CalMan 5 Release Notes and Discussion - Page 83 - AVS Forum
 4Likes
post #2461 of 2479 Old 09-03-2014, 12:03 AM
sotti's Avatar
Quoted: 28 Post(s)
Liked: 167
Originally Posted by Andrei_VVB View Post
Yes you got it right.
Well. .simply because calman was on his computer and hcfr on mine. We didn't have the time to do it on both computers.
The reason I ask this, and sorry for continuing the OT is because hcfr when it starts it has the option of selecting the display type(plasma edr) and then a correction matrix. It shouldn't be used together. I was thinking if Calman was using both when profiling maybe this is how I should set HCFR.
CalMAN uses whatever predefined table you have selected when you create the profile. I believe the raw XYZ (no EDR) is an option.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #2462 of 2479 Old 09-05-2014, 03:05 AM
ACappo's Avatar
Liked: 42
Hi Sotti,
is there no logfile that can tell why Calman keeps crashing when I do auto cal with my EEcolor?
ACappo is offline
post #2463 of 2479 Old 09-05-2014, 09:35 AM
lovingdvd's Avatar
Quoted: 42 Post(s)
Liked: 32
Will my i1 D3 Pro meter work accurately with new laser home projectors like the Epson just announced at IFA? Will there be a new option added to CalMAN to select "laser" as the light source (along with the other choices like Plasma, UHP etc)? Thanks.
lovingdvd is online now
post #2464 of 2479 Old 09-05-2014, 09:49 AM
sotti's Avatar
Quoted: 28 Post(s)
Liked: 167
Originally Posted by ACappo View Post
Hi Sotti,
Their might be. Go into the logging settings from the main menu and turn all the logging on.
The log file is then located at c:\programdata\spectracal\[CalMAN Product Name]\Logs
Joel Barsotti
SpectraCal
sotti is offline
post #2465 of 2479 Old 09-06-2014, 03:55 AM
ACappo's Avatar
Liked: 42
I will have a look tonight do I just email them to you or what do I do with them?
ACappo is offline
post #2466 of 2479 Old 09-06-2014, 09:03 AM
PlasmaPZ80U's Avatar
Quoted: 89 Post(s)
Liked: 198
I was looking at the power 2.2 gamma curve for my set with a black offset (not sliding power gamma) and I saw while it does little to 5% stim and up, it does seem to target significantly lower gammas for the steps just above black. Does this mean if I was doing a PC autocal with a LUT or an autocal with a LUT box, gamma would be lowered to match the curve seen in the image below exactly?
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
PlasmaPZ80U is offline
post #2467 of 2479 Old 09-09-2014, 07:29 AM
ACappo's Avatar
Liked: 42
I found the following in the log
[Log 08-21-2014]
000000 = 11:58:57.968 Initialized - Version 5.3.6.1606 - Level 1
000001 = 17:10:12.735 DotNetException - Begin stack trace for exception
000002 = 17:10:12.735 DotNetException - Exception of type 'System.OutOfMemoryException' was thrown.
000003 = 17:10:12.754 DotNetException -
000004 = 17:10:12.755 DotNetException - Top level exception
000005 = 17:10:12.755 DotNetException - at System.StubHelpers.MngdNativeArrayMarshaler.Conver tContentsToManaged(IntPtr pMarshalState, Object& pManagedHome, IntPtr pNativeHome)
000006 = 17:10:12.756 DotNetException - at Cal.CalIO.NaturalNeighborWrapper.Interpolate(Delau nayVertex[] tripletsIn, Int32 pointsIn, DelaunayVertex[] tripletsOut, Int32 pointsOut, Double minSpacing)
000007 = 17:10:12.756 DotNetException - at Cal.CalIO.NaturalNeighborWrapper.RunInterpolationB ucket(DelaunayVertex[] scopedInputVals, List`1 outList, Double minSpacing, ManualResetEvent renderWait, UpdateCount updateMessage, Object interpolateLocker, Int32& pointsCalced)
000008 = 17:10:12.756 DotNetException -
000009 = 17:10:12.757 DotNetException - End stack trace for exception
000010 = 17:10:14.134 DotNetException - Begin stack trace for exception
000011 = 17:10:14.135 DotNetException - Exception of type 'System.OutOfMemoryException' was thrown.
