CalMan 5 Release Notes and Discussion - Page 85 - AVS Forum | Home Theater Discussions And Reviews
 356Likes
post #2521 of 3811 Old 11-14-2014, 07:40 AM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1056
zoyd is offline
post #2522 of 3811 Old 11-14-2014, 01:29 PM
Quoted: 1559 Post(s)
Liked: 647
Originally Posted by zoyd View Post
reconnecting the eeColor after the other stuff is found works for me.
Thanks for trying to help.
I updated the driver and still wasn't able to connect to the signal generator even with the eeColor unplugged.
Klein K-10A, CR250, i1D3, i1Pro2, Calman Enthusiast, LG 65B6P, Panasonic 65VT50, and a great wife that puts up with all this.:)
JimP is offline
post #2523 of 3811 Old 11-14-2014, 02:25 PM
sotti's Avatar
Quoted: 330 Post(s)
Liked: 332
On the Application Preferences Panel try unticking "Reconnect Hardware on Startup". It seems even the act searching for some hardware may be causing the issue.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #2524 of 3811 Old 11-14-2014, 02:56 PM
Liked: 647
O.K.....I just tried this and it didn't make any difference. After the program is up and running, I attempt to find the Accupel. It acts like its searching but doesn't find it. Like I said in other post, it connect properly in the release (non beta) versions.
I can't help but believe in a few days others will be reporting the same behavior.
Just to be clear, I'm glad to help out with beta versions.
Is there something else I can try?
JimP is offline
post #2525 of 3811 Old 11-14-2014, 04:33 PM
p5browne's Avatar
Quoted: 2983 Post(s)
Liked: 2291
BETA Versio 1800:
http://spectracal.com/forum/viewtopic.php?f=121&t=5492
Notes:
Added support for the madVR TPG (pattern generator). Supported for Enthusiast, Ultimate, and Studio licenses.
Improved gamut retargeting accuracy
Updated interface for the new HP Dreamcolor firmware (v 230)
BT1886 is now selectable in the DDC Controls within CalMAN for the Panasonic AX9xx series displays
Added some fixes for 3D LUT crashes. Also put some code in that we hope will give us some more information for existing crashes.
Added the new Lightning LUT Workflow.
Added CalMAN Eyeglass - SpectraCal's NEW 3D LUT Visulization Tool. Upload your own photos to this independent app to see the before-and
p5browne is offline
post #2526 of 3811 Old 11-17-2014, 06:47 PM
Cozmo85's Avatar
Quoted: 245 Post(s)
Liked: 92
I am probably just missing a checkbox or something... but how the heck do i do a sweep like this?
This is what i have
This is what i want to be able to do, or atleast in 25% increments
Im using calman basic 5.3.6
Basically I cant get saturation sweep or luminance sweep to do anything but black and white.
Cozmo85 is offline
post #2527 of 3811 Old 11-17-2014, 11:48 PM
ConnecTEDDD's Avatar
Quoted: 1392 Post(s)
Liked: 1917
Hi, to Verify 4-Point Saturation using Quick Analysis Workflow:
For 4-Point Saturation / 100% Stimulus Level: Go to Saturation Sweep layout page, open the Workflow and Application Settings Panel -> Workflow Basic Options, change the Stimulus Level to 100 and set Saturation Sweeps to 25% Sweeps. About all other settings of the Layout page it doesn't matter where they are.
For 4-Point Saturation / 75% Stimulus Level: Go to Saturation Sweep layout page, open the Workflow and Application Settings Panel -> Workflow Basic Options, change the Stimulus Level to 75 and set Saturation Sweeps to 25% Sweeps. About all other settings of the Layout page it doesn't matter where they are.
Verify 4-Point Luminance using Quick Analysis Workflow:
For 4-Point Luminance / 100% Stimulus Level: Go to Luminance Sweep layout page, open theWorkflow and Application Settings Panel -> Workflow Basic Options, change the Stimulus Level to 100 and set Gamut Ramp Points to 4-Point 25% Step 25-100%. About all other settings of the Layout page it doesn't matter where they are.
For 4-Point Luminance / 75% Stimulus Level: Go to Luminance Sweep layout page, open the Workflow and Application Settings Panel -> Workflow Basic Options, change the Stimulus Level to 75 and set Gamut Ramp Points to 4-Point 25% Step 25-100%. About all other settings of the Layout page it doesn't matter where they are.
I have posted more instructions for x-Point measurement options here.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #2528 of 3811 Old 11-18-2014, 01:27 PM
Cozmo85's Avatar
Quoted: 245 Post(s)
Liked: 92
What am i missing? New calibration, clicked on saturation sweep. Made the 2 changes. all it shows is grayscale as you see.
