Radiance 3D LUT (5x5x5 Cube) Calibration with CalMAN 5 - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #811 of 834 Old 08-13-2014, 02:06 AM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 1567 Post(s)
Liked: 2013
Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 072214 Firmware Update
Release Notes
A bugfix for CUE filtering from 072114 firmware when upscaling.
Improved the CUE filter menu, filter did not immediately turn on when enabled (Update time ~9 minutes @57k)
Download Link
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #812 of 834 Old 08-15-2014, 12:14 PM
p5browne's Avatar
Quoted: 3068 Post(s)
Liked: 2391
Calman Update
http://color.spectracal.com/downloads
August 15, 2014
Version 5.3.6 Build # 1606 - on hold - wait for repair update. 5.3.6a Build #1611 now available.
Resolved issue with pattern delays and Client 3
Resolve issue where the Brightness DDC control wasn't displaying for the HP DreamColor in the Monitor - Direct workflow.
The modified dE2000 is an option now for AutoCal
p5browne is online now
post #813 of 834 Old 08-20-2014, 04:39 PM - Thread Starter
Liked: 2013
CalMAN 5.3.6a Build: 1611 Released @ 21 August 2014
Resolved Issues
Resolved issue where data from previously saved data files was not restoring properly for a Color Checker run.
Resolved issue where after changing a LUT selection, CalMAN would fail read a 3D LUT from a device.
Resolved issue which would cause crashes in AutoCal and DDC grayscale controls.
Download Links:
Download CalMAN 5 for Business / ColorChecker 5.3.6a (Build 1611)
Download CalMAN 5 for Home Video Calibration 5.3.6a (Build 1611)
post #814 of 834 Old 08-25-2014, 09:29 PM
p5browne's Avatar
Liked: 2391
21XX Series FW Update
Production 080114- Fix for a configuration saving issue that didn't allow the "undo save" to work properly. Also, another fix for working with the configuration utility. Note the configuration utility was also just updated to version 1.8. as the earlier version was not downloading the CMS portion of the configuration to save on a PC for 21XX units. If you backed up your 21xx configuration earlier you should back it up again after performing this update and downloading the new 1.8 version of the configuration utility. There were some improvements to the config utility as well.
Update time ~3 minutes @57k from previous firmware
http://www.lumagen.com/testindex.php?module=updates
post #815 of 834 Old 08-26-2014, 03:15 PM - Thread Starter
Liked: 2013
CalMAN 5.3.6b Build: 1622 Released @ 26 August 2014
Release Notes
Performance updates to the UI.
Added feature that allows users to view information on their meter's NIST certificate from within CalMAN. NIST certificates are only available on meters that have been enhanced or certified by SpectraCal. The back end for this feature is not yet in place, but this version of CalMAN will work with the feature once it is.
Added new dE2000/JNDab formula that emphasizes luminance error, particularly at the low end.
Download Links:
Download CalMAN 5 for Business / ColorChecker 5.3.6b (Build 1622)
Download CalMAN 5 for Home Video Calibration 5.3.6b (Build 1622)
post #816 of 834 Old 08-29-2014, 05:25 PM
p5browne's Avatar
Liked: 2391
New News and FW Updates:
21XX:
Production 081514- Added 17x17x17 CMS along with corresponding menu and rs232 command options. Added option to enable Darbee enhancement for just 2d or just 3d sources. If you back up your setup to a PC Be sure to download the new configuration (v1.8) utility from the utilities page to use with your Radiance 21xx.
Update time ~15 minutes @57k from previous firmware
20XX:
Production 081514- Added option to enable Darbee enhancement for just 2d or just 3d sources.
Older Models:
Production 081514- Added faster serial port IO to enable faster operation with calibration software.
New Utilities Version 1.8:
http://www.lumagen.com/testindex.php?module=utilities
These FW updates have made my latest calibration the Best Ever!
August 31: Radiance 20XX
Production 081614- (081514 had a previously fixed bug in it and was replaced) Added option to enable Darbee enhancement for just 2d or just 3d sources. Added faster serial port IO to enable faster operation with calibration software. Update time ~15 minutes @57k from previous firmware
Sept 2, 2014: Radiance 20XX
http://www.lumagen.com/testindex.php...ce20XX_updates
Radiance 20XX Owners: Production 081714- The audio configuration menu had lost the spdif/coax selectable options from 050114-081614 in 20xx models only.