000012 = 17:10:14.135 DotNetException -
000013 = 17:10:14.136 DotNetException - Top level exception
000014 = 17:10:14.136 DotNetException - at System.StubHelpers.MngdNativeArrayMarshaler.Conver tContentsToManaged(IntPtr pMarshalState, Object& pManagedHome, IntPtr pNativeHome)
000015 = 17:10:14.137 DotNetException - at Cal.CalIO.NaturalNeighborWrapper.Interpolate(Delau nayVertex[] tripletsIn, Int32 pointsIn, DelaunayVertex[] tripletsOut, Int32 pointsOut, Double minSpacing)
000016 = 17:10:14.137 DotNetException - at Cal.CalIO.NaturalNeighborWrapper.RunInterpolationB ucket(DelaunayVertex[] scopedInputVals, List`1 outList, Double minSpacing, ManualResetEvent renderWait, UpdateCount updateMessage, Object interpolateLocker, Int32& pointsCalced)
000017 = 17:10:14.138 DotNetException -
000018 = 17:10:14.139 DotNetException - End stack trace for exception
ACappo is offline
post #2468 of 2479 Old 09-09-2014, 08:30 AM
Quoted: 89 Post(s)
Liked: 198
I noticed an annoying issue in the latest build of CalMAN 5 Home Video. It was present in builds for the last few months or so and I did mention it before on the CalMAN forums. The issue is when using pattern change prompts and the read series button if you want to cancel the reads completely before all readings are taken, you can't. Pressing cancel or escape still takes a reading and then moves to the next step and the cycle repeats.
Another issue which doesn't affect calibration but is worth fixing is in the quick analysis workflow, the color comparator shows target black as reddish and actual black as normal black. It's also been there in the last few months of builds though this is the first time I'm reporting it.
post #2469 of 2479 Old 09-09-2014, 08:44 AM
ACappo's Avatar
Liked: 42
additional the following was found in the event viewer
Application: CalMAN App.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.OutOfMemoryException
Stack:
at System.Number.FormatDouble(Double, System.String, System.Globalization.NumberFormatInfo)
at System.Double.ToString(System.String, System.IFormatProvider)
at System.Text.StringBuilder.AppendFormat(System.IFor matProvider, System.String, System.Object[])
at System.String.Format(System.IFormatProvider, System.String, System.Object[])
at System.String.Format(System.String, System.Object[])
at Cal.CalIO.NaturalNeighborWrapper.RunInterpolationB ucket(Cal.CalIO.DelaunayVertex[], System.Collections.Generic.List`1<Cal.CalIO.Delaun ayVertex>, Double, System.Threading.ManualResetEvent, UpdateCount, System.Object, Int32 ByRef)
at Cal.CalIO.NaturalNeighborWrapper+<>c__DisplayClass 6.<Interpolate>b__0()
at System.Threading.ThreadHelper.ThreadStart_Context( System.Object)
at System.Threading.ExecutionContext.RunInternal(Syst em.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threa ding.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threa ding.ExecutionContext, System.Threading.ContextCallback, System.Object)
at System.Threading.ThreadHelper.ThreadStart()
Faulting application name: CalMAN App.exe, version: 5.3.6.1611, time stamp: 0x53f50adf
Faulting module name: KERNELBASE.dll, version: 6.1.7601.18409, time stamp: 0x53159a86
Exception code: 0xe0434352
Fault offset: 0x0000c42d
Faulting process id: 0x1f38
Faulting application start time: 0x01cfbd2ee79b3e58
Faulting application path: C:\Program Files (x86)\SpectraCal\CalMAN 5 Home Theater\CalMAN App.exe
Faulting module path: C:\Windows\syswow64\KERNELBASE.dll
Report Id: a295030d-294d-11e4-ae3f-005056c00008
Since the mention of System.OutOfMemoryException, I would like to add spec of my Laptop
ACappo is offline
post #2470 of 2479 Old 09-09-2014, 09:55 AM
chunon's Avatar
Quoted: 169 Post(s)
Liked: 494
I have seen that purple tinted black target in the color comparator also was wondering what was up with that.