Cozmo85 is offline
post #2529 of 3811 Old 11-18-2014, 01:40 PM
Liked: 647
Coz,
Which license do you have?
JimP is offline
post #2530 of 3811 Old 11-18-2014, 01:50 PM
Cozmo85's Avatar
Quoted: 245 Post(s)
Liked: 92
Originally Posted by JimP View Post
Coz,
Calman 5 basic
Cozmo85 is offline
post #2531 of 3811 Old 11-18-2014, 02:09 PM
Liked: 1917
That is very strange. Try to delete the quick analysis workflow and re-install CalMAN.
post #2532 of 3811 Old 11-18-2014, 02:37 PM
Cozmo85's Avatar
Quoted: 245 Post(s)
Liked: 92
Still happens, ill try reloading the OS since its only used for this.
Cozmo85 is offline
post #2533 of 3811 Old 11-18-2014, 02:42 PM
Liked: 1917
Try to clear and re-enter your license code also.
post #2534 of 3811 Old 11-18-2014, 02:58 PM
Cozmo85's Avatar
Quoted: 245 Post(s)
Liked: 92
It happens when i enter in my Calman 5 Basic License . I assumed i could fully use the quick analysis workflow with it.
EDIT: Verified with another computer its my license.
Cozmo85 is offline
post #2535 of 3811 Old 11-18-2014, 07:42 PM
p5browne's Avatar
Liked: 2291
A comparison between licences is on the Spectracal Website.
p5browne is offline
post #2536 of 3811 Old 11-18-2014, 07:47 PM
Cozmo85's Avatar
Quoted: 245 Post(s)
Liked: 92
Yea, basic says it supports advanced quick analysis workflow, the same as control and enthusiast. It doesn't say quick analysis but not this feature of quick analysis.
Cozmo85 is offline
post #2537 of 3811 Old 11-19-2014, 03:13 AM
Liked: 1917
Yes, but it doesn't say that detail about saturation sweeps.
post #2538 of 3811 Old 11-19-2014, 09:31 AM
Cozmo85's Avatar
Quoted: 245 Post(s)
Liked: 92
I spoke with a guy at tech support. He wasn't even aware that Basic did not support Saturation/luminance sweeps until he looked it up when i called. Hes going to call me back to see if there is anything they can do for me. Kind of crappy though that the website does not make any mention of this and i cant return the software.
Cozmo85 is offline
post #2539 of 3811 Old 11-19-2014, 09:39 AM
Liked: 1917
A new workflow has to be created, titled for example as 'Basic Quick Analysis', without saturation/luminance sweep pages for the CalMAN Basic users to prevent this problem in the future for other users, and lock the current Quick Analysis workflow only for Control license or higher.
W3Rman likes this.
post #2540 of 3811 Old 11-19-2014, 10:26 AM
Cozmo85's Avatar
Quoted: 245 Post(s)
Liked: 92
They are gonna figure something out for me. Great company.
ConnecTEDDD likes this.
Cozmo85 is offline
post #2541 of 3811 Old 11-20-2014, 05:48 AM
avsform1's Avatar
Quoted: 51 Post(s)
Liked: 32
Joel
I am having the same issues with the Accupel as well. Nothing seems to allow communication. It is as Jim says, it just act like it is trying to find the unit.. the scrolling bar just continues to scroll and you have to use the Task Manager to get out.
Output from the log at debug level 63 when I select the AccuPel at Com port 4
000038 = 13:41:00.865 Direct Display Control - License 1
000039 = 13:41:02.838 U3 - Read [SpectraCal CalMAN v4] CalMANv5
000040 = 13:41:02.838 U3 - License(s) CalMANv5 LIC(s)
000041 = 13:42:11.621 AccuPel HDG-3000 - Create Object 0c26c4c0
000042 = 13:42:11.621 AccuPel HDG-4000 - Create Object 0c26c4c0
000043 = 13:42:11.621 AccuPel DVG-5000 - Create Object 0c26c4c0
000044 = 13:42:11.622 AccuPel DVG-5000 - Load
000045 = 13:42:11.622 AccuPel DVG-5000 - Startup COM4
000046 = 13:42:11.633 COM4 - Write Size:01 Bytes:01 Data:0D .
000047 = 13:42:11.633 COM4 - Write Size:02 Bytes:02 Data:3F0D ?.
