CalMan 5 Release Notes and Discussion - Page 79 - AVS Forum | Home Theater Discussions And Reviews
 243Likes
post #2341 of 3489 Old 05-18-2014, 01:23 PM
AVfile's Avatar
Quoted: 241 Post(s)
Liked: 126
I don't recall 5.3 being released. If so they need to update their web site for the new features and hardware support page.
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
post #2342 of 3489 Old 05-18-2014, 02:39 PM
ACappo's Avatar
Quoted: 47 Post(s)
Liked: 45
Can BT1886 reveal banding?
my issue is the following My son is watching X-Men 2 on sky (satellite) an in a dark scene i notices some banding on the background, initially I was thinking Image compression is not uncommon on TV, however I decided (much to my sons frustration smile.gif ) to pause the scene and turn the cLUT off , this revealed that there still was banding however not as much, could this be down to the fact that I use BT1886 on my cLUT and that my TV in general have a flat Power Law 2.2. i.e. without the cLUT the dark back ground was darker, and brighter with the cLUT applied (more revealing).
ACappo is offline
post #2343 of 3489 Old 05-18-2014, 02:52 PM
ConnecTEDDD's Avatar
Quoted: 1066 Post(s)
Liked: 1539
Originally Posted by ACappo View Post
Originally Posted by ConnecTEDDD View Post
If you see the LightSpace's Customers List, Shooters Inc. and Park Road Post Productions are using LightSpace and propably used monitors calibrated for Blu-Ray (REC.709) Release with Power Gamma Law 2.2-2.3 Power Law Gamma.
BT1886 is a fairly new feature in LS right? So yes based on that BT1886 is unlikely.
Ted you know of the cube solutions available for the pro marked, how many other have BT1886 as a gamma option?
The defacto applications that post-production studios are using all these years for large 3D LUT Profilings are:
BaseLight TrueLight (September 2003)
Rising Sun Research CineSpace (around 2002) changed to CineTal CineSpace (August 2008) - > later became THX CineSpace CineCube (April 2012) were it was locked to REC.709 only (with reduced price).
Light Illusion LightSpace CMS (January 2009) (The Chief Color Scientist of LightSpace was responsible for the colour science in TrueLight)
CalMAN Studio where it was entered lately to pro industry (July 2012).
During my latest access of CineSpace's Private Secured FTP, they didn't had support for BT1886, just at August 2013 they added the Target Profiling File for REC.709 2.4 Power Gamma, before August it were available only REC709 2.2
THX CineSpace/CineCube has 2 worklows: ITU-R_709_g2.2 + ITU-R_709_g2.4, no BT1886...
It was not possible to enter custom gamma value with CineSpace.
Also THX CineSpace/CineCube project has now discontinued... frown.gif Their site are offline also... frown.gif
BaseLight TruLight has BT1886 as an option but I don't see any option for Black Offset, I can't test a evaluation to tell you this 100% because I don't have a Mac or a Truelight Projector / Monitor Probe...
TruLight works only with their probe, no other probes are supported. frown.gif But meter correction matrix is available.
Since the Post Production Industry don't widely using BT1886, you can calibrate to any gamma target you want, just note that REC.709 2.2 Power Gamma is the most common gamma used for the movies that have been mastered since now...
If you take 3 different displays, lets say, one plasma, one LED-backlit LCD and one CCFL-LCD backlighting and you calibrate them using the same gamma target value, if you display the same material after that the same time from that 3 panels, it will be different at shadow detai/mid-tones etc. etc.. to your eyes....
An idea of having 2-3 different memories to your LUT Box of to your internal display memories and swap them to find which one that it gives you the best performace of your display to each specific movie using your eyes is the best solution right now.
We can't do anything about it, and we don't know if the monitors that are calibrated at studios are calibrated so tight to the specs..... or how frequently they are calibrated... a mystery.....
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #2344 of 3489 Old 05-18-2014, 04:24 PM
Iron Mike's Avatar
Quoted: 62 Post(s)
Liked: 407
can you elaborate on your latest calibration ?
which display/PJ did you calibrate, CM options and cube size, validation workflow.... did the 1000+pt val patch set run through okay the second time ?
Can you post pics here of the CM report of the large validation patch set ?
- M
calibration & profiling solutions: Lightspace, Spaceman, Calman, Argyll, ColorNavigator, basICColor
profiling & calibration workflow tools: Display Calibration Tools
meter: CR-250, Klein K-10 A, i1Pro, i1D3
AVS thread: Lightspace & Custom Color Patch Set & Gamma Calibration on Panasonic 65VT60
Iron Mike is offline
post #2345 of 3489 Old 05-18-2014, 07:31 PM
cadett's Avatar
Quoted: 37 Post(s)
Liked: 98
Hello guys, the last official release was CalMAN 5 Home Theater 5.3.0.1450
I pulled that info directly from the public site. Apparently they have another version somewhere else.
cadett is offline
post #2346 of 3489 Old 05-19-2014, 12:25 AM
HDTVChallenged's Avatar
Liked: 215
Can BT1886 reveal banding?.
