CalMan 5 Release Notes and Discussion - Page 94 - AVS Forum | Home Theater Discussions And Reviews
 268Likes
post #2791 of 3550 Old 07-02-2015, 02:47 PM
ConnecTEDDD's Avatar
Quoted: 1158 Post(s)
Liked: 1659
CalMAN 5.5.1 Preview - Build: 1964 Released @ 02 July 2015
''With the holiday weekend swiftly approaching, we decided to do a 5.5.1 preview release to the forums. This is basically 5.5.1 final, but is not going up on the web site until next week.''
Release Notes
Added support for OSEE as pattern generator for Ultimate, Studio, and ColorChecker license levels.
Added the OSEE file format for cube calibrations in SpectraCal Cube Generator.
Added a check box on the Source tab for madVR to force it into full screen mode while CalMAN takes readings. The window will be returned to its previous state when readings are done. This requires madVR version 0.88.14 or higher.
Resolved issue where Target lines on deltaE charts might not display once enabled.
Added Rec BT.2020 UHD and D65 P3 Gamuts to Studio Express and Studio Lite licenses.
Resolved an issue where Pattern Auto Advance would apply to an automated pattern generator.
Resolved an issue on the Lumagen Radiance (all models) where CalMAN would not reset the internal 3D LUT at the start of a cube calibration.
Resolved an issue where CalMAN would not recreate a settings file on startup if it were missing. This would cause CalMAN to crash on startup.
Fixed typo on the ColorChecker button on the last layout of the Studio Introduction workflow.
CalMAN for Business Download Link
CalMAN Home Theater Download Link
CalMAN Studio Download Link
Manni01 likes this.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #2792 of 3550 Old 07-02-2015, 09:37 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
Originally Posted by Chase Payne View Post
Is there a way to export a profile then import it? Because I cannot get both meters to show up at once. Calman appears to be doing things that I hate in regards to programming, by adding unnecessary restrictions to things because the developers think that it would be impractical to do so.
You can use multiple meters in CalMAN. One of the goals of CalMAN is to make the software as flexible as possible.
I tried this, apparently it ignores this setting during the 3dLUT calibration. It still errors out, until I raise brightness to have 0 IRE emit light.
You might need to lengthen the exposure to get a valid reading.
Also, eyeglass is really important. I am trying out this software before I buy it. Eyeglass allows me to test how effective a 3dLUT can be to my image; but since it is broken, I can't see how effective the 3dLUT would be.
Eyeglass on works on PCs, so it doesn't make a great tool to validate video paths, unless your HTPC is setup in a very specific manner.
What 3D LUT device are you planning on calibrating?
Not really a great sell if the "trial" doesn't work for me.... to top all that off, they restrict their forums to have an account which is ridiculous.
Colorchecker is a trail and good software to check display accuracy.
The eyeglass bit is a bit of marketing tack-on. Depending on the product you're looking at and your use case if you talk to the sales dept. they can do a better job getting you the best demo of the product.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is online now
post #2793 of 3550 Old 07-02-2015, 09:52 PM
chhanthony's Avatar
Quoted: 54 Post(s)
Liked: 53
Dear Sotti,
Is it possible to correct a general meter by a reference meter with Calman before I start calibrate?
chhanthony is offline
post #2794 of 3550 Old 07-02-2015, 10:40 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
Originally Posted by chhanthony View Post
Dear Sotti,
Yes you can create a profile at any time.
You can connect multiple meters and connect to them at the same time. Or you can always go do another search from the Meters Tab.
Also on the meters tab is a drop down with meter profiles and a new/edit button next to it.
Joel Barsotti
SpectraCal
sotti is online now
post #2795 of 3550 Old 07-04-2015, 08:23 AM
chhanthony's Avatar
Quoted: 54 Post(s)
Liked: 53
Smile
Thanks for your reply!
post #2796 of 3550 Old 07-04-2015, 08:53 AM
lovingdvd's Avatar
Quoted: 2515 Post(s)
Liked: 465
Thank you for the details release notes, as usual. Not all software companies do this, which can be frustrating, so I just wanted to point out that it is very much appreciated.
AVfile likes this.
lovingdvd is offline
post #2797 of 3550 Old 07-04-2015, 09:00 AM
sat4all's Avatar
hi,
is there something similar to argyllcms black output offset in calman 3d cube calibration?
because i'm stuck with bt.1886 curve based on measured black, even when setting custom black level target.
let's say my tv black is 0.0138fL but i want a curve with 0.0069fL black level, setting argyllcms black output offset to 50% give me exactly what i want. how about calman?
sat4all is offline
post #2798 of 3550 Old 07-04-2015, 12:46 PM
PeterLewis's Avatar
Quoted: 133 Post(s)
Liked: 69
Sotti,does calman have a meter profile for the 2014 and 2015 Sony Xbrs (900b,940c) with trilimunos as the generic white led provided from xrite does not work right with these sets?
