CalMan 5 Release Notes and Discussion - Page 46 - AVS Forum | Home Theater Discussions And Reviews
 496Likes
post #1351 of 4126 Old 04-08-2013, 10:22 AM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
Originally Posted by Franin View Post
With the meter facing the screen at what distance is it recommended to place the meter? I was told today it should be at least 1-2 feet away from screen. i was under the impression that it should be close to your seating position. if it is 1-2 feet can the meter be angled up to avoid its shadow ?
Thank you
High end spectros, like the Jeti and PR units, can be located near the seating position because they have a very narrow field of view. Consumer grade colorimeters should be closer, about 1-2 feet away depending on their construction. Their FOV is wider.
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS500 and 600, JVC RS400, LG 65C7P, JVC RS420
Copied settings measured, older LG OLED calibration tips, Review index
Chad B is offline
post #1352 of 4126 Old 04-08-2013, 10:49 AM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Thank you
Here is a Spectracl document that will allow you to picture/measure your meters field of view.
http://store.spectracal.com/article-why-viewing-angle-is-important
The important thing is to have the meter at a height and angle that is the same as your eyelevel when seated. In your line of site but close enough so it is reading the area of the screen with the pattern and nothing out side that area.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #1353 of 4126 Old 04-08-2013, 06:22 PM
Kilgore's Avatar
Quoted: 728 Post(s)
Liked: 435
I place my iDisplay 3 about 1-1.5 feet away from the screen, tilted sideways to avoid the shadow. Works perfectly fine. It helps to do a continuous measurement of a 100% White pattern, adjusting as you move it around to find the best spot.
Kilgore is offline
post #1354 of 4126 Old 04-09-2013, 04:35 AM
Franin's Avatar
Quoted: 2404 Post(s)
Liked: 1512
Thank you. I'm going to have to do it again.
_________________________
Franin is offline
post #1355 of 4126 Old 04-09-2013, 04:37 AM
Franin's Avatar
Liked: 1512
Thanks for the link. I will redo the calibration.
Franin is offline
post #1356 of 4126 Old 04-09-2013, 04:40 AM
Franin's Avatar
Liked: 1512
Another question ( if its ok ) how many hours esp. with JVC projectors am I looking at when I do my next calibration? After the fist initial one will I do my second after it hits 1000 hours or before?
Thank you
Franin is offline
post #1357 of 4126 Old 04-09-2013, 07:56 AM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Thank you
I normally tweak my projector every 6 months.. Once the software and hardware is purchased and you are familiar with your display you will want to keep it looking as good as you can. Hardest part is getting a night when the wife will let me play for a couple of hours...
Doug
post #1358 of 4126 Old 04-09-2013, 08:20 AM
p5browne's Avatar
Quoted: 3138 Post(s)
Liked: 2452
I rather play with calibrating, then the wife. Wife ALWAYS tells me what I'm doing wrong, the PQ just shows me!
Note: Lumagens have new FW updates!
UN65HU9000 with SEK-3500U in UJS9000 Mod Mode. SDR Input at 1080P 60HZ 444. 4K separate HDMI input - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U in UJS9000 Mod Mode / UN32EH5300 (On floor and up for sale) / 2 X LG 55LHXs / New addition UN40J5200AF - Wife's
PN64F8500 still up for sale
p5browne is offline
post #1359 of 4126 Old 04-09-2013, 04:35 PM
erkq's Avatar
Quoted: 664 Post(s)
Liked: 465
If that includes conjugal relations, then no wonder you'd rather play with calibrating! And, no, I don't want to hear any more details about that. smile.gif
erkq is offline
post #1360 of 4126 Old 04-09-2013, 04:53 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 353
Thank you
You can calibrate every week if you want to. I calibrate projectors I am reviewing every 200 hours and there are changes. Not big changes, but there are changes. dEs can change from all below 1 up to 2s and 3s within 200 hours. Note that this does not happen if the projector has an LED light source, it only applies to the high-pressure lamps used in most projectors that are supposed to last for 2000-4000 hours.