Yes ... absolutely, yes. Perhaps the worst example of banding I've ever seen is on the remake of "Fright Night" (delivered via D*, HBO/Sho/Starz ... don't recall which at the moment)
It's not BT1886's fault, the banding is clearly in the source ... it's just much more noticeable when you flatten out the "gamma" at the dark end.
HDTVChallenged is offline
post #2347 of 3489 Old 05-19-2014, 02:56 PM
ACappo's Avatar
Quoted: 47 Post(s)
Liked: 45
Mike I did not try again with the large patch set, but I have just set it of again with a gamma of 2.22.
This bring up a question.
All my tv modes have undersaturated green with the exception of dynamic, has anyone tried to calibrate that? I have reduced contrast and backlight and set brightness so it look ok, however my pre calibration grayscale if very off, can the cube sort that out? I guess time will tell smile.gif
HDTV
I will try with 2.22 hopefully that will help, I must admit I have yet to see a movie where I preferred bt1886
ACappo is offline
post #2348 of 3489 Old 05-19-2014, 03:01 PM
Iron Mike's Avatar
Quoted: 62 Post(s)
Liked: 407
HDTV
the eeColor 65^3 LUT can/will definitely improve your GS, it has 65 GS points, but you should try to setup GS as good as possible before profiling, do at least 30/100 and try to get 100 as accurate as possible...
post back the large validation patch set report when u had a chance to run it... that will give us great feedback how the LUT performs !
- M
W3Rman likes this.
post #2349 of 3489 Old 05-19-2014, 03:15 PM
ACappo's Avatar
Quoted: 47 Post(s)
Liked: 45
Problem is in dynamic mode does not have any gray scale control.
I will post the validation files when done, but might be a few days, depending on the dynamic test
ACappo is offline
post #2350 of 3489 Old 05-19-2014, 03:45 PM
Iron Mike's Avatar
Quoted: 62 Post(s)
Liked: 407
I meant, setup the display BEFORE you start the profiling process... that's the correct approach...
ergo, load the CM 30/100 chart (there is one somewhere under Advanced Calibration IIRC) - adjust 30 and 100 on your screen via the internal display CMS, and when all good then start your LUT profiling process in CM... smile.gif
post #2351 of 3489 Old 05-19-2014, 03:56 PM
ACappo's Avatar
Quoted: 47 Post(s)
Liked: 45
To avoid undersaturated green am I using the dynamic profile on my tv, however when selecting dynamic all advanced options in the tv menu is greyed out, no 2pg grayscale settings and no CMS.
ACappo is offline
post #2352 of 3489 Old 05-19-2014, 04:01 PM
Iron Mike's Avatar
Quoted: 62 Post(s)
Liked: 407
what is a "dynamic profile" and what is the name and model of this mysterious tv ? smile.gif
post #2353 of 3489 Old 05-19-2014, 04:11 PM
Quoted: 1394 Post(s)
Liked: 588
Better yet, put your display and calibration equipment/software in your signature so we can better help you.
tbaudoin likes this.
JimP is offline
post #2354 of 3489 Old 05-19-2014, 07:25 PM
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
Is this ok for placemebt it's about 3-4 inches away but it's a HP dalite screen so it's kinda in direct path of my projector.
My projector is shelf mounted above my head for best results with that screen.
Holiday121 is offline
post #2355 of 3489 Old 05-19-2014, 09:59 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Looks pretty good. You'd want the meter at about the same angle of incident as your eyeballs for viewing. I'd guess that would mean a little more horizontal if you can work it that way.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #2356 of 3489 Old 05-19-2014, 10:39 PM
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
Thanks was just making sure I was doing it right
post #2357 of 3489 Old 05-21-2014, 01:06 AM
ACappo's Avatar
Quoted: 47 Post(s)
Liked: 45
im in a bit of a rush but will update tonight meanwhile please find attached data of the validation set
1085.xlsx 1010k .xlsx file
Iron Mike and ConnecTEDDD like this.
ACappo is offline
post #2358 of 3489 Old 05-21-2014, 03:30 AM
Iron Mike's Avatar
Quoted: 62 Post(s)
Liked: 407
you are one of the first to provide actual validation data of a CM LUT running a large custom patch set in CM...
alright, 1087pt custom patch set
dE 2000
avg: 1.075503039
max: 6.8854
points with dE > 1.5: 233
points with dE > 2.0: 124
points with dE > 2.5: 75
points with dE > 3.0: 54
dE 2000 luminance compensated
avg: 1.132358748
max: 8.1761
points with dE > 1.5: 259
points with dE > 2.0: 150
points with dE > 2.5: 99
points with dE > 3.0: 77
- M
ConnecTEDDD likes this.
post #2359 of 3489 Old 05-21-2014, 03:37 AM
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
I am so close to pulling the trigger on Calman 5.
