2 and SI 1 Integrator, Benq HT1075, JK 126" Fixed Screen N4-FL/W1
chhanthony is offline
post #3910 of 3916 Old 07-20-2017, 05:32 AM
Hello, World!
Mark_H's Avatar
Quoted: 292 Post(s)
Liked: 202
Question: is it possible to specify a nits level for white that is lower than the actual display brightness so that CalMAN calibrates down to it? So, eg say my display is set up to deliver 200 cd/m2, but I want my 3D cube to only output 120cd/m2 after autocal?
I'm looking at using the Lumagen Pro HDR Intensity Mapping on my TV but am limited to one basic setup, so the idea would be to maximise brightness for the HDR material but use a smaller cube for SDR
dlinsley likes this.
My cinema: The Cave!
My kit: 15' 2.35:1 Screen Research CP2 4-way mask, JVC Z1, Lumagen Pro, Meridian 861/621/7x5500/2xSW5500
Mark_H is offline
post #3911 of 3916 Old 07-20-2017, 06:19 AM
SJHT's Avatar
Quoted: 402 Post(s)
Liked: 204
Is there a difference between the C6 HDR and C6 HDR2000? I have the C6 HDR. Thanks. SJ
SJHT is online now
post #3912 of 3916 Old 07-20-2017, 06:20 AM
Quoted: 428 Post(s)
Liked: 313
Yes
post #3913 of 3916 Old 07-20-2017, 07:54 AM
Rolls-Royce's Avatar
Quoted: 316 Post(s)
Liked: 481
Originally Posted by BertL View Post
From specs on the website and email, the newer model supports up to 2000 nits. IIRC the former HDR model supported up to ~1000, and the original C6 less than that.
The C-6 and Retail I1D3 are guaranteed to 1000 nits. The former HDR model was selected and tested for 1300 nits.
BertL likes this.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
post #3914 of 3916 Old 07-20-2017, 08:21 AM
AnotherDude's Avatar
Quoted: 45 Post(s)
Liked: 56
I posted that question in the Spectracal forum, and was answered by Tyler as Rolls-Royce stated: 2000 nits for HDR-2000, 1300 for the HDR, and 1000 for the original C6.
AnotherDude is offline
post #3915 of 3916 Old 07-24-2017, 03:53 PM
ConnecTEDDD's Avatar
Quoted: 1534 Post(s)
Liked: 1978
CalMAN 2017 5.8.1 Final (Build 34) Released @ 25 July 2017
Release Notes
This is the exact same build as CalMAN 2017 5.8.1.34 (Build 34) RC3. There have been no changes.
Download Links
Manni01 likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #3916 of 3916 Old Today, 05:58 AM
Quoted: 1634 Post(s)
Liked: 698
Last night, I was trying to run a LUTs calibration using an eecolor as my LUTs box.
Since I'm calibrating a 2016 LG OLED, I wanted to use an alternate white point. The one D-Nice came up with for the 2016s.
Can you do this with enthusiast level license? One of the pages in the 3d cube workflow seems to say that selecting alternate white points as well as two other items is only available with certain licenses. It gives you two ways of selecting but nothing to show which of the two you pick which leads me to think that you can't do it with enthusiast license.
On a separate issue, I chose the 90 minute LUTs run which took over 3 hours. Any idea why?
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is online now
Reply Display Calibration