Sept 3, 2014: Radiance 21XX
Production 081814- Location values displayed for 17x17x17 gamut adjustment via the menu were off by 1 for a few locations due to a rounding error. (also in 9x9x9)
http://www.lumagen.com/testindex.php...ce21XX_updates
Radiance 20XX:
Production 081814- Location values displayed for 9x9x9 gamut adjustment via the menu were off by 1 for a couple locations due to a rounding error.
Sept 8, 2014:
Radiance 21XX:
Production 082014- Bugfix for configuring analog composite inputs (2143, 2144 only). The menu would show settings being made for these inputs without corresponding changes to the picture. Update time ~3 minutes @57k from previous firmware
Sept 19, 2014:
Radiance 21XX:
Production 091014- Fix for a bug which under some circumstance could give strange colors in grayscale intermittently.
Use above URL for 21XX
post #817 of 834 Old 09-22-2014, 11:29 PM - Thread Starter
Liked: 2013
Lumagen Radiance (XE/XE+/XE3D/XE/XE+/XE3D/Mini-3D/XD/XD3D) New 091114 Firmware Update
Release Notes
Fix for a bug which under rare circumstances could give strange colors in grayscale that a user may have remedied by turning off and back on. (Update time ~9 minutes @57k)
Download Link
post #818 of 834 Old 09-23-2014, 06:13 AM
p5browne's Avatar
Liked: 2391
Expanded view:
Radiance 21XX:
Production 091114- Fix for an issue that changes a 17x17x17 CMS to an 8 point CMS when copying from a CMS location to another.
Radiance 20XX:
Production 091114- Fix for a bug which under rare circumstances could give strange colors in grayscale that a user may have remedied by turning off and back on.
Radiance XE/XS/Mini/XD
Production 091114- Fix for a bug which under rare circumstances could give strange colors in grayscale.
Update time ~9 minutes @57k from previous firmware
Sept 24, 2014:
Radiance 20XX
Production 091214- Fix for an issue in 091114 having problems with 480/576p reinterlacing giving blank screen or green/pink colors. Fix for an issue with the test pattern color when editing the color gamut via the menu.
October 10, 2014: Radiance 20XX and 21XX
Production 100514- Fix for not correctly handling Pal (576i) video on analog inputs and not being able to power up on an analog input. This update is only helpful for units with analog inputs (2124/2144). Update time ~3 minutes @57k from previous firmware
post #819 of 834 Old 10-22-2014, 09:24 PM
p5browne's Avatar
Liked: 2391
New Utility Software
Radiance Configuration utility Version 1.8 for the XD/XE/XS/Mini/20XX/21XX (supports new 21XX series)
post #820 of 834 Old 11-04-2014, 01:02 PM
p5browne's Avatar
Liked: 2391
Model 21XX:
Production 103114- Fix for an issue with optional CRT 3D glasses emitter. Fix for output setup issue with being unable to select desired Style. Fix for auto aspect when "Letterbox Zoom" was set to off and would do a zoom step for 2.40 and 1.85 sources. Added 24 Hz to the direct vertical rate command ("menu 04").
Model 20XX:
Production 103114- Fix for output setup issue with being unable to select desired Style after being previously set. Fix for auto aspect when "Letterbox Zoom" was set to off and would do a zoom step for 2.40 and 1.85 sources. Added 24 Hz to the direct vertical rate command ("menu 04").
Model XE/XS/XD/Mini:
Production 103114- Fix for output setup issue with being unable to select desired Style after being previously set. Added 24 Hz to the direct vertical rate command ("menu 04").
post #821 of 834 Old 11-05-2014, 03:48 PM - Thread Starter
Liked: 2013
Lumagen Radiance Configuration utility Version 1.81 for the Radiance XD/XE/XS/Mini/20XX/21XX
This is a PC windows application useful for several tasks:
Backup/restore your setup by downloading/uploading to your PC.
Share your configuration with other users or Lumagen to solve problems.
Download Link
post #822 of 834 Old 11-05-2014, 04:43 PM
p5browne's Avatar
Liked: 2391
Radiance 20XX and 21XX:
Production 110114- Fixed issue where setting hotplug to always on could result in video not turning on for output.
post #823 of 834 Old 11-07-2014, 11:29 PM - Thread Starter
Liked: 2013
CalMAN 5.4.0 Build 1794 Open Beta Released @ 08 October 2014
Release Notes
Slight speed increase for the Lumagen radiance 21xx series when connected via USB.
