CalMan 5 Release Notes and Discussion - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 496Likes
post #721 of 4125 Old 01-02-2013, 11:32 AM
Calby's Avatar
Quoted: 13 Post(s)
Originally Posted by p5browne View Post
Don't like the results from the C6 - will only profile off an i1Pro. What Menu Option are you picking for the Meter? Meter was crazy originally because I made the wrong Menu choice.
I profile it against my i1pro so thats good.
I have the original menu options.
Calby is offline
post #722 of 4125 Old 01-02-2013, 10:32 PM
cobhc2010's Avatar
Originally Posted by sotti View Post
Both grayscale and gamut work on the GT50. There is a still a bit of an issue having to set brightness and contrast to default before running autocal, but we are working on that.
Thanks Sotti. So I'd have to do Gamma manually?
cobhc2010 is offline
post #723 of 4125 Old 01-02-2013, 11:01 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
If you want to get the results to be well beyond visual perception than you'll want to touch it up after you re-adjust brightness and contrast. The results of just an autocal are very good, but changing the brightness and contrast causes our calibrated points to measure slightly differently. So you can re-tweak them manually, or just leave the small error.
sotti is offline
post #724 of 4125 Old 01-02-2013, 11:06 PM
cobhc2010's Avatar
I understand that some touch up will be required, but wondered if the Autocal did gamma alongside grayscale.
post #725 of 4125 Old 01-02-2013, 11:12 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
Oh yes, absolutely.
When dealing with two point systems you might separate grayscale out since 2 point controls don't effect gamma and 2 point systems nearly always have a separate gamma control. But when we look at multi-point grayscale data we always show the information to calibrate both the gamma and the grayscale. So our autocal works the same way.
sotti is offline
post #726 of 4125 Old 01-02-2013, 11:22 PM
cobhc2010's Avatar
Oh yes, absolutely.
That's good to know. I have Calman Basic at the moment, and last night I was having trouble getting the dE of 75% gray less than 3 even though the individual rgb and cmy luminance matched the targets quite closely. I also appear to have a problem with gamma at the high end as 80-100% seem to be a major pain to keep level. Any ideas?
post #727 of 4125 Old 01-03-2013, 01:28 PM
p5browne's Avatar
Quoted: 3138 Post(s)
Liked: 2452
Try some of the other Meter Menu Options. One of them may be more suitable to your setup. Originally I was told to go LCD Direct View (Wide Gamut White LED), which turned out to be wrong , (And the Meter did wild and weird things) when LCD Direct View (White LED) was correct for my system.
UN65HU9000 with SEK-3500U in UJS9000 Mod Mode. SDR Input at 1080P 60HZ 444. 4K separate HDMI input - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN32EH5300 (On floor and up for sale) / 2 X LG 55LHXs / New addition UN40J5200AF - Wife's
PN64F8500 still up for sale
p5browne is offline
post #728 of 4125 Old 01-04-2013, 02:01 PM
sodaboy581's Avatar
Quoted: 27 Post(s)
Liked: 39
Does CalMan offer an OPTION calibrating for 9300K? I know 6500K is the standard and I've done a calibration for that using ColorHCFR, but ColorHCFR doesn't have an option for 9300K calibration. (I've heard CalMan is better overall than ColorHCFR, so I figured I'd buy a basic license for it and give it a whirl if it had this option.)
Anyhow, I'm sure you're asking WHY 9300K? Well, I'd like to have an alternate picture mode on my TV for 9300K for watching Japanese television. My fiance is Japanese and sometimes watches Japanese dramas and movies. In Japan, the standard white point is 9300K, so I figured I'd match it using a different scene setting on my TV.
Sometimes, I do some gaming too, both import and domestic, and games typically look better through 9300K than 6500K.
I mean, of course, we can just set the color temperature to "Cool" on that scene setting, but I'd really like to do the gray scale if I could as well.
Thanks in advance for the answer!