Eh
post #2360 of 3489 Old 05-21-2014, 06:54 AM
Liked: 1539
dE 2000
avg: 1.075503039
max: 6.8854
avg: 1.132358748
max: 8.1761
- M
Hello ACappo, how many color points did you calibrated with CalMAN to have this report?
Can you re-measure these 1085 Patches without correction LUT Active?
Iron Mike likes this.
post #2361 of 3489 Old 05-21-2014, 07:41 AM
zoyd's Avatar
Quoted: 1315 Post(s)
Liked: 1051
I was going to ask the same thing, there is a trend for high dE points at lower saturations so it would be good to know what the pre-LUT values are for these points. I've found that a saturation density of 9 (17/9 is what I typically use) provides good coverage in combination with DLC, and the DLC threshold set to 1.5
Out of curiosity I ran the same test set ACappo used through my RC1 calibrated eecolor memory slot to compare to what I see using my typical random set and the statistics were very close to each other.
1000 Random
Avg= 0.69
Max= 2.60
# > 1.0 = 139
# > 2.0 = 4
# > 3.0 = 0
1086 set
Avg=0.64
Max=2.76
# > 1.0 = 136
# > 2.0 = 5
# > 3.0 = 0
zoyd is offline
post #2362 of 3489 Old 05-21-2014, 01:51 PM
1forsnow's Avatar
Quoted: 41 Post(s)
Liked: 54
I can semi add to this. The screenshot below is from the latest version of calman. I have a kuro so the blue is undersaturated, so the spike in errors if from the color points that are undersaturated. That can clearly be seen in the charts. As a confirmation i suppose I can create a custom colorspace to move the blue point up to remove the saturation error in the charts. However that wont do anything for me but give me better looking charts.
1forsnow is offline
post #2363 of 3489 Old 05-21-2014, 02:19 PM
ACappo's Avatar
Quoted: 47 Post(s)
Liked: 45
Okay let's try:)
My test display is an older samsung LN46A560. It has issues with undersaturated red and green and at low luminance it desaturate colors (mainly red)
To avoid the undersaturated red/green did use dynamic mode (i have the options of standard/movie/dynamic) I know this is my far the worst mode for calibration, since it turn blue up in the grey scale without the option to fix it (advanced menu is disabled) so pre calibration the picture is as bad as possible. I will try again in standard this weekend.
I used CalMAN's detailed option when starting the cube calibration, I unfortunately I didn't Check the total number of readings
I will recalibrate this weekend, doing a full pre calibration patch set.
ACappo is offline
post #2364 of 3489 Old 05-21-2014, 02:22 PM
Iron Mike's Avatar
Quoted: 62 Post(s)
Liked: 407
what are the stats for this ?
Charts like this can look "better" because of resolution of the point and the target area, that's why they don't mean much...
what are the numbers ?
post #2365 of 3489 Old 05-21-2014, 02:24 PM
Iron Mike's Avatar
Quoted: 62 Post(s)
Liked: 407
Okay let's try:)
not sure what exactly "dynamic mode" does on this display, but u def want to disable any "dynamic" behavior... display needs to be set up as good as it can be in pre-profile and then remain stable...
post #2366 of 3489 Old 05-21-2014, 02:48 PM
ACappo's Avatar
Quoted: 47 Post(s)
Liked: 45
Its what is also known as torch mode
ACappo is offline
post #2367 of 3489 Old 05-21-2014, 03:07 PM
1forsnow's Avatar
Quoted: 41 Post(s)
Liked: 54
I am not sure what you mean mike? The average for 1000 points is .5272 with the highest error at 2.1335. The delta graph at the bottom shows this. Is this not good?
1forsnow is offline
post #2368 of 3489 Old 05-21-2014, 03:24 PM
Iron Mike's Avatar
Quoted: 62 Post(s)
Liked: 407
yeah, for whatever reason the image does not enlarge when I click on it... it's hard to tell what the numbers are on the Y axis... so it's dE 1, 2, 3 ?
Edit: got it, had to restart Firefox to get it to work ! smile.gif
post #2369 of 3489 Old 05-21-2014, 03:41 PM
Iron Mike's Avatar
Quoted: 62 Post(s)
Liked: 407
so, can you elaborate on your validation set up ?
Is this a custom patch set or a 10^3 grid ? did you use an external patch generator, HDMI Out or Ted's disk via Blu-ray ?
- M
post #2370 of 3489 Old 05-21-2014, 05:06 PM
1forsnow's Avatar
Quoted: 41 Post(s)
Liked: 54
- M
I used this:
i have to admit, i am a rookie with this patch generator, so i wanted to start with the basics. I used hdmi out, but I have verified its accuracy against a dvdo tpg which calman now has triplet support for.
Once i get more familiar with the patch generator, i will expand my patch options.
1forsnow is offline
Reply Display Calibration
