CalMan 5 Release Notes and Discussion - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 457Likes
post #181 of 4036 Old 09-21-2012, 02:28 AM
sillysally's Avatar
Quoted: 992 Post(s)
Liked: 949
Originally Posted by derekjsmith View Post
CalMAN 5 Home Video RC2 out end of tomorrow.
Have you guys looked at the new firmware from Panasonic 1.17 for the VT50's, and have you made any adjustments to the RC2 because of this firmware update?
Tried to do a ISF calibration on my VT50 with the new firmware 1.17 and wasn't happy with what I was seeing in the calibration numbers. CMS a shift in the Primary's for the worse and brightness/contrasts seemed to cause my problems, CMS with adjusting Blue was a total nightmare, Green was no picnic either.
Of-course there could have been other factors involved, and this was just a 1 time fluke.
I use CM5E and a I1pro2.
ss
"Don't worry be happy"
sillysally is offline
post #182 of 4036 Old 09-21-2012, 09:27 AM
derekjsmith's Avatar
Liked: 116
ss
We have not looked at it yet. Been busy with the JVC sutff but I will have our lab setup and run tests over the weekend.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #183 of 4036 Old 09-21-2012, 04:19 PM
p5browne's Avatar
Quoted: 3100 Post(s)
Liked: 2415
Calman 5 - how do you get the Full Screens like I had on Calman 4 after ticking off a couple of selections?
UN65HU9000 with SEK-3500U in JS Mod Mode + Input at 1080P 60HZ 444. 4K separate input- Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 (On floor and up for sale) / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 still up for sale
p5browne is offline
post #184 of 4036 Old 09-21-2012, 04:37 PM
Liked: 116
ss
Just ran with the Panasonic 1.17 AutoCal in the lab without issues.
Derek
post #185 of 4036 Old 09-21-2012, 04:39 PM
Liked: 116
Not sure what you mean? For the applications we have the traditional close/min/max controls in the upper right that is persisted.
Derek
post #186 of 4036 Old 09-21-2012, 09:22 PM
p5browne's Avatar
Liked: 2415
Calman 4 - remove Check Marks Beside Grey Scale Window Field, and Gamut Window Field
Calman 5 - Found - Under 1Scan Duo, set Window Size to Full
New problem - Can't find the Dark Meter Reading click setting for the i1Pro. You're probably going to tell me something simple, but 2 of us tonight could not find where to do the Dark Reading.
p5browne is offline
post #187 of 4036 Old 09-21-2012, 09:32 PM
rjyap's Avatar
Quoted: 31 Post(s)
Liked: 24
I just press F4 for dark meter reading. Hope this help.
rjyap is offline
post #188 of 4036 Old 09-21-2012, 11:15 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 334
Click the timer.
In v4 the timer would open the Dark Cal tab as well, now it's part of the tab.
sotti is offline
post #189 of 4036 Old 09-22-2012, 12:55 AM
sillysally's Avatar
Quoted: 992 Post(s)
Liked: 949
Thank You.
Glad to read there is no issues with Calman and 1.17 firmware.
I haven't used autocal yet, but with your new RC2 I will try it.
ss
post #190 of 4036 Old 09-22-2012, 04:43 AM
p5browne's Avatar
Liked: 2415
How about in RC3 - the message becomes: Error #17 Push F4 for Dark Meter Reading .
Next question: Where to find Function Key Listing.
p5browne is offline
post #191 of 4036 Old 09-22-2012, 09:32 AM
Liked: 116
We will be added shortcut and function keys to the Introduction workflow and help files but for now:
Derek
post #192 of 4036 Old 09-25-2012, 07:09 AM
p5browne's Avatar
Liked: 2415
Problem on my LG 55LHX - Service Menu White Balance Warm - Calman 4 and 5 have Red at 200 - over the 192 LG Recommends as the top value.
Solved: Now use Pixel Protector Pixel Washes before calibration, during the set's warm up period. Red now at 188: now below the 192
Problem with SD Local News at night: could never get skin tones anywhere close to looking natural.