Sony OLED XBR-65A1E (In my Future )| XBR65X950B|XBR55X900B|2-BR100/Subs|4K X10 Player
Denon - X7200WA|Roku Ultra 4k|PS4
Mirage Omnisat V2 5.1.4 Dolby Atmos set up with SVS PB2000 Sub
PeterLewis is offline
post #2799 of 3550 Old 07-04-2015, 09:46 PM
AVfile's Avatar
Quoted: 254 Post(s)
Liked: 131
Peter, what version of CalMan do you have?
"This one goes to eleven." Martin Logan Descent-i subwoofer
AVfile is offline
post #2800 of 3550 Old 07-05-2015, 10:35 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
They are closer to RGB LED or OLED, but we haven't had those specific displays in our lab.
Joel Barsotti
SpectraCal
sotti is online now
post #2801 of 3550 Old 07-06-2015, 03:40 PM
Liked: 1659
CalMAN 5.5.1 Final - Build: 1964 Released @ 06 July 2015
New Features
Added support for OSEE to function as a pattern generator (CalMAN Ultimate).
Added OSEE file format for cube calibrations within SpectraCal’s Cube Generator (CalMAN Ultimate).
Changes
Changed the default pattern delay setting for Eizo displays.
Added a check box within the source tab for madVR. This button will force the patterns to go into fullscreen mode while CalMAN is taking readings. The window will return to its previous state when the readings are finished. This feature requires madVR version 0.88.14 or higher.
Disabled the "Include Stabilizing Delay for Read All" setting by default.
CalMAN will no longer calculate Contrast Ratio unless both black and white readings have been taken.
Resolved Issues
Resolved issue where deltaE chart target lines might not be displayed once they are enabled.
Resolved issue where Pattern Auto Advance would apply to an automated pattern generator if going from a manual pattern generator to an automatic generator.
Resolved crashes that occurred when CalMAN would not recreate a settings file on startup if it were missing.
Resolved an issue that would occur on the Lumen Radiance (all models). CalMAN would not reset the internal 3D LUT at the start of a cube calibration.
Fixed a typo ColorChecker button on last layout of Studio Introduction workflow.
Download Links
post #2802 of 3550 Old 07-08-2015, 08:37 AM
Liked: 1659
Originally Posted by ConnecTEDDD View Post
CalMAN 5.5.0 - Build: 1952 Released @ 10 June 2015
New Features
Added support for Prisma 3D LUT Box (CalMAN Ultimate/Enthusiast).
Just to correct the above release notes I posted (that later changed by SpectraCAL).
Prisma 3D LUT Box is supported for 3D LUT AutoCAL's via VirtualCube from CalMAN Ultimate and CalMAN Studio (Full) licenses, and not from CalMAN Enthusiast.
Prisma is supported as a Pattern Generator from CalMAN Ultimate, Studio, Professional, Enthusiast, Control, and ColorChecker licenses.
CalMAN is not supporting the direct upload of the generated 3D LUT correction tables, it requires a simple external uploading procedure from the user.
post #2803 of 3550 Old 07-10-2015, 03:20 AM
Andreas21's Avatar
Quoted: 1052 Post(s)
Liked: 687
New Features
Changes
Resolved Issues
Download Links
I can not find the 5.5.1 on the download site, I only find the 5.4.2 I already have...
Regards
Andreas
My Homecinema
Calibration software: Lightspace and Calman. TPG: Murideo Fresco SIX-G
Meters: Klein K-10 A and Jeti 1501. THX II certified.
Andreas21 is offline
post #2804 of 3550 Old 07-10-2015, 04:34 AM
Liked: 1659
Hi Andreas,
Click to that picture from the above link...
and if you don't see:
Download CalMAN Home Video
CalMAN 5.5.1 for Windows*
Build: 1964. Size: 110 MB. Release Notes >
use the refresh button of your web browser to load the updated page.
post #2805 of 3550 Old 07-10-2015, 06:32 AM
p5browne's Avatar
Quoted: 2832 Post(s)
Liked: 2151
Spectracal hadn't changed the ID # when I downloaded. But the file did say 5.5.1 when I did the download.
UN65HU9000 with SEK-3500U - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 up for sale
p5browne is offline
post #2806 of 3550 Old 07-10-2015, 07:06 AM
Andreas21's Avatar
Liked: 687
Hi Andreas,
Thanks, found and downloaded it now.
