CalMan 5 Release Notes and Discussion - Page 97 - AVS Forum | Home Theater Discussions And Reviews
 283Likes
post #2881 of 3572 Old 08-17-2015, 06:27 AM
chunon's Avatar
Quoted: 2203 Post(s)
Liked: 1908
Originally Posted by sotti View Post
The one file with your meter's serial number lives in the previously discussed location.
That file contains any and all profiles generated.
When CalMAN loads it read in any profile data in that file.
Ahhh ! Light bulb just went on
chunon is online now
post #2882 of 3572 Old 08-17-2015, 06:44 AM
chunon's Avatar
Liked: 1908
Sotti,
Unrelated question, when Chad calibrated my set Saturday we could not get satisfactory greyscale and gamma after the lut. It would look great after the autocal, but remeasuring after the lut the greyscale was not satisfactory. Is that a quirk of the lumagen ?
post #2883 of 3572 Old 08-17-2015, 02:15 PM
p5browne's Avatar
Quoted: 2849 Post(s)
Liked: 2169
Sotti,
What set were you calibrating?
You may want to put it into your signature, like you see on mine, and then we know what you're referring to.
UN65HU9000 with SEK-3500U - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 up for sale
p5browne is offline
post #2884 of 3572 Old 08-17-2015, 02:23 PM
chunon's Avatar
Liked: 1908
Js9500
It was a generic question Ive seen this behavior on both a plasma and an lcd. Its specific to Calman and the lumagen not the display.
post #2885 of 3572 Old 08-18-2015, 08:44 AM
Quoted: 1437 Post(s)
Liked: 599
Yesterday, Sillysally posted a 2500 point patch set in .csv file format.
Where does this need to go in Windows 7?
JimP is offline
post #2886 of 3572 Old 08-18-2015, 09:25 AM
zoyd's Avatar
Quoted: 1316 Post(s)
Liked: 1055
CalMan does not support user generated patch sets for 3dLUT calibration. It does support user generated measurements of arbitrary patch sets in XML format.
zoyd is offline
post #2887 of 3572 Old 08-18-2015, 09:38 AM
Liked: 599
Is that the same as saying that it could be used for the colorchecker?
If so, then which directory?
JimP is offline
post #2888 of 3572 Old 08-18-2015, 09:42 AM
Quoted: 1467 Post(s)
Liked: 994
Js9500
What was specifically wrong with the grey scale?
John
LG 55OLEDE6P
55HU9000 / SEK-3500
Marantz 7009
Ohm Walsh Speakers
ISF Level II Certified
jrref is offline
post #2889 of 3572 Old 08-18-2015, 09:58 AM
zoyd's Avatar
Liked: 1055
yes
Custom color sets are read from the XML formatted (not csv) file CustomColorSets.ccfx in /ProgramData/SpectraCal/CalMAN <version>/Config
zoyd is offline
post #2890 of 3572 Old 08-18-2015, 11:22 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
We ship a patchset editor with the product.
But if you want to do something that large you'll probably want write a script to convert it into our XML format.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #2891 of 3572 Old 08-18-2015, 11:24 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
Js9500
Which lumagen.
Joel Barsotti
SpectraCal
sotti is offline
post #2892 of 3572 Old 08-18-2015, 11:31 AM
chunon's Avatar
Liked: 1908
Sotti,
Sorry Lumagen 2143, my sig doesn't always show up for some reason.
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
post #2893 of 3572 Old 08-18-2015, 02:09 PM
sillysally's Avatar
Quoted: 844 Post(s)
Liked: 857
Sorry, the file I originally posted was for just Lightspace .cvs.
I have changed the file to .ccfx file that should work in Calman.
As I have said I don't use Calman for my profiles/3DLUT's, so I can say how well Calman will work with the updated .ccfx file.
Also that file is a alternating low stimulus to high stimulus color patch file and probably should be used with "APL Linear" set at 25%. I posted that file to let folks try that use a I1pro display (D3) meter for profiling/3DLUT. I don't know if this will help but it may be worth a try.