Solved: Use Calman 5, and Profile the i1Pro to the C6. (Having trouble trying to Delete the older Profiles though - click Delete, and they don't delete!)
Problem: 5 readings taken across the 55LHX panel all give total different readings, making Meter on the Screen for calibration, localized.
Solved: Mounted C6 on Tri-pod, profile off i1Pro and calibrate with Meter about a foot away from panel.
Problem: Greyscale is down to the fine tuning. On Calman 4, Window would zoom in so that we could see closer details to do the fine tuning. Calman 5 doesn't seem to do this?
Solved: No - anyone with an answer to this problem?
p5browne is offline
post #193 of 4036 Old 09-25-2012, 08:16 AM
Nudgiator's Avatar
Quoted: 34 Post(s)
Liked: 35
You can use "autosize" or manually input the borders for the chart (use right click on chart)
Source: Samsung UBD-K8500 (UHD), Panasonic BDT-110 (BD), Toshiba HD-XE1 (HD-DVD), Vantage VT-1S (SAT), Kathrein UFS-924 (SAT)
Calibration: LightSpace CMS, SpaceMan, SpaceMatch, CalMAN 5 Prof., Chroma Pure, Lumagen Radiance Pro 4446, Chroma 5, SpectraCal C6, EODIS3, i1 pro 2, Klein K10-A
Target: Panasonic TX-P65VTW60 (Plasma TV)
Sound: Yamaha RX-V2067 (AVR), Teufel Theater LT 3 (Speaker)
Nudgiator is offline
post #194 of 4036 Old 09-25-2012, 08:32 AM
Liked: 116
True most of our charts are set to a fixed scale in CalMAN 5 because auto scaling charts were confusing to most. But you can right click on any chart and change its properties including scaling type: fixed, manual or auto.
Derek
post #195 of 4036 Old 09-25-2012, 09:22 AM
mouradb's Avatar
Did anyone try calibrating a JVC-RS45 with CalMan 5 (Enthusiast)? Both my computer and the JVC are connected via LAN. CalMan5 finds my JVC fine. I am tryinig to have Calman5 auto-calibrate the grayscale. The software shows it is processing different points and after few minutes, it says that it is done. But the results are not that great (RGB balance all over the place) and I when I look at the gamma curve thru the JVC menu, I don't see any changes. What am I missing?
My goal is trying to get the grayscale calibration handled (mostly) by the projector. When completed, I'll reconnect everything thru my radiance and proceed with the gamut and the cube calibration.
PS. Sorry didn't save my session. WishI did so that I can show a snapshot. I'm planning on trying a 2nd time anyway, so any advice will help. Thanks.
mouradb is offline
post #196 of 4036 Old 09-25-2012, 09:37 AM
Nudgiator's Avatar
Quoted: 34 Post(s)
Liked: 35
I suggest the following:
1. Select a gamma curve which lies slightly above power gamma 2.2, a color temperature near 6500K and a slightly oversaturated gamut (if possible)
2. Adjust black and white level with the JVC controllers
3. Calibrate the 100 IRE white point ONLY with the GAIN controllers of the JVC - don't touch the OFFSET controllers !
4. Run grayscale/gamma autocal with the Radiance
5. Run 125-point cube autocal with the Radiance
With that hints you will get a nearly perfect result !
post #197 of 4036 Old 09-25-2012, 09:41 PM
p5browne's Avatar
Liked: 2415
Don't get any Menu re sizing when right clicking on the Chart - Get Help, Past and Properties. Tried right clicking all over the chart and get the same. Is there a specific area to click for the menu?
p5browne is offline
post #198 of 4036 Old 09-25-2012, 10:11 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 334
Choose properties.
The Axis settings are one of the properties for the chart.
sotti is offline
post #199 of 4036 Old 09-26-2012, 06:19 AM
rachmat-d's Avatar
Quoted: 34 Post(s)
Can not use Autocal ColorCube, with New Firmware from lumagen.
The application is non responsive.
