Can I use an EyeOne Display LT using Color HCFR software on a computer running Windows 7 Home Premium 64-bit? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 09-02-2012, 06:58 PM - Thread Starter
dave999z's Avatar
I keep getting an "incorrect driver" error when I try to run it. I know the computer can communicate with the EyeOne because it works with the Xrite software.
I need it to work with Color HCFR though. I've read that it's a problem running Color HCFR on Windows 7 64-bit. But I can't find any solution. Is this true that Color HCFR doesn't work at all on Windows 7 64-bit? (I mean, it will launch, but it won't find any meters.)
Anyone know of any other free calibration software I could use with my EyeOne?
dave999z is offline
post #2 of 14 Old 09-02-2012, 07:12 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 188
I've not heard of any problems with HCFR and Win 7 64 bit. I use it with no trouble.
Have you copied the file EyeOne.dll to the ColorHCFR folder?
Larry
LarryInRI is offline
post #3 of 14 Old 09-02-2012, 07:15 PM - Thread Starter
dave999z's Avatar
Where would that eye one.dll file be?
and thanks for the quick reply!
dave999z is offline
post #4 of 14 Old 09-02-2012, 07:31 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 188
It's in the folder with the x-rite files. (It maybe in a folder named... )
Never mind, I've attached a copy. Just download it and rename txt to dll.
EyeOne.txt 3164k .txt file
Larry
post #5 of 14 Old 09-02-2012, 07:37 PM - Thread Starter
dave999z's Avatar
OK, yes I copied the "EyeOne.dll" and the "EyeOneIO.dll" files from the i1 Match folder into the Color HCFR folder. But I still go to file-->new, choose DVD manual for the generator, click next, and get an error that says "Incorrect driver - Starting communications with the meter failed with severe error. Argyll Error".
Very frustrated. I bought this stupid netbook just so I could do this. I guess that's the price of relying on shareware.
dave999z is offline
post #6 of 14 Old 09-02-2012, 07:52 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 188
Oh, you have the new under-development version of HCFR. You need to use the Argyll drivers for that.
Read this thread: http://www.avsforum.com/t/1393853/fork-of-hcfr-started-whats-needed. But that's probably where you downloaded HCFR to start with.smile.gif If you have one of the newer meters, you'll have to read the thread to find out how to change the drivers. Or read here: http://sourceforge.net/p/hcfr/wiki/Home/
If you have an older meter, install this version: http://www.homecinema-fr.com/colorimetre/release/Setup_v2_1_0.exe .
Larry
post #7 of 14 Old 09-02-2012, 08:01 PM - Thread Starter
dave999z's Avatar
You RULE!!!
THANK YOU! The older software version seems to be detecting the sensor and working now.
I really appreciate your help.
Cheers!
dave999z is offline
post #8 of 14 Old 09-03-2012, 03:44 PM - Thread Starter
dave999z's Avatar
So, my EyeOne Display LT is three years old, and it seems the color has drifted quite far. It's pretty much unusable.
If I get an i1Pro, will it work with this older version 2.1.0 of Color HCFR? (i.e., is it supported?) If not, I'd have to run the newer version of Color HCFR, and that's where I ran into problems with it not finding the meter.
dave999z is offline
post #9 of 14 Old 09-03-2012, 11:10 PM
Killerbeenl's Avatar
I1pro works in old version and you can make an offset matrix to correct the LT.
More info about this:
http://www.avsforum.com/t/1394567/documentation-for-offset-profiling-creation
Sometimes you are 1 click away from pulling your hair out and bang your head against the wall
Killerbeenl is online now
post #10 of 14 Old 09-04-2012, 07:27 AM - Thread Starter
dave999z's Avatar
Thanks. And just to be clear, I'm talking about this version of the i1 Pro:
http://www.amazon.com/Xrite-EODIS3-i1Display-Pro/dp/B0055MBQOW/ref=sr_1_1?ie=UTF8&qid=1346768633&sr=8-1&keywords=i1+pro
That will work with the older software version?
Interesting that I can create a matrix to correct the LT. But it's kind of a catch-22. Once I buy the i1 pro, I won't need the LT (it'll probably sit in a drawer forever -- don't think I can get much money selling an LT that has drifted).
dave999z is offline
post #11 of 14 Old 09-04-2012, 08:43 AM
djams's Avatar
^ that is an i1 display pro (colorimeter), not an i1 pro (spectro). The i1 display pro will not work with HCFR 2.1 - the i1 pro will.
X-rite's main goal with product branding seems to be to confuse new customers... wink.gif
djams is offline
post #12 of 14 Old 09-04-2012, 08:56 AM - Thread Starter
dave999z's Avatar
Thanks. Glad I asked. So will the i1 display pro work with the newer version of HCFR? That version ran on my Windows 7 machine, but it wouldn't recognize the LT. Maybe it would recognize the i1 display pro though?
Is the i1 display pro considered a decent colorimeter? Is it any better than the colormunki? Is there any other good choice for a low cost colorimeter to work with HCFR?
dave999z is offline
post #13 of 14 Old 09-04-2012, 01:20 PM
LarryInRI's Avatar
Quoted: 18 Post(s)
Liked: 188
Changing the driver in Win7 for the new HCFR to make the i1 D2 (LT) work is a trivial matter.
Larry
post #14 of 14 Old 10-09-2012, 10:04 AM
daMaster's Avatar
That's the Eye One Display 3 Pro and will definitely work with the latest HCFR 3.0.4.0 if you install the Argyll drivers that come with HCFR 3.0.4.0. I don't think the Eye One Display 3 Pro will work with the older HCFR 2.1 given it's age.
I also have an Eye One Display Lt that I was always using with HCFR 2.1. I just tried it with HCFR 3.0.4.0 and get different measurements than what I'm getting in HCFR 2.1. Strange...
daMaster is offline
Reply Display Calibration
