CalMan 5 Release Notes and Discussion - Page 52 - AVS Forum | Home Theater Discussions And Reviews
 495Likes
post #1531 of 4123 Old 05-10-2013, 09:02 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
Originally Posted by ndaa75 View Post
Having a problem generating reports - anyone know if this is workflow specific or not? Using quick analysis on the enthusiast license.
No matter what, hitting generate report does not work.....any ideas Calman crew?
Quick analysis isn't setup for reports.
Each workflow has to be configured to have a pre and post page to work correctly with reports. The QA workflow does not.
You could edit the QA workflow to have a post page that would work with the home report.
sotti is offline
post #1532 of 4123 Old 05-10-2013, 09:12 AM
erkq's Avatar
Quoted: 664 Post(s)
Liked: 465
I'm so frustrated with reports I've just given up. With no modifications to the LUT workflows that come with Enthusiast, I just get pretty graphs with no data. Where are reports documented? Do I have to go through a tutorial that's going to take my time to tell me a lot of stuff I already know or is there documentation for reports somewhere?
I love the product and get great results from it. But I find when there's something not working right that I need documentation for I just forget about it. I don't have time to slog through a tutorial in hopes that what I'm looking for is covered in there somewhere. I'm a "look up what I need" type of guy and find the general lack of complete documentation to be very frustrating.
erkq is offline
post #1533 of 4123 Old 05-10-2013, 09:13 AM
ndaa75's Avatar
Originally Posted by Chad B View Post
I am able to generate reports as usual with my custom workflow
What about non custom workflows? Also what license do you have?
Benq W1080ST Projector, Panasonic TXP55VT30 plasma, Yamaha RXA3020 AVR, Denon DVD-2500BT, Q Acoustics 1010i in 7.1, i1 Pro spectro, i1 Display Pro, Calman 5 Enthusiast, PS3, Xbox 360, Wii
Calibration Management Disc
ndaa75 is offline
post #1534 of 4123 Old 05-10-2013, 09:33 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
  • Quick Anaylsis does not have a report.
  • Home workflows work with the home report.
  • Business workflows work with the business reports.
  • The Color Cube (3D LUT) is designed to work with the Color Cube (3D LUT) Report
  • Custom workflows can work with any report, provided you set up the workflow report sources to point to the data you want.
sotti is offline
post #1535 of 4123 Old 05-10-2013, 09:35 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
Originally Posted by erkq View Post
I'm so frustrated with reports I've just given up. With no modifications to the LUT workflows that come with Enthusiast, I just get pretty graphs with no data. .
Reports are primarily a business feature, but we included them for home users for the first time in CalMAN 5.
Enthusiast should have access to 2 reports, the basic home report and the Color Cube (3D LUT) report. If you switch your report to the Color Cube report, things should work as expected.
sotti is offline
post #1536 of 4123 Old 05-10-2013, 09:45 AM
erkq's Avatar
Quoted: 664 Post(s)
Liked: 465
Right... and as you know, no good deed goes unpunished. smile.gif I'll have a re-look. Thanks!
erkq is offline
post #1537 of 4123 Old 05-10-2013, 09:56 AM
Franin's Avatar
Quoted: 2401 Post(s)
Liked: 1508
Originally Posted by p5browne View Post
The C6, to get the best possible calibration, should be Profiled Off either the i1Pro or 2 Model. Since these meters are more pricey, if you know anyone in your area with one that will lend it for an evening, or, I think you can rent one from Spectracal for a short period of time.
Too be honest I have no idea how to profile, I don't think I want to get involved in all that at the moment. I was told the C6 has the additional calibration tables and also gets updated by SpectralCal.
_________________________
Franin is offline
post #1538 of 4123 Old 05-10-2013, 11:19 AM
ndaa75's Avatar
Thank you Joel.
ndaa75 is offline
post #1539 of 4123 Old 05-10-2013, 11:37 AM
hrc4u's Avatar
Originally Posted by Franin View Post
Hi all I also have a Windows 8 computer but seem can never get Calman Control working on it. Am I doing something wrong?
i'm runnin calman ...enhusiast though fine on my w8/pro 64bit..
does it crash or throw any errors?
cheers!/H
hrc4u is offline
post #1540 of 4123 Old 05-10-2013, 12:06 PM
Nudgiator's Avatar
Quoted: 34 Post(s)
Liked: 37
That's very easy. You only need two sensors: a colorimeter and a spectrofotometer. So you combine the best of the two worlds.