Added support for the CRI-100 meter
Added support for ASSIMILATE SCRATCH as a pattern generator.
Added support for the MadVR cube file format in the SpectraCal Cube Generator
Added support for the Cube Generator to the Enthusiast license. With the Enthusiast license, only the MadVR format is supported.
We've also added some new methods of performing a cube calibration. You will now see a new option on the AutoCal Set dialog for cube calibrations called Calibration Type. InteractiveCal is the same method we have used in previous version of CalMAN. We've also added:
Added Intelligent Resolution Profiling (iRP) for 3D Cube calibrations: This method allows the users to specify the amount of time they wish to spend on the calibration. CalMAN then takes a series of readings, determining which areas need the most work, and then focusing on those areas. This method is targeted for professionals who need a display that is close enough and have limited amount of time to spend on the calibration.
Added Lightning LUT for 3D Cube calibrations: This is a fast method of creating a LUT targeted towards displays which are fairly linear and normally averages less than 15 minutes (often less than 10). I get excellent results on my EIZO monitor here, but this method can have issues with Plasma displays.
Added 3D LUT Retargeting: When using one of the two methods above to create a profile, you can now create a profile to different targets from the data generated from the first profile. This option is available on the Display tab when connected to hardware that supports a 3D cube. Just click the button and browse to the appropriate log file. You will then be prompted to select your new targets.
Added support for these new 3D LUT calibration methods for the Radiance 20xx and 21xx models.
Notes for workflow designers: We have uncoupled the in workflow pattern window for performance reasons. This means that CalMAN will not wait for this window to update before taking a reading. In cases where you have created workflows which use these windows for taking readings, you will need to make a modification. When getting properties on these windows, you will see a new option called Sync Pattern for Calibration. You will want to check this box if the window is used for taking active readings. All workflows created before this change will have that box unchecked.
We recommend you remove the zoomed in CIE chart you might have on 3D Cube calibration layouts. This window can cause CalMAN to crash during calibration. This window has already been removed from the official Color Cube (3D LUT) workflow.
Download Link
post #824 of 834 Old 11-13-2014, 04:53 PM - Thread Starter
Liked: 2013
CalMAN 5.4.0 Build 1800 Open Beta Released @ 14 November 2014
Release Notes
Added support for the madVR TPG (pattern generator). Supported for Enthusiast, Ultimate, and Studio licenses.
Improved gamut retargeting accuracy
Updated interface for the new HP Dreamcolor firmware (v 230)
BT1886 is now selectable in the DDC Controls within CalMAN for the Panasonic AX9xx series displays
Added some fixes for 3D LUT crashes. Also put some code in that we hope will give us some more information for existing crashes.
Added the new Lightning LUT Workflow.
Added CalMAN Eyeglass - SpectraCal's NEW 3D LUT Visulization Tool. Upload your own photos to this independent app to see the before-and-after effects of your 3D LUT calibration.
Download Link
post #825 of 834 Old 11-26-2014, 03:07 AM - Thread Starter
Liked: 2013
CalMAN 5.4.0 RC1 - Build: 1807 Released @ 26 November 2014
New Features
Lightning LUT Technology: generate corrective 3D LUTs in five minutes or less. CalMAN’s new Lightning LUT technology allows users to quickly correct the output of their video monitors. Unique interpolation algorithms allow CalMAN to provide an accurate 3D LUT calibration while only reading a select number of points in a 3D colorspace. Available in CalMAN Ultimate.
IR Profiling (Intelligent Resolution Profiling): create corrective 3D LUTs that fit your unique needs and time constraints. The process of creating a 3D LUT in CalMAN now offers users the option of setting specific time and quality preferences before beginning a 3D LUT calibration. Create a 3D LUT in under an hour or set no time constraints for a maximum quality calibration. Available in CalMAN Ultimate and CalMAN Professional.
Free CalMAN Eyeglass 3D LUT Visualization Tool: upload your own photos to SpectraCal's free 3D LUT visualization tool to compare before-and-after results of 3D LUT calibrations. Located in the CalMAN Main Menu.
