i1pro vs i1pro2????? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
post #61 of 66 Old 10-28-2012, 07:43 PM
<^..^>Smokey Joe's Avatar
Quoted: 75 Post(s)
Liked: 101
IMHO, if you don't have a i1pro and want the spectro design, the new (G2 or rev E) i1pro version is a better unit through the various advantages that CalMAN can take advantage of. However if you already own the i1pro D, unless the dark reading thing is a big problem for you, I'd spend money on a C6 or similar unit for the advantages of the two devices combined.
I bought a Jeti1211BT instead, bit of a step in another direction
Masterpiece Calibration Ltd
Lincolnvilleshire
New Zealand
<^..^>Smokey Joe is offline
post #62 of 66 Old 10-29-2012, 04:58 AM
p5browne's Avatar
Quoted: 3104 Post(s)
Liked: 2418
Originally Posted by sotti View Post
It's an offer for people who want to upgrade, if you don't want to that's okay.
Just spoofing with you. Hence the part about the wife at the end. I deleted my posting, but you caught me!
I did like the part about the extended Dark Reading times, but had forgotten about the Low Level Readings. Will continue with my current setup. (i1Pro profiled to the C6)
UN65HU9000 with SEK-3500U in JS Mod Mode + Input at 1080P 60HZ 444. 4K separate input- Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 (On floor and up for sale) / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 still up for sale
p5browne is offline
post #63 of 66 Old 10-30-2012, 06:57 AM
Matthieu's Avatar
I switche from i1Pro to the i1Pro G2 and it is a relieve not to do the initialization every 10 minutes.
This newer device is so much more proffesional looking too, which also helps to keep the temperature down on the device itself.
My LLH in Calman is set to defau.lt and it is on 10 cd/m2, and than does 20 messurements below it.
Is this what the i1Pro G2 needs to be set on, or is this a default setting for all meters, when you enable LLH?
I only have the i1Pro G2 so I cannot check this..
Low light messuring is indeed taking it's time.
Not sure how calibrating goes with 2 meters, for example the C6 I read about here.
When do you switch meters?
When you do Greyscale, or only when you messure below the 50 IRE settings, than you switch?
To me it seems like a dragon, to switch meters all the time.
Also, I have to read myself in, to what Colorymeter is best to use.
But if it give that much better result,...
Will my display's look so much better?
Matthieu is offline
post #64 of 66 Old 10-30-2012, 07:29 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 334
It is the default for both the i1Pro and i1Pro 2. Other meters are different and therefore have different defaults.
sotti is offline
post #65 of 66 Old 10-30-2012, 07:41 AM
Matthieu's Avatar
In another forum, someone wrote to put LLH off till the i1Pro give an error himself.
Maybe this make a faster calibration and posible wont give an error if the display is bright enough, but I think that will give wrong readings at a certain point and no ISF display result.
Or is the i1Pro G2, or CalMAN 5 that good?
Any experience with that.
Matthieu is offline
post #66 of 66 Old 10-30-2012, 08:38 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 334
We ship the defaults because we think they are the best settings.
We expose the settings so you can tweak them if you want to.
sotti is offline
Reply Display Calibration