Still can do Autocal on greyscale, but not with Gamut.
rachmat-d is offline
post #200 of 4036 Old 09-26-2012, 06:56 AM
rachmat-d's Avatar
Quoted: 34 Post(s)
It work , i wrongly set for radiance CMS. It Should be Radiance 3dLut.
post #201 of 4036 Old 09-26-2012, 10:59 AM
Liked: 116
Thanks for confirming this was not broken you had me worried. Our grayscale and cube AutoCal code for the Radiance has worked without incident since firmware 090412.
Derek
post #202 of 4036 Old 09-26-2012, 06:19 PM
robnix's Avatar
Quoted: 756 Post(s)
Liked: 558
Originally Posted by robnix View Post
I downloaded that one. It's the same one I was using before. Same issue. Tomorrow I may have time during the day to test with a DPG-1000.
Tried this again with the 1.2b disc from the Spectracal website. I still end up in the ColorHFCR patterns. Doing a Grayscale autocal, the first pattern is fine, but after that disc goes to the wrong patterns.
These are the steps I follow:
Connect i1pro rev d.
Put 1.2b disc in my Panasonic Blu Ray player
In the TV Menus go to Custom > Pro Settings > Red Button.
Start Calman 5 RC2
Set the Disc to the Top Menu, the one with the 709 logo on the screen
Initialize my i1pro
Go to Grayscale
Start Autocal.
Looky here!
robnix is online now
post #203 of 4036 Old 09-27-2012, 01:23 AM
DaGamePimp's Avatar
Quoted: 443 Post(s)
Liked: 494
Control version not allowing me to use my i1Pro spectro, it throws a license error 26 even though it finds the meter (shows it in red on the main and white on the profile but I cannot use it).
Any help would be appreciated..?
Thank you,
Jason
Media Room = Samsung 65KS8000 / Denon x3300 / Klipsch speakers / Velodyne subs / Samsung K8500 / PS4 Pro + PSVR / WiiU / PS3 / 360 / Wii / 1080 TI - i7 game PC / Multi-Arcade / My HT SLIDESHOW
DaGamePimp is offline
post #204 of 4036 Old 09-27-2012, 01:39 AM
ConnecTEDDD's Avatar
Quoted: 1671 Post(s)
Liked: 2080
Thank you,
Jason
Try installing the latest CalMAN 5.0.3.938 Release Candidate 2.
http://store.spectracal.com/downloads.html
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #205 of 4036 Old 09-27-2012, 01:17 PM
DaGamePimp's Avatar
Quoted: 443 Post(s)
Liked: 494
Thank You Ted, the new version fixed the issue, I still do have to search for it to find the i1Pro, but at least now it will let me use it. biggrin.gif
Jason
post #206 of 4036 Old 09-27-2012, 08:59 PM
p5browne's Avatar
Liked: 2415
Where do you click now, to get the 6500K readings in Calman 5?
p5browne is offline
post #207 of 4036 Old 09-28-2012, 04:55 AM
Liked: 116
Not sure what you mean by "6500K readings"? By default CalMAN 5 is set to D65.
Derek
post #208 of 4036 Old 09-28-2012, 06:22 AM
buzzard767's Avatar
Quoted: 1660 Post(s)
Liked: 2438
I think he's looking for one of these:
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #209 of 4036 Old 09-28-2012, 08:44 AM
sillysally's Avatar
Quoted: 992 Post(s)
Liked: 949
Or when doing your grayscale you could look at the smaller box (yellow border) on the lower right side of your screen the one that says CCT Avg. and don't change the default setting of 6503K. For each IRE you will see a black dot, the idea is to get them all in the center of the square box.
In the example below you can pretty much believe your CCT's are about as close as possible. This will also reflect in your Raw numbers to sum degree.
ss
post #210 of 4036 Old 09-28-2012, 06:40 PM
p5browne's Avatar
Liked: 2415
On Calman 4 under Inital Settings Display Control you could take a reading and show what value you were getting. ie: My wife's favourite Samsung - 9500K! (Which I'm not allowed to change!) My calibrated sets, in and around the 6500K.
I know about the lower right hand box, Will have to check if there's any values there tonight.
p5browne is offline
Reply Display Calibration