You can always measure the projector every 100 or 200 hours and keep a log of how much change you see from the original calibration. That way you can learn how often you might want to do the complete calibration. You may find that the lamp does not change in the same ways when the lamp has 200, 1000 or 2000 hours on it - and the speed of changes may be different with 1000 hours or 100 hours. So it is difficult to say 200 hours or 400 hours or 600 hours... you may want to calibrate at 100 hours, 300 hours, 700 hours, 1200 hours, 1800 hours, etc. Or you may find a different number of hours is best for your projector. When you change lamps, the new lamp may have a similar "change profile" or the new lamp could be very different. You just don't know what is happening without taking a series of grayscsale and CMS measurements.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #1361 of 4126 Old 04-09-2013, 07:20 PM
p5browne's Avatar
Liked: 2452
I get more compliments from the calibrating results, besides, at the age of 68 ? Pheromones gone, hormones gone, and the stress from the Government taking all my money, and trying to live on what's left! Oh yes, try to sneak a few pennies away here and there to save for the OLED 4K TV! (I wonder what it's going to be like to calibrate?)
Appendum after last night's calibration cession:
Whoops!
Crash! Due to the New Lumagen FW not quite getting along with Calman?
Started over. Sitting on the 30/100 2 Point Calibration Workflo Screen that was looking Peachy!
Did Reset - still Peachy, Reset again, still Peachy, One more time, Reset - finally get the 100 Screen.
Decided to do the Greyscale the old fashioned way ChadB had mentioned in the past, except this time,
instead of doing the calibration on the TV, use the DDC to calibrate the XE-3D. 100 set to the 0 Line,
then, starting from 10, work my way back up to 100, calibrating only the Green to 0 Line, start back at 10,
calibrate Blue to 0, with any fine tuning of Green. Once finished, back to 10 to do Red to the 0 line, Again
fine tuning Green and Blue. The result, a Greyscale almost perfectly straight across the 0 line!
Could never do this with the AutoCal, followed by using the DDC fine tuning. Tonight, 125 Point by AutoCal.
p5browne is offline
post #1362 of 4126 Old 04-10-2013, 05:51 AM
Franin's Avatar
Liked: 1512
Thank you, I will look into it when the projector hits another 200 hours. Curious to see the change. The bright side of all this, it cost me nothing just my time( which I don't mind)
Franin is offline
post #1363 of 4126 Old 04-10-2013, 11:52 AM
sillysally's Avatar
Quoted: 1018 Post(s)
Liked: 952
Whoops!
The latest FW for my Mini 3D as a pattern source generator is working fine with the latest Beta of Calman.
When I was using my Mini 3D to store and process the 125 point LUT, I would set both GS and LUT to 0.5 and used a 21 point RGB balance/Gamma/grayscale. Always got some very nice results.
When I did a manual 10 point ISF DDC RGB Balance using the controls of my VT50, I would never change Green only Red and Blue, used Luma to balance out RGB.
As you will see if you look at my link for my VT50's settings.
ss
BTW, the best wife repellent imo is playing a Blu Ray like Starz Spartacus. That will make her think twice before she enters your man cave.eek.gif
"Don't worry be happy"
sillysally is offline
post #1364 of 4126 Old 04-10-2013, 12:40 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4068
Have i1 pro 2 and calman control 5 on order. For profiling if I decide that's what I want to do, do I need to spend $695 on a c6 or is the OEM i1display the better move at $250?
gadgtfreek is offline
post #1365 of 4126 Old 04-10-2013, 12:45 PM
sillysally's Avatar
Liked: 952
I am selling my I1Pro REV D and C6 both new from Calman.
I don't need them anymore because I got a K10-A new from Calman.
ss
post #1366 of 4126 Old 04-10-2013, 12:51 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4068
Please pm me about C6. I did not see in classifieds.
post #1367 of 4126 Old 04-10-2013, 01:47 PM
erkq's Avatar
Quoted: 664 Post(s)
Liked: 465
"Wife repellent"... I don't understand you guys. Of course I've only been married only 18 months... give it time I guess...