Regards
Andreas
My Homecinema
post #2807 of 3550 Old 07-14-2015, 02:45 PM
Liked: 1659
CalMAN 5.5.2 Open Beta - Build: 1966 Released @ 14 July 2015
Release Notes posted from SpectraCAL's Support Team
''So, we've got a new build that makes changes to the Radiance. Specifically we've changed how we connect and how we perform resets to 3D LUTs. This should speed up performance in these areas.
I've worked on this with a Radiance XD, 20xx, and 21xx series models and everything looks good, but we'd really like to get feedback from the field. Let us know how its going for you, if you have any issues, etc.''
Download Links
post #2808 of 3550 Old 07-14-2015, 07:15 PM
stash64's Avatar
Quoted: 221 Post(s)
Liked: 78
I'm debating whether to move to Windows 10 now or wait awhile. Is CalMAN currently Windows 10 ready ?
Sean
stash64 is offline
post #2809 of 3550 Old 07-14-2015, 10:32 PM
Kilgore's Avatar
Quoted: 727 Post(s)
Liked: 435
Download Links
I'm assuming this should also work with the Radiance Mini3D, yes?
Kilgore is offline
post #2810 of 3550 Old 07-15-2015, 12:45 AM
Liked: 1659
Yes, but not expect noticed difference since the 3D LUT table size is small and it takes a lot of faster to reset it vs. the 20xx/21xx models.
post #2811 of 3550 Old 07-15-2015, 08:24 AM
p5browne's Avatar
Liked: 2151
I'm recommending to my clients to Reserve it that you're on the list. Then wait several months and checkout whether the fallout is + or - .
Myself, and most likely Spectracal have had Windows 10 Betas for awhile, to test the Calman program with, and to check out.
For myself, glad to see in the latest Beta, 2 of my 3 suggestions are now in the latest versions!.
Last suggestion, just passed on to MS, recommended they do something with the eventvwr.exe program that the fraudsters are using to suck millions, if not billions of $s out of computer owners. (Or as I call it, `The Eventvwr Scam!' )
p5browne is offline
post #2812 of 3550 Old 07-15-2015, 09:36 AM
sjschaff's Avatar
Quoted: 65 Post(s)
Liked: 25
Os x
Certainly would be better if CalMan ran on OS X, rather than the soon to be DOA of OS's. But I suppose Spectracal has invested too much to date to get out from under Windoze.
JVC RS500 - Stewart Firehawk - Lumagen Radiance Pro - Anthem D2V - Revel Salon speakers - SV Sound SB13 Ultra sub - Various sources
sjschaff is offline
post #2813 of 3550 Old 07-15-2015, 10:30 AM
PlasmaPZ80U's Avatar
Quoted: 1973 Post(s)
Liked: 566
What's a good way to profile my c6 against my i1pro spectro before running the automated calibration for my laptop display? Using CalMAN 5 Enthusiast.
PlasmaPZ80U is offline
post #2814 of 3550 Old 07-15-2015, 10:45 AM
stash64's Avatar
Quoted: 221 Post(s)
Liked: 78
Boo
Sean
stash64 is offline
post #2815 of 3550 Old 07-15-2015, 11:26 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
From the main menu you can open the meter profiling tool.
You can also access the tool from the meters drop down.
Joel Barsotti
SpectraCal
sotti is online now
post #2816 of 3550 Old 07-15-2015, 11:58 AM
Liked: 566
Will the pattern display automatically? And can I use a full field and single measure approach?
post #2817 of 3550 Old 07-15-2015, 12:10 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
All of the standard pattern generator settings and automation is used, so you can configure it how ever you like for your situation.
Joel Barsotti
SpectraCal
sotti is online now
post #2818 of 3550 Old 07-15-2015, 03:21 PM
Liked: 566
What's the difference between expand video to pc levels and expand built in patterns to pc levels? The former is unchecked by default and the latter is checked by default.
post #2819 of 3550 Old 07-15-2015, 04:25 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
What are you using for a pattern source?
The functionality expands the Video range patterns from 16-235 to 0-255 with the expectation that something else down the line will re-compress them back to 16-235. These checkboxes have no effect in PC range.
Joel Barsotti
SpectraCal
sotti is online now
post #2820 of 3550 Old 07-15-2015, 07:16 PM
oliverlim's Avatar
Quoted: 64 Post(s)
After a profile is done, is there a way to see what difference there was between the 2 meters at the RGBW points?
oliverlim is offline
Reply Display Calibration