Sony XBR-65X900E, Denon AVR-X2300W, Polk CS20 Center, Polk Monitor 75T Fronts, Polk TSI300 Rears, Power Sound Audio S1500 Subwoofer.
sodaboy581 is offline
post #729 of 4125 Old 01-04-2013, 02:09 PM
Joshua Quain's Avatar
Yes you can. See here:
Joshua Quain
www.spectracal.com
Joshua Quain is offline
post #730 of 4125 Old 01-04-2013, 02:16 PM
sodaboy581's Avatar
Quoted: 27 Post(s)
Liked: 39
You're the man! Thanks again!
That's supported in Basic, right? I was a little confused on the webpage by the Gamut Target Editor being an Enthusiast feature. At first, I was thinking that meant just the ability to not use 6500K, but I'm guessing the Target Editor is to create your OWN targets.
Going to have to buy it next week as I spent a lot of money shuffling TVs and also other personal things over the holidays. C'mon, paycheck! smile.gif
post #731 of 4125 Old 01-04-2013, 02:27 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
Well, I'd like to have an alternate picture mode on my TV for 9300K for watching Japanese television. My fiance is Japanese and sometimes watches Japanese dramas and movies. In Japan, the standard white point is 9300K, so I figured I'd match it using a different scene setting on my TV.r!
The japanese 9300K thing is a myth.
If japanese content was mastered at 9300K it would look incredibly red on a properly calibrated display. Not that the consumer displays sold in japan aren't overly blue, but so are most displays here.
If you want to have a 9300K calibration though, that option is available for basic users.
And you are correct the gamut editor allows you to create custom gamut targets.
sotti is offline
post #732 of 4125 Old 01-04-2013, 02:41 PM
sodaboy581's Avatar
Quoted: 27 Post(s)
Liked: 39
post #733 of 4125 Old 01-05-2013, 01:03 AM
Kirnak's Avatar
Just got a DVDO Duo and have a stupid question: Which level o Calman 5 do I need to do an AutoCal with the Duo? How about whiich level do I need to use the Duo as a pattern Generator? I have Calman 5 control. Which features of the Duo will I unlock by going to enthusiast? Thanks!
Kirnak is offline
post #734 of 4125 Old 01-05-2013, 07:29 AM
chunon's Avatar
Quoted: 2504 Post(s)
Liked: 2233
Did the ability to manually enter a correction table in Calman 5 ever become a reality ? I remember reading you guys were working on a tool or update to allow that.
Sony 75XBR940E
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #735 of 4125 Old 01-05-2013, 07:50 AM
hrc4u's Avatar
What I can see it should work with control licence...
http://store.spectracal.com/support/hardware-support.html
GT-i9300 CM10.1
hrc4u is offline
post #736 of 4125 Old 01-05-2013, 09:38 AM
Kirnak's Avatar
GT-i9300 CM10.1
Doh! Thanks!
Kirnak is offline
post #737 of 4125 Old 01-05-2013, 10:08 AM
erkq's Avatar
Quoted: 664 Post(s)
Liked: 465
What about the ability to import/export grayscale/gamma/gamut tables?
erkq is offline
post #738 of 4125 Old 01-05-2013, 11:22 AM
turbe's Avatar
Liked: 97
I'm not so sure about that.. this may be from the past.. though with all the translating that needs to be done, it also seems like from some document translations used there is also talk about CCT 9300K for lighting in productions to. But, Sony professional broadcast monitors have 9300K options - Actually several Professional Level Monitors have options for D55, D65 and D93.
Some References:
  • ARIB Technical documents reference D93 9305K, one Here .
  • From this 2000 Sony Monitor Catalog (Japan D93 NTSC- See Page 92).
  • From Journal of Electronic Imaging (See from Page 2).