erkq is offline
post #1368 of 4126 Old 04-10-2013, 02:32 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Guess that depends on the wife.. Spartacus is one of our favorite shows,shame it is almost done.. along with Banshie (blows Spartus away for violence and sex), GOT, True Blood, The Americans and many others.. wink.gifeek.gif Hard to find a night when I can take over the projector for mind numbing gray scale readings.. mad.gif
Doug
post #1369 of 4126 Old 04-10-2013, 02:33 PM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4068
I love Spartacus, Banshee and Strike Back. And with the equally naked men on Spartacus, I think women like it too LOL.
post #1370 of 4126 Old 04-10-2013, 04:10 PM
p5browne's Avatar
Liked: 2452
24 Months is the Recognized amount of time, then things change, and you learn to calibrate!
Famous last words `Happy Wife, Happy Life!' , then you buy bigger and better, and then learn how to calibrate that one. At some point, it's got to be `Home Theatre!'. That now requires a new method of calibrating! Wecome to the Forum!
p5browne is offline
post #1371 of 4126 Old 04-10-2013, 04:26 PM
erkq's Avatar
Quoted: 664 Post(s)
Liked: 465
6 months to go, then!
I calibrate! smile.gif I've got the CalMAN/Radiance/C6 package and do Color Cube and 21 pt gamma calibrations with it. My wife actually loves the results. I also already have a dedicated home theater... 10' wide AT screen, tiered seating, 16.5 by 21 feet. My wife is all for improving the look of that with printed fabric over the sound treatment and upgraded furniture. I haven't hit that 24 months yet.
erkq is offline
post #1372 of 4126 Old 04-10-2013, 09:52 PM
p5browne's Avatar
Liked: 2452
I don't know about Projection Systems, but on my LG 55LHX, the C6 reading of my set, is far different then the reading of the C6 Profiled off my i1Pro. The C6 seems to get the Reds wrong, whereas with the Profiling, this is corrected.
p5browne is offline
post #1373 of 4126 Old 04-10-2013, 10:04 PM
erkq's Avatar
Quoted: 664 Post(s)
Liked: 465
Maybe it would be worth it for me to try and rent a i1Pro. Reds sure look OK, but the eye is easily fooled.
erkq is offline
post #1374 of 4126 Old 04-11-2013, 12:49 AM
realzven's Avatar
Liked: 84
ss
why not keeping the I1 Pro REV D for profiling the K10 ?
realzven is offline
post #1375 of 4126 Old 04-11-2013, 03:02 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4068
I recently had the chance to run my D3 pro after a reference meter. It wasn't near as close as I'd hope with the plasma profile.
post #1376 of 4126 Old 04-11-2013, 05:58 AM
Franin's Avatar
Liked: 1512
Is it worth the upgrade to a SpectraCal C6? Just for Home use only.
Franin is offline
post #1377 of 4126 Old 04-11-2013, 06:16 AM
gadgtfreek's Avatar
Quoted: 634 Post(s)
Liked: 4068
From what? I have the D3 pro with chromapure and its been nice. Its like the C6 with built in profiles.
That being said I decided to grab an i1 pro 2 and D3 OEM with calman 5 for profiling. Should be pretty deversified now smile.gif
post #1378 of 4126 Old 04-11-2013, 08:14 AM
AVfile's Avatar
Quoted: 285 Post(s)
Liked: 138
Besides the studios are just screwing up the color timing in all the new film transfers.
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
post #1379 of 4126 Old 04-11-2013, 08:15 AM
venkatesh_m's Avatar
Quoted: 39 Post(s)
Liked: 27
U shd not need the d3 OEM as the one u hv will work with calman, I believe. Calman will not use the pro tables that's all.
Sent from my GT-I9100 using Tapatalk 2
venkatesh_m is online now
post #1380 of 4126 Old 04-11-2013, 08:15 AM
PE06MCG's Avatar
Liked: 51
I have both OEM D3 and a C6 and they are both excellent meters.
I think the idea of profiling is to check out the Display for conformity to its type.
I don't think either meter would be the cause of any errors, they give great accuracy for the amateur like me. However, if your display is not typical of the LUT type you use during calibration whether Calman or Chromapure that's where the error can be hence the use of profiling for each Display.
In all probability your Display will be typical but there's always that nagging doubt.
I bought a Spectro to check and it was very close so effectively wasted my money. If I change my Display however I can check that one as well, probably with the same result.
PE06MCG is offline
Reply Display Calibration
