Do I need to adjust video settings on my receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-20-2012, 08:41 AM - Thread Starter
yaomizzle's Avatar
Liked: 27
I have a Yamaha rx-z7 with the ABT 2010 VP it has a few options for video settings do I need to dial these in or are my calibrated settings on TV good enough
Sent from my GT-P7510 using Tapatalk 2
yaomizzle is offline
post #2 of 3 Old 08-20-2012, 09:24 AM
kkpro's Avatar
Quoted: 138 Post(s)
Liked: 76
I would only use those setting if your sources have different levels. For example, your main sourc component may be a blu-ray player and you calibrate your tv using that source. Now, you switch to a cable/sat box and it has different brightness and contrast, there is where you would change the settings on your receiver so that both sources would look the same on the display. You may also use those controls if you have limited/coarse controls on your display.
kkpro is offline
post #3 of 3 Old 08-20-2012, 11:49 AM - Thread Starter
yaomizzle's Avatar
Liked: 27
I have a 50g20 Panasonic so I think all is well...I just always wonder if I could get anything better out of it
Reply Display Calibration