65VT60
55ST60
Sony BDV-F7 3dbluray/soundbar
Calman Enthusiast
Dish Network with Hopper/Super Joey
chunon is offline
post #2471 of 2479 Old 09-09-2014, 01:08 PM
sotti's Avatar
Quoted: 28 Post(s)
Liked: 167
Looks like you're getting a straight out of memory exception.
Are you running virtualized? If so give windows another gig of memory.
Joel Barsotti
SpectraCal
sotti is offline
post #2472 of 2479 Old 09-09-2014, 02:15 PM
ACappo's Avatar
Liked: 42
No it's running on the host with nothing else running.
edit:
Having just seen your reply on your forum I will reply on here.
Any plans of a 64bit version of calman?
I do have design mode available so will try to delete some charts of the workflow.
Thank you for your reply..
ACappo is offline
post #2473 of 2479 Old 09-09-2014, 02:24 PM
ConnecTEDDD's Avatar
Quoted: 93 Post(s)
Liked: 471
CalMAN 5.4.0 build 1632 Open Beta Released @ 09 September 2014
Release Notes
This is an early open beta of CalMAN 5.4.0 which contains support for the new Lumagen 21xx series and the 17x cube sizes.
In adding this support, we needed to make some changes which could potential affect the older Radiance models. We have not seen evidence of that in our internal testing, but please let us know if anything pops up.
Download Link
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, CalPC, ControlCAL
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #2474 of 2479 Old 09-10-2014, 04:58 PM
p5browne's Avatar
Quoted: 93 Post(s)
Liked: 190
Release Notes
Download Link
Thanks - gave up looking there figuring they weren't going to use it anymore.
Only issues I had was that I had to disconnect and reconnect my Radiance VQ's
p5browne is offline
post #2475 of 2479 Old 09-11-2014, 12:01 PM
BobRiff's Avatar
Quoted: 12 Post(s)
Since I am experiencing the same issue, I copied the first part of your post and re-posted it on the SpectraCal Forum yesterday.
Still no response from them as of today, but if I get one I'll post it here on AVS too.
BobRiff is offline
post #2476 of 2479 Old 09-11-2014, 02:03 PM - Thread Starter
WiFi-Spy's Avatar
Quoted: 12 Post(s)
Thanks, I will bring this up in our engineering meeting.
Tyler Pruitt - Technical Liaison at SpectraCal
WiFi-Spy is offline
post #2477 of 2479 Old 09-11-2014, 04:58 PM
BobRiff's Avatar
Quoted: 12 Post(s)
Excellent.
Hope you can duplicate the problem and fix it.
Let me know if you need anything else.
BobRiff is offline
post #2478 of 2479 Old 09-11-2014, 09:33 PM
p5browne's Avatar
Quoted: 93 Post(s)
Liked: 190
Calibrated my wife's LG 55LHX tonight with the new Beta 5.4, and using the iScan Duo for VQ.
Still having the same issue I reported quite a few upgrades back. Namely the AutoCal on the CMS. All Primary and Secondary Colours calibrate OK, except Blue. When it gets to Blue, zips it up, then starts stepping down to almost the Zero line (Hue: 37, Saturation: 59 and Luminance: 31), then it starts stepping it back up to end at the 10 Line (Hue: 34, Saturation: 69, Luminance: 26). I then have to use the DDC Control to bring it back down to where it's best settings ended at Hue: 37.01, Saturation: 58.01 and Luminance: 30. Why is it doing this?
Also have the same Blue issue when doing my wife's bedroom LG 42LH90 and iScan Duo.
p5browne is offline
post #2479 of 2479 Old 09-15-2014, 04:38 PM
cardoski's Avatar
Quoted: 105 Post(s)
Liked: 90
Curious when we might get support for my JVC X500 projector, looking forward to running an auto calibration.
James Reid:D
cardoski is online now
Reply Display Calibration
User Tag List