Added support for ASSIMILATE SCRATCH® and SCRATCH Lab® digital workflows as pattern generators. Supported in CalMAN Ultimate.
Added ASSIMILATE SCRATCH to the format drop-down on the SpectraCal Cube Generator.
Added support for the Lumagen Radiance 21xx series video processors with higher baud rate when using the built-in USB connection in CalMAN Professional and CalMAN Ultimate.
Added support for the Colorimetry Research CR-100 colorimeter in all license levels of CalMAN for Business.
Updated keyboard shortcuts for greater usability. New shortcuts are as follows:
A = AutoCal/AutoCube
C = Continuous Read
H = Read Grayscale High
L = Read Grayscale Low
S = Series Read
X = Stop
Arrow Key Right = Next Workflow Page
Arrow Key Left = Previous Workflow Page
Space Bar = Single Read
Added new Lightning LUT workflow to CalMAN Ultimate. Provides 3D LUT calibrations exclusively with CalMAN’s new Lightning LUT technology.
Changes
Updated interface for the new HP DreamColor firmware (v.230)
BT.1886 is now available in the CalMAN DDC controls for the Panasonic AX900 series displays.
Resolved Issues
Resolved issue where target lines weren't drawing on deltaE charts in reports.
Resolved issue where White and Black points were incorrect on Saturations Sweeps when in PC Levels.
Resolved issue with the VP401 where patterns could get out of sync.
Known Issues
On the CR-100, if you have initialized the meter with Sync On, then switch it off and then back on, the meter will still function as if Sync is set to off. You need to reinitialize the meter before Sync will enable again.
Notes
For Workflow Designers using CalMAN’s Design Mode Feature: We have uncoupled the in workflow pattern window for performance reasons. This means that CalMAN will not wait for this window to update before taking a reading. In cases where you have created workflows which use these windows for taking readings, you will need to make a modification. When getting properties on these windows, you will see a new option called Sync Pattern for Calibration. You will want to check this box if the window is used for taking active readings. All workflows created before this change will have that box unchecked.
Download Links
post #826 of 834 Old 12-29-2014, 03:14 PM
p5browne's Avatar
Liked: 2391
New Features
C = Continuous Read
S = Series Read
X = Stop
Changes
Resolved Issues
Known Issues
Notes
Download Links
New update to 5.4.0b Build #1833
post #827 of 834 Old 01-10-2015, 12:33 PM
p5browne's Avatar
Liked: 2391
After all these years!
Getting an issue while manually calibrating the Samsung UN65HU9000 Greyscale and CMS
(and previously the LG 55LHX, and the Samsung PN64F8500), I got that `Does not
Respond to setting changes' moments!
Will shut everything down, and start over, to continue to finish, or sometimes come
up with the same stalemate. But results were always mixed.
Also over the years was the Info screen popping up from the Radiances due to some
conflict with the TV Remote.
Pushing the Exit button got rid of that issue.
Last night, it finally dawned on me. The Radiance was also being affected in other ways
by the TV Remote, but because nothing was seen on screen, never thought my calibration
was being compromised!
So, last night I covered the front of the Radiance to prevent stray TV Remote signals.
Absolutely the BEST calibration I've done in years!
No more cursing the TV, Calman, and what ever! Radiance front stays covered through out
the calibrations from now on. Only signals going to it is the Serial Connection.
Addendum:
Turn Off the Radiance IR: MENU 0995. To turn back on repeat, or remove power Input, wait 10 seconds and reinsert.
post #828 of 834 Old 01-14-2015, 11:40 PM - Thread Starter
Liked: 2013
CalMAN 5.4.1 Open Beta - Build: 1847 Released @ 14 January 2015
New Features
Added Include Black in AutoCal Adjustments check box. This is available under the Workflow Advanced Options tab. This is saved with the workflow. Prior to this change, if you selected a specific Black Level, CalMAN would attempt to calibrate black to this specified level.
With this box unchecked, CalMAN will instead use this as the value of black for its calibration calculations. Black will not be adjusted, but the targets will be calculated using this specified black.
New History runtype. For you workflow developers, there is a new run type called History. This cal allow you to take multiple readings repeated readings and have them all chart together. In order for this to work, you need to set the layout to History and your graphs to History. There need to be at least one chart on the layout which is set to the runtype of your readings.