  • From Charles Poyntons book Digital Video and HDTV Algorithms and Interfaces ("9300K is common in Asia (e.g., in studio monitors in Japan" on Page 224, "Studio video standards in Japan call for viewing with a 9300 K White reference: this is apparently due to a cultural preference regarding the reproduction of skin tones" on Page 255, "9300 K (discouraged but used in studio standards in Japan) - x= 0.283, y= 0.298, z = 0.419, U' = 0.1884, v' = .4463 on Page 225) - Poynton does not mention D93.
  • From this ITU Document (See Page 2 for second quote text below).
In ARIB of Japan, a Task Group on Flat Panel Display (FPD-TG) was established to set up the user requirement for flat panel display, using it as an HDTV master monitor in a TV program production environment (example: studio, editing room, outside broadcast van, etc.) in June 2004. This is not only because the picture quality of flat panel displays has recently greatly improved, but also because CRT master monitors will no longer be supplied in the near future.
There were two differences: one is that the room was made very dark and the other is the colour temperature of CRT and LCD was set to 9300K (D93). Because it was thought that the subjective assessment test should preferably be conducted under the same viewing conditions as those in the actual TV programme production environment at Japanese TV stations, considering that the purpose of this test was to evaluate the adequacy of picture quality of LCD as a master monitor.
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #739 of 4125 Old 01-05-2013, 01:32 PM
sodaboy581's Avatar
Quoted: 27 Post(s)
Liked: 39
It's not a myth, I just didn't want to start an argument. NTSC-J is defined clearly as 9300K.
Simple Google search of NTSC-J 9300K will reveal all sorts of technical documents and websites, a lot in Japanese, on this subject. As well as companies that produce professional monitors calibrated for 9300K specifically for Japan.
A lot of Japanese HD broadcasts are also produced using the 9300K white point.
Anyway! Not trying to start an argument. I really appreciate the info and can't wait to try out CalMan later!
post #740 of 4125 Old 01-05-2013, 01:48 PM
turbe's Avatar
Liked: 97
It's not a myth
I have also heard about this stuff in the past from my Australian users, it seems like there are many down under who watch content from japan.... unlike North America, UK Europe, Australia models are usually directly manufactured in Japan / asia and brought in to. I just think most here including Professionals have no direct knowledge about the past standards in Japan.
I also saw at EIZO's website that talks about this (EIZO is a Japanese Company, founded in 1968) but was getting lazy on posting additional links lol
As a rule of thumb, most Japanese film titles assume a 9300 K environment, while non-Japanese films assume a 6500 K environment. This means one is highly likely to achieve color reproduction close to that intended by filmmakers by setting the color temperature of an LCD monitor to 9300 K when viewing a Japanese film and 6500 K when viewing a non-Japanese film. (Naturally, this doesn't apply universally.) When using a model with a wide range of choices in Kelvin values—an Eizo Nanao LCD monitor, for example—users can adjust the color temperature to whatever looks best.
Here's also a LINK to preview Page 643 from Poynton's book (though he's going from D65 to 9300K labels:
D65 (except in Japan, where the standard white reference is 9300 K).
All this has peaked my interest again, to see how this looks. I may look at sourcing some original and proper content from there and of course a proper source device and then some calibration sessions..
ControlCAL™
turbe is offline
post #741 of 4125 Old 01-07-2013, 10:51 AM
p5browne's Avatar
Liked: 2452
Did a reading on my wife's 32" Samsung in the Family room - 9500K - but looks good in that it's in a bright room. (Happy wife, happy life!)
p5browne is offline
post #742 of 4125 Old 01-08-2013, 08:31 PM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
I posted some screenshots over in the UT50 settings and Issues thread you can compare the differences. D9300K is quite cooler with "Castle in the Sky" from Studio Ghibli.
http://www.avsforum.com/t/1412033/the-official-panasonic-ut50-settings-issues-thread/570#post_22803809http://www.avsforum.com/t/1412033/the-official-panasonic-ut50-settings-issues-thread/570#post_22803809
anikun07 is offline
post #743 of 4125 Old 01-08-2013, 09:05 PM
sodaboy581's Avatar
Quoted: 27 Post(s)
Liked: 39
I will agree that D 9300K looks wrong in your photos. I also appreciate your effort, but you did your comparison using a DVD released for this region. (I believe in your PM to me, you said you doubt that they rebalanced the color for release over here... but there isn't any way to tell unless you got your hands on a copy of the film for that region.)
