Older display grayscale controls in service menu. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-16-2012, 12:00 PM - Thread Starter
avsform1's Avatar
Quoted: 29 Post(s)
Liked: 30
I've been into the calibration thing for awhile and have calibrated newer sets for family members. The newer sets pretty much have everything that it is needed to calibrate the unit outside of the service menu, but the older sets have these controls in the service menu. However within the service menu these values are not decimal basee but appear to be hex based (Panasonic for example). So my question is when calibrating the grayscale to we convert decimal to hex for the value?
avsform1 is offline
post #2 of 4 Old 08-16-2012, 12:28 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Write down the starting values and then increase or decrease the value until it is correct just like any 2 point.. why would it matter what the numbers are? I have done a bunch of old CRTs and the values on screen are of no consequence to the outcome.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 4 Old 08-16-2012, 12:39 PM - Thread Starter
avsform1's Avatar
Quoted: 29 Post(s)
Liked: 30
It matters if the SM interprets the values as hex. ie if a value is FF how do you increase FF by 1?
avsform1 is offline
post #4 of 4 Old 08-16-2012, 01:23 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Every service menu I have worked in or read instructions on how to enter and navigate has an up and down entry on the remote to increase and decrease the values but maybe some allow direct entry of data.. . In which case use the calculator in windows, choose view, scientific and click the hex radio button. Now add or subtract ... I.E. FF + 1 = 100 FF - 1 - FE..
Doug
Reply Display Calibration