For example: if I wanted to have a history of how 100% reads over time, I might throw out an RGB chart and a luminance chart set to history. I might then also add a RGB chart set to single point which is set to grayscale. For grayscale points on the layout, I would set it to White Only.
We'll work on putting together a demo layout/workflow to show this new feature off. In the mean time, we'd love to get feedback from you out there on how you view this new feature and see what tasks you can come up for it.
Changes & Fixes
Resolved licensing issue for the CR-250 meter
CalMAN now requires version 0.87.13 of madVR. No new functionality yet, but some is coming that requires a later version.
Download Links
post #829 of 834 Old 01-31-2015, 10:04 PM
p5browne's Avatar
Liked: 2391
Radiance FW Updates
21XX:
Production 012515- Fix for an issue with factory reset after enabling 17x17x17 CMS that would give incorrect colors. Adds composite input option to 2124/2144 component inputs. Improvements to auto aspect detection. Added auto aspect detection capability to analog inputs (2124/2144). Fix for composite input with film mode selected. Fix for loss of video issues with chromebox and other HTPC type sources. Fix for constant height setup with certain 3D formats and scale bias off causing incorrect picture. Fix for test patterns with side-by-side or top-bottom 3D output. Expanded size limits for rs232 "ZY2" command to match onscreen menu limits.
20XX:
Production 012515- Adds composite input option to 2022/2042 component inputs. Improvements to auto aspect detection. Added auto aspect detection capability to analog inputs (2022/2042). Fix for loss of video issues with chromebox and other HTPC type sources. Fix for constant height setup with certain 3D formats and scale bias off causing incorrect picture. Fix for test patterns with side-by-side or top-bottom 3D output. Expanded size limits for rs232 "ZY2" command to match onscreen menu limits.
XE:
Production 012515- Fix for loss of video issues with chromebox and other HTPC type sources. Fix for constant height setup with certain 3D formats and scale bias off causing incorrect picture. Fix for test patterns with side-by-side or top-bottom 3D output. Expanded size limits for rs232 "ZY2" command to match onscreen menu limits.
Update time ~3minutes @57k from previous firmware
XS:
Mini:
XD:
post #830 of 834 Old 03-05-2015, 12:50 PM - Thread Starter
Liked: 2013
CalMAN 5.4.1 - Build: 1891 Released @ 05 March 2015
New Features
Added "Include Black" option in AutoCal Adjustments checkbox. This is available under the Workflow Advanced Options tab and is saved with the workflow. With this box unchecked, CalMAN will not adjust absolute black in calibrations, but custom black level targets may still be set within the workflow.
Added "Points Remaining" indicator to progress windows for point-based 3D LUT calibrations.
Added support for 2014 EIZO models: CG247, CG277, CX241 and CX271.
Added support for new firmware for Colorimetry Research meters (CR-100, CR-250) that improves meter syncing.
Ultimate License Only: added new History runtype that allows users to display multiple readings on the same chart.
Ultimate License Only: added ST.2084 gamma formula for high dynamic range (HDR) displays.
Added LCD LED Blue/Green colorimeter tables for X-Rite i1Display Pro (OEM and retail).
Changes
Changed default setting for input and output on the DVDO TPG to "Limited." This assures the output levels of the device are not compressed.
CalMAN support for madVR pattern generator and 3D LUTs now requires version 0.87.13 of the madVR software.
Computer monitor workflows now default to full PC levels (0-255) for compatibility with the sRGB gamma standard.
Changed meter mode default for the CR-250 from Fast 2x to Normal.
CalMAN now writes 3D LUT/profile files directly to the hard drive previous to writing the files to 3D LUT hardware.
CalMAN now supports up to 99 different meter tables for the Klein K10 devices.
Resolved Issues
Resolved licensing issue with the CR-250 spectroradiometer.
Resolve an issue that would cause CalMAN to crash or stop during a 3D LUT calibration or LUT retargeting.
Resolved an issue that prevented workflow charts from updating properly.
Resolved an issue that prevented CalMAN from writing 1D LUTs to EIZO CX models.
Resolved an issue that caused CalMAN to crash when connecting to the SpectraCal C3 colorimeter.
Corrected luminance scaling issue in meter profiles.
Resolved an issue with CalMAN PC levels for the DVDO TPG.