Output from the log at debug level 63 when I select the AccuPel at Auto
000041 = 14:12:41.061 AccuPel HDG-3000 - Create Object 0c08a4c0
000042 = 14:12:41.062 AccuPel HDG-4000 - Create Object 0c08a4c0
000043 = 14:12:41.062 AccuPel DVG-5000 - Create Object 0c08a4c0
000044 = 14:12:41.062 AccuPel DVG-5000 - Load
000045 = 14:12:41.062 AccuPel DVG-5000 - Startup COM0
I confirmed in the setup of the AccuPel that the baud rates were set at 9600. It works fine withe CP and the AccuPel DVG5000 Deskto app.
avsform1 is offline
post #2542 of 3811 Old 11-21-2014, 05:51 AM
Liked: 647
avsforum1
Found that when Calman hangs up trying to connect to the Accupel, that you can unplug the usb cable and it'll stop doing whatever its trying to do. Unlike zoyd, I can't get the accupel to connect regardless of trying the various suggestion previously posted here and on their forum.
I rolled back to built 1752 and the connection issues have all gone away. I can even set it to reconnect devices on startup and it'll do it.
JimP is offline
post #2543 of 3811 Old 11-21-2014, 07:16 AM
zoyd's Avatar
Liked: 1056
There appears to be a general problem with hardware searches in this build. I have started having problems connecting to the AVLab TPG and even my i1display pro. I think the connections are being made but for some reason the dialog hangs and you never get returned to the main UI.
zoyd is offline
post #2544 of 3811 Old 11-22-2014, 05:31 PM
p5browne's Avatar
Liked: 2291
Have had no issues finding my Radiance XE-3D with #1800 . Haven't tried on any of my DVDO iScan Duos yet, nor the Radiance XD-3D.
Calman 5.4.0RC1 now available for Business and Home Theatre:
http://spectracal.com/forum/viewforum.php?f=91
From TestGoddess:
Hi everyone,
Version 5.4.0 RC1 has been put up on the web site. Updated since the last beta are:
- Resolved issue with the Accupel 5000 where baud rate could be set improperly.
- Removed the Auto selection for connecting to serial meters and sources. There have just been too many issues here and more get created every time we add a new serial device.
- Resolved issue that could cause hangs and crashes when creating a 3D LUT using some or a custom gamma formula.
- The CR-100 meter now defaults to Auto for Sync
- Video and PC levels now both match white and black points at 0.0 and 1.0 when using madVR. This should resolve the levels issues people have been seeing.
ASSIMILATE SCRATCH plugin - made a few text changes to make it consistent with the SCRATCH interface.
Ray, the issue you were seeing with the CR-100 meter. The problem is that when you turn Sync to off and then back to On, we are actually using Sync as off until you initialize the meter again. This is a known issue in RC1.
Since we are now out of beta, threads have been opened in the various CalMAN 5 forums. Thanks you to everyone for your time and feedback.
p5browne is offline
post #2545 of 3811 Old 11-27-2014, 12:13 AM
Liked: 1917
CalMAN 5.4.0 RC1 - Build: 1807 Released @ 26 November 2014
Download Links
post #2546 of 3811 Old 11-27-2014, 12:07 PM
avsform1's Avatar
Quoted: 51 Post(s)
Liked: 32
Download Links
Found that this build doesn't connect to a Lumagen Radiance XD and CR100. Anyone else having issues with the Lumagen and CR100?
Confirmed connecting to:
DVDO DUO
Hubble
i1Pro
I1Pro2
C6
AccuPel
Chroma5
VT25
Sharp Elite
RS60/4810
Sencore 403
avsform1 is offline
post #2547 of 3811 Old 11-27-2014, 12:15 PM
Liked: 1917
Added support for the Colorimetry Research CR-100 colorimeter in all license levels of CalMAN for Business.
Do you have business license, right?
post #2548 of 3811 Old 11-28-2014, 01:14 AM
avsform1's Avatar
Quoted: 51 Post(s)
Liked: 32
Yes.
Reloaded the CR drivers and the CR100 is now communicating. Lumagen is still out. Checked 2 different Radience on 2 different laptops.
avsform1 is offline
post #2549 of 3811 Old 11-28-2014, 06:01 PM
seanbryan's Avatar
Quoted: 254 Post(s)
Liked: 162
I'm using Calman 5 version 5.3.6.1622 with the radiance mini (most current software).
I have the enthusiast license. It will perform auto cal for gray scale and gamma, but it won't perform the 3D lut autocal.
When I try to run the 3D LUT I get this message:
This operation is not supported for this device.
Any idea what the issue is?
seanbryan is offline
post #2550 of 3811 Old 11-28-2014, 07:03 PM
Rolls-Royce's Avatar
Quoted: 279 Post(s)
Liked: 452
What version of firmware is in the Mini?
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
Reply Display Calibration