Calibration Anomaly on Newest of the New LG OLED!
ss
"Don't worry be happy"
sillysally is offline
post #2894 of 3572 Old 08-19-2015, 01:45 AM
mac1guru's Avatar
Quoted: 75 Post(s)
It to bad that you cant upgrade home video Eutiasth to the pro version of Calman. 😯
Skickat från min SM-G900F via Tapatalk
SpectraCal CalMan 5.5.2 Enthusiast @ Windows 10
i1Display Pro
MobileForge @ Amazon Fire TV stick & AppleTV 3
DVE Bluray / AVSHD709 / Ted's LightSpace CMS Calibration Disk
Samsung UE48H6275 (XXE) European model)
Playstation 4 / AppleTV 3 / iPad Air 2 (128GB) / iPhone 6 (16GB)
mac1guru is offline
post #2895 of 3572 Old 08-19-2015, 04:14 AM
Liked: 599
Spectracal is very good about customer service and would work with you to get the version upgrade that you want. I see what you mean about the current upgrade page but that looks more like an oversight. http://calman.spectracal.com/store/c10/Upgrades.html
I'd recommend contacting them either by phone or through their website.
Just curious, which features are you wanting that you don't have with enthusiast license?
JimP is offline
post #2896 of 3572 Old 09-04-2015, 12:35 PM
p5browne's Avatar
Liked: 2169
New Calman Beta 5.6.0 Build # 2136
http://spectracal.com/forum/viewtopic.php?f=130&t=5791
Business - http://files.spectracal.com/downloads/f ... 0902.3.exe
Home Theater - http://files.spectracal.com/downloads/f ... 0902.3.exe
Studio - http://files.spectracal.com/downloads/f ... 0902.3.exe
Notes
Optimized AutoCube algorithms for grayscale performance in general as well as a focus near black.
For those of us performing cube calibrations, we really want to get your feedback on this.
Added Support for the Astro VG series pattern generators
(Ultimate, Professional, Expert, Studio, and ColorChecker)
Added madVR support to the Professional license level (Pattern Generator and Display)
Added new FSI models to the drop down box for the FSI Display
Prisma has been added as a drop down selection for format for the SpectraCal Cube Generator
Qinc Prisma has been added as its own entry as a display. This creates a LUT file that can be uploaded to the device using the Prisma's interface.
(Ultimate, Professional, Studio, Enthusiast)
Resolved an issue where the Load LUT File button on the 3D LUT DDC Controls screen was not working.
Resolved an issue that would cause hangs/crashes when performing a 3D LUT calibration in PC Levels.
Removed Manual DVDs. Pattern Change Prompts under the default Source option still function as usual.
Removed support for all IR controlled devices except for the SpectraCal DPG line.
p5browne is offline
post #2897 of 3572 Old 09-04-2015, 12:41 PM
erkq's Avatar
Quoted: 627 Post(s)
Liked: 447
What does this mean?
"as well as a focus near black"
Clearly the calibration has no effect on focus. Do you mean the calibration process focuses especially on the near black portion of the cube to enhance shadow detail? This would be nice.
erkq is offline
post #2898 of 3572 Old 09-04-2015, 12:59 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 332
It's a bit of an algorithm change to help transition more smoothly to black.
Joel Barsotti
SpectraCal
sotti is offline
post #2899 of 3572 Old 09-04-2015, 01:00 PM
ConnecTEDDD's Avatar
Quoted: 1217 Post(s)
Liked: 1721
Hi, they have improved the algorithm to calculate a correction with better shadow detail performance. The users who will test this have to confirm that they see improvement at this area also.
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #2900 of 3572 Old 09-04-2015, 01:35 PM
erkq's Avatar
Quoted: 627 Post(s)
Liked: 447
This is what I was hoping it meant. Thanks guys!
erkq is offline
post #2901 of 3572 Old 09-08-2015, 03:37 AM
mmwwmm's Avatar
Quoted: 66 Post(s)
Liked: 37
Sorry to post such a dumb question but where is the option to reset all settings to factory default in Calman 5? I can't found it.
mmwwmm is offline
post #2902 of 3572 Old 09-08-2015, 03:46 AM
Liked: 1721
Hi, You can reset your settings if you delete the settings file from: C:\Users\YourUserName\Documents\SpectraCal\CalMAN 5 Home Theater\Settings.ccfx
A new setting file will be automatically created by CalMAN when you will reinstall it.