Resolved an issue with data plotting for charts with a filtered data set. This was especially noticeable on CIE charts during 3D LUT calibrations.
Reduced discontinuities in the whiter-than-white (WTW) region of a 3D LUT when profiling to reference white (235).
Known Issues
There is a known issue with Windows 8 and the Blackmagic Design HDLink drivers which cause CalMAN to crash when writing to the device.
Download Links
Manni01 likes this.
post #831 of 834 Old 03-09-2015, 07:36 PM
p5browne's Avatar
Liked: 2391
20XX FW Update:
Model 20XX:
Production 030115- Fix for test patterns with 3D signal and 2.35 output. Fix for 2022/2042 analog component input when source switches from higher resolution to 480i and the 20XX loses the 480i picture.
post #832 of 834 Old 08-31-2015, 03:06 PM
p5browne's Avatar
Liked: 2391
New Pro, 21XX and 20XX Updates
http://www.lumagen.com/testindex.php...ncepro_updates
Beta 082015- Fix for input colorspace problem with rgb source into inputs 7 and 8. Adds ability to set output colorspace (.ie RGB, YCbCr422, etc) in menu under Output:Styles:HDMI Format:Type. Fixed incorrect reporting of output colorspace when in 4k60 output mode.
Update time ~1 minutes @230k from previous firmware
Production 080415- Fix for problem with setting vertical shift greater than 0 when using output shrink (a combination sometimes used for setting up a 2.35 output aspect). Fix for issues with not displaying video source correctly in a rare situation. Improved reliability of output video connection.
UN65HU9000 with SEK-3500U - Mine
UN75JU7100 / UN55HU7250 with SEK-3500U / UN32EH5300 / 2 X LG 55LHXs - wife's ! New addition UN40J5200AF
PN64F8500 up for sale
post #833 of 834 Old 09-02-2015, 01:19 PM - Thread Starter
Liked: 2013
CalMAN 5.6.0 Open Beta - Build: 2136 Released @ 02 September 2015
Release Notes
Optimized AutoCube algorithms for grayscale performance in general as well as a focus near black.
For those of us performing cube calibrations, we really want to get your feedback on this.
Added Support for the Astro VG series pattern generators (Ultimate, Professional, Expert, Studio, and ColorChecker)
Added madVR support to the Professional license level (Pattern Generator and Display)
Added new FSI models to the drop down box for the FSI Display
Prisma has been added as a drop down selection for format for the SpectraCal Cube Generator
Qinc Prisma has been added as its own entry as a display. This creates a LUT file that can be uploaded to the device using the Prisma's interface. (Ultimate, Professional, Studio, Enthusiast)
Resolved an issue where the Load LUT File button on the 3D LUT DDC Controls screen was not working.
Resolved an issue that would cause hangs/crashes when performing a 3D LUT calibration in PC Levels.
Removed Manual DVDs. Pattern Change Prompts under the default Source option still function as usual.
Removed support for all IR controlled devices except for the SpectraCal DPG line.
Download Links
post #834 of 834 Old 09-09-2015, 10:27 AM
p5browne's Avatar
Liked: 2391
Calman now updated to # 2143
Lumagen Pro:
Beta -082815- Adds 4K60 input support. Fixup for test patterns with certain setup conditions that caused the pattern to not fill in correctly. Adds in Output:Style:HDMI Format: Color Format menu command. Adds a Menu SIze option into Menu Options under Other: Menu Control. Please continue giving us your detailed feeback on issues via email at radiancepro_beta@lumagen.com .
Update time ~5 minutes @230k from previous firmware
Beta 090215- Fix for input color issue with DVI sources. Fix for incorrect output colors occurring under certain conditions. Fix for video not coming on sometimes when unit was turned off and back on. Added audio mute duration control (in the menu under Global: Audio: Mute Control) to extend audio muting when switching between sources. Please continue giving us your detailed feeback on issues via email at radiancepro_beta@lumagen.com .
Beta 091515- Adds 3D support for all common 3D formats. When running this update disconnect all but the selected source and allow the single connected source to play a non interrupted video--like a movie while the update runs. This avoids a problem during the update which has occurred for some users in previous updates. The issue causing this problem is now fixed and updates after this should work fine regardless of the connected sources. Please continue giving us your detailed feeback on issues via email at radiancepro_beta@lumagen.com .
Reply Display Calibration