I am sure you will think about it in a few month / years wink.gif
The additional calibration tables are not necessary when you are profiling. The C6 is field upgradeable for NEW technologies, but it's NOT possible to recalibrate it via an update ! You have to send it to SpectraCal for a recalibration.
Source: Samsung UBD-K8500 (UHD), Panasonic BDT-110 (BD), Toshiba HD-XE1 (HD-DVD), Vantage VT-1S (SAT), Kathrein UFS-924 (SAT)
Calibration: LightSpace CMS, SpaceMan, SpaceMatch, CalMAN 5 Prof., Chroma Pure, Lumagen Radiance Pro 4446, Chroma 5, SpectraCal C6, EODIS3, i1 pro 2, Klein K10-A
Target: Panasonic TX-P65VTW60 (Plasma TV)
Sound: Yamaha RX-V2067 (AVR), Teufel Theater LT 3 (Speaker)
Nudgiator is offline
post #1541 of 4123 Old 05-10-2013, 12:29 PM
hrc4u's Avatar
you know profiling takes tops 2-5min?.. =)
/H
hrc4u is offline
post #1542 of 4123 Old 05-10-2013, 12:36 PM
erkq's Avatar
Quoted: 664 Post(s)
Liked: 465
/H
And that $1k meter (at least). Was I sold a bill of goods with the C6? I was told they rarely need re-calibration when sent back. In fact I was advised not to even bother for personal use.
erkq is offline
post #1543 of 4123 Old 05-10-2013, 03:11 PM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
/H
Likely more if you count setting up the second meter and verifying the profile.
My C6 is typically off by 3-5 dE from my Jeti spectro before profiling, as was my older setup: enhanced Chroma5 before profiling off an i1Pro.
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS500 and 600, JVC RS400, LG 65C7P, JVC RS420
Copied settings measured, older LG OLED calibration tips, Review index
Chad B is online now
post #1544 of 4123 Old 05-10-2013, 04:48 PM
hrc4u's Avatar
/H
How exactly do you verify the profile?..
GT-i9300 CM10.1
hrc4u is offline
post #1545 of 4123 Old 05-10-2013, 04:52 PM
hrc4u's Avatar
You can buy the x rite photo/design spectro for lot less than 1k :-) and what I picked up...colorimeters only good for grayscale...not cms.. :-)
hrc4u is offline
post #1546 of 4123 Old 05-10-2013, 05:09 PM
p5browne's Avatar
Quoted: 3132 Post(s)
Liked: 2447
The Good thing about having the 2 different type of Meters is, Meters like the C6, gradually start to go downhill (How gradual, I don't know, you'd have to ask the Experts.), but Profiling brings it back up to the Spectro Level. The Spectros are the Meters that go a long time before having to be re-calibrated. C6, as mentioned above, are quicker, and Profiled, are more accurate like the Spectro, plus the C6 is better in your lower light levels.
UN65HU9000 with SEK-3500U in JS Mod Mode + Input at 1080P 60HZ 444. 4K separate input- Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 (On floor and up for sale) / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 still up for sale
p5browne is online now
post #1547 of 4123 Old 05-10-2013, 05:14 PM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
GT-i9300 CM10.1
Take a measurement run with the spectro and then on a new tab take one with the profiled colorimeter and see if they match above 30% or so.
post #1548 of 4123 Old 05-10-2013, 05:18 PM
Franin's Avatar
Liked: 1508
cheers!/H
Hi there
Before this new update it used to come up with Microsoft found an error running this software( something similar ) will send report to Microsoft. It happens all the time. With the new updated version calman keeps coming up with errors.
Never worked on my windows 8 computer.