If you are familiar with regitry settings modification, use regedit and remove the following registry key: HKEY_CURRENT_USER\SOFTWARE\SpectraCal, Inc\CalMAN 5 Home Theater
post #2903 of 3572 Old 09-08-2015, 04:09 AM
mmwwmm's Avatar
Quoted: 66 Post(s)
Liked: 37
Thanks!! Much appreciated.
mmwwmm is offline
post #2904 of 3572 Old 09-08-2015, 02:33 PM
Liked: 1721
CalMAN 5.6.0 Open Beta - Build: 2143 Released @ 09 September 2015
Release Notes
Added support for the Murideo pattern generator to the Ultimate, Professional, Expert, Studio, and ColorChecker license levels.
Resolved various errors and crashes when creating a 3D LUT.
Added 25% Only and 50% Only as options for Saturation sweeps.
Added 2pt Grayscale and Dynamic Range layouts to the Quick Analysis workflows.
Added the ability to show 8, 10, or 12 bit levels on the slider bar
Note: For those of you who have been seeing crashes or having issues with 3D LUTs, give it a run on this build and let us know how it goes.
Download Links
Manni01 likes this.
post #2905 of 3572 Old 09-10-2015, 08:46 AM
Wizziwig's Avatar
Quoted: 1012 Post(s)
Liked: 671
Anyone know where to download older versions of Calman 5 Home? Oldest I see on their website is 5.2.3. I need a version before they removed 21-point grayscale autocal on older JVC projectors like RS40. For some reason all the recent versions only have 11-point. Thanks.
Wizziwig is offline
post #2906 of 3572 Old 09-10-2015, 08:53 AM
Liked: 1721
What version you want? I have them all to my hard disk. Find the version you want and send me PM. your email to upload it.
post #2907 of 3572 Old 09-22-2015, 11:11 AM
Liked: 1721
CalMAN 5.6.0 Open Beta - Build: 2158 Released @ 22 September 2015
Release Notes
Updated the Quick Analysis workflow to include 2pt Grayscale and Dynamic Range layouts.
Major updates to the HT Enthusiast and SI Professional workflows.
Minor tweaks to the SI Basic and SI Advanced workflows.
Added RGB Triplet support for the QD 804 pattern generator.
Added Drift Compensation*
*The beginnings of Drift Compensation have been in since the first 5.6.0 beta and we've been working on improving the algorithms since.
CalMAN's iRP calibration takes additional measurements to track the drift of the display over the time it is under testing. This allows the measurement data to be corrected for both luminance and chromaticity to produce a final 3D LUT with a higher level of accuracy. This is especially valuable on displays that exhibit image retention.
Download Links
Manni01 likes this.
post #2908 of 3572 Old 09-22-2015, 11:31 AM
lovingdvd's Avatar
Quoted: 2686 Post(s)
Liked: 558
Release Notes
Download Links
Is there an option to turn the drift compensation feature off?
lovingdvd is offline
post #2909 of 3572 Old 09-22-2015, 11:58 AM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
sorry to hear that.
I thought only products I have were being phased out.
Loving D65
CalWldLif is offline
post #2910 of 3572 Old 09-22-2015, 12:05 PM
W3Rman's Avatar
Quoted: 158 Post(s)
Liked: 131
Release Notes
I would like to know how this feature differs in the implied beneficial way from other calibration software that already generates corrections based on captured xyY data.
IOW,
if a display drifts over time and calibration software performs for example a 5000 point profile on PDP this will cause panel drift and all software makes decisions for corrections already based on this drift. So, then is this a fancy term for "improving engine math calculations", or is there completely new additional feature to enable/disable based specific panels and conditions.
good question
#1 Calibration Disk / Best Support: Ted's LightSpace CMS Calibration Disk
#1 Calibration Software / Best Support: LightSpace CMS - Calibration Comparison
W3Rman is offline
Reply Display Calibration