I would actually try with some native Japanese content instead of a domestic release here.
Even so, usually the Studio Ghibli movies come out in the theater in Japan first. It's possible that Japanese movies that come out in the theater first are balanced for 6500K first. (Theater equipment and not home equipment.)
And, even if your movie DOES look right at D65, it doesn't stop the fact that Japanese content that airs on TV has and is broadcast at 9300K.
As seen above, there's lots of evidence (from both consumers and professionals) that the Japanese use this as their white point for broadcasting.
This isn't a matter of "Well, gee, since I tested one thing from Japan that was released in the US, that everything native from Japan is done in 6500K!" it's actually a lot more complicated than that.
I downloaded the Persona 4 animation (broadcasted from HDTV, not ripped from DVD or Blu-Ray and on D65, it's clearly far too red.)
post #744 of 4125 Old 01-08-2013, 09:06 PM
AVfile's Avatar
Quoted: 285 Post(s)
Liked: 138
Just got a Radiance and have a newbie question. Should I be using any particular workflow to Autocal it or will the default quick analysis one do? So far the latter seems to work and is looking good!
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
post #745 of 4125 Old 01-08-2013, 09:21 PM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
Good call, thanks! I do own "Howl's Moving Castle" and a film called "Always San Chome no Yuuhi" (Always Sunny on Third Street). I will test with those possibly tomorrow. I'm having issues with my OS HDD so I will see how that goes. I could always see if I can find a rental of "Howl's Moving Castle."
anikun07 is offline
post #746 of 4125 Old 01-08-2013, 10:03 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
No, any old workflow is fine, unless you are planning on doing a full 3D LUT for the radiance, then you should use the Color Cube (3D LUT) workflow.
sotti is offline
post #747 of 4125 Old 01-09-2013, 09:16 PM
p5browne's Avatar
Liked: 2452
Currently have IREs, 2 and 10 Point Plus CMS set to Zeroes. AutoCal Gets the Grayscale fairly Linear. Is it OK to now go into the Grayscale IREs and tweak to get it even more linear, or just leave the IREs at Zeroes. The Autocal seems to have troubles at 20 and 80 IRE, leaving the Gamma 2.2 with some slight elevations. Tweaking flattens it out,
p5browne is offline
post #748 of 4125 Old 01-09-2013, 09:57 PM
sillysally's Avatar
Quoted: 1017 Post(s)
Liked: 952
Just remember that once you have run a full calibration, going back in a changing your settings will 90 out of 100 times change other settings, so you are probably causing other points to be off. So when using autocal imo its best just to re-run autocal until you are happy with the outcome. Also meter placement and window size will have some impact on how the calibration comes out.
When I calibrated manually I would do just that, check and re-check everything, until I got all settings working in harmony.
ss
"Don't worry be happy"
sillysally is offline
post #749 of 4125 Old 01-10-2013, 01:04 PM
p5browne's Avatar
Liked: 2452
AutoCal , despite running 5 times, consistently left 80IRE RGB at equal levels Below the Reference Line. 100IRE, either had problems with Blue, or Red. When it finally got 100IRE right, 80, got worse. Got fed up and Manually tweaked to Flatten the 2.2 line. What I can't understand is, when I find I have 1 Click is too High, or 1 Click the other way is too Low, I thought AutoCal had more settings to play with that would work out to, let's say, a 1/2 Click, or 1/4 Click. But it seems to be constrained by the 1 Click problem as well. (or, it sometimes appears worse like it can only do a 2 Click)
p5browne is offline
post #750 of 4125 Old 01-10-2013, 01:25 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
AutoCal doesn't have any finer resolution available to it than the hardware exposes via it's menu.
sotti is offline
Reply Display Calibration