Franin is offline
post #1549 of 4123 Old 05-10-2013, 05:22 PM
ConnecTEDDD's Avatar
Quoted: 1732 Post(s)
Liked: 2131
GT-i9300 CM10.1
Or make a layout page like mine to compare both meters without need to switch tabs tabs.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #1550 of 4123 Old 05-10-2013, 05:23 PM
Franin's Avatar
Liked: 1508
Do you have them both setup when calibrating ?
I thought it was firmware updated, I will see how it goes.
Franin is offline
post #1551 of 4123 Old 05-10-2013, 05:26 PM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
Oh, only problem I see is if there are nonlinearities. I got tracking problems in 3D mode when I tried to profile the C6 (contact mode) off the Jeti (non contact, with 3D glasses).
tbaudoin likes this.
post #1552 of 4123 Old 05-10-2013, 05:33 PM
p5browne's Avatar
Liked: 2447
Now if I could only plug in my Non-enhanced i1Pro, and my Enhanced i1Pro and compare them, but Calman won't recognize them both when plugged in together. It's either one, or the other, but not both. You'd think having separate serial #s they would. In the older Calman 4, they actually had separate names, but under 5, both have the same name. (Still couldn't compare them under 4 either.)
post #1553 of 4123 Old 05-10-2013, 05:56 PM
hrc4u's Avatar
hmm..since colorimeters should only be used for greyscale as ive read..that could be right....but still don't get the need for check profile as long as calman does correct the offset/matrix thing right?....no matter how off the meters are from each other at the beginning they should match after profiling?...(so they should always show same"values after profiling...?)
cheers/H
hrc4u is offline
post #1554 of 4123 Old 05-10-2013, 06:11 PM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
cheers/H
A profiled colorimeter can be used for CMS.
Every once in a while something may go wrong with the profiling process. It's happened to me a few times, though not often recently. You wouldn't want to proceed to calibrate with an inaccurate profile.
Problems with meter sync, positioning, etc can cause a bad profile.
post #1555 of 4123 Old 05-10-2013, 06:56 PM
Kilgore's Avatar
Quoted: 728 Post(s)
Liked: 435
Does the new version of CalMan access the newly added pluge patterns in the DVDO iScan Duo with it's latest firmware?
Kilgore is offline
post #1556 of 4123 Old 05-10-2013, 07:15 PM
stash64's Avatar
Quoted: 287 Post(s)
Liked: 104
To those using AutoCal, what are you using as a pattern generator ?
Does a BD player with a usb-uirt controller work well as a pattern generator ? If so, is there a specific controller I should buy ?
Using my Panny BD player as the source/generator would be my preferred method if there are no major drawbacks. I have ChromaPure now but am considering purchasing Calman 5 Control.
Sean
stash64 is offline
post #1557 of 4123 Old 05-10-2013, 08:07 PM
erkq's Avatar
Quoted: 664 Post(s)
Liked: 465
I'm using a Lumagen Mini 3D.
erkq is offline
post #1558 of 4123 Old 05-10-2013, 08:38 PM
sillysally's Avatar
Quoted: 1012 Post(s)
Liked: 952
Same here, and don't forget to check the Reference box in the source box of Calman.
ss
"Don't worry be happy"
For Sale Lumagen Radiance Pro 4440/2, see link for details
http://www.avsforum.com/forum/210-vi...l#post54911046
sillysally is offline
post #1559 of 4123 Old 05-10-2013, 08:49 PM
praz's Avatar
Liked: 26
ss
This would be the case only if using the Radiance as the pattern generator and not as the video processor.
praz is offline
post #1560 of 4123 Old 05-10-2013, 09:06 PM
sillysally's Avatar
Liked: 952
No worry there, understand that we are talking about "pattern generator", if you are using the Radiance as a processor then whatever memory slot that you have a calibration in and you have that memory slot setup to output, then that becomes your Reference output for your video input.
And that is the reason why when using the Radiance as a pattern generator you would want to tick the Reference Pattern box in Calman, so as not to have any calibration's that you have stored in your Radiance modifying your output Patterns for calibration. wink.gif
ss
Reply Display Calibration
