Radiance 3D LUT (5x5x5 Cube) Calibration with CalMAN 5 - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #91 of 834 Old 09-14-2012, 08:38 AM
PlasmaPZ80U's Avatar
Quoted: 2315 Post(s)
Liked: 716
Originally Posted by N3W813 View Post
Question before I drop ~2000 on a Radiance Mini without my wife knowing....(you all know how dangerous that is.....)
are all Sharp Elites that bad?
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is offline
post #92 of 834 Old 09-14-2012, 08:51 AM
Chad B's Avatar
Quoted: 579 Post(s)
Liked: 1332
All Sharp Quattrons are that bad, Elite or not. Calibrating at 75% saturation certainly helps and the color can look subjectively pleasing but never objectively accurate (until this with the Lumagen, of course).
touring ISF/THX calibrator with Jeti 1211 and Klein K-10
Latest reviews:JVC RS500 and 600, JVC RS400, LG 65C7P, JVC RS420
Copied settings measured, older LG OLED calibration tips, Review index
Chad B is offline
post #93 of 834 Old 09-14-2012, 08:51 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
Yes they are all that bad, and yes that is exactly what a lumagen Cube 3D Lut will fix.
sotti is offline
post #94 of 834 Old 09-14-2012, 09:39 AM
derekjsmith's Avatar
Liked: 116
As I stated yesterday: This marks a significant milestone in how we calibrate displays
Not just the AutoCal side of it but now being able to truly fix all the mistakes the display mfg can make.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #95 of 834 Old 09-14-2012, 09:54 AM
N3W813's Avatar
Quoted: 45 Post(s)
Liked: 81
Sorry for the newbish question......when I calibrate CMS in Calman v5, the default setting is 75% "luminance". This is not the same as calibrating 75% saturation, right? If not, how should I configure Calman v5 in order to calibrate 75% saturation? And at what % luminance?
My ArgyllCMS/MadVR 3DLUT Creation Workflow
My Sharp Elite Movie THX AV Mode Settings
--Aug 2011 Set, 2.2 gamma [ link ]
--Nov 2012 Set, 2.2 gamma [ link ]
N3W813 is offline
post #96 of 834 Old 09-14-2012, 09:57 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
In some of the advanced workflows their are saturation graphs, like the ones posted in this thread. To calibrate using 75% saturation, you adjust the CMS while looking at those points to see how much you should adjust the system. You can use any luminance percentage you want. By default we use 75% (It's the same selector for gamut and gamut saturation in our UI).
sotti is offline
post #97 of 834 Old 09-14-2012, 02:12 PM
Liked: 116
Radiance 090512 beta firmware just posted: http://www.lumagen.com/testindex.php?module=updates
I'm sure this will happen a few times over the next week so I would check with Lumagen every couple of days until it is final.
Mike_WI likes this.
Derek
post #98 of 834 Old 09-14-2012, 03:15 PM
Liked: 116
Here we go http://store.spectracal.com/downloads.html license keys are also in the email queue, let the fun begin
Derek
post #99 of 834 Old 09-14-2012, 03:35 PM
Rolls-Royce's Avatar
Quoted: 398 Post(s)
Liked: 564
OK, I'm in. I just downloaded the V5 Home RC and have ordered a Radiance Mini-3D. Curious to see how much of a difference it will make over my VideoEQ Pro!smile.gif
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #100 of 834 Old 09-14-2012, 03:38 PM
N3W813's Avatar
Quoted: 45 Post(s)
Liked: 81
CalPC Client on downloads page show 2.1.1.18 but actual download is still 2.1.1.13. smile.gif
N3W813 is offline
post #101 of 834 Old 09-14-2012, 05:28 PM
Liked: 116
That is being fixed it should say 2.1.1.13 are working on CalPC Client 2.2.1.18 but that won't be out until next week.
Derek
post #102 of 834 Old 09-14-2012, 06:35 PM
njfoses's Avatar
Quoted: 159 Post(s)
Liked: 109
Im thinking about jumping aboard the auto calibrate train and have a question. Can you pause the process to take a dark reading with the i1 pro since the process takes 40 min or so?
njfoses is online now
post #103 of 834 Old 09-14-2012, 06:45 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
You can't, but the Cube cal process only runs for about 20 minutes and doesn't really have very many dark readings, so an i1 Pro should be fine, just do a dark cal right before you kick off the cube calibration portion.
e08 likes this.
sotti is offline
post #104 of 834 Old 09-14-2012, 06:58 PM
buzzard767's Avatar
Quoted: 1660 Post(s)
Liked: 2439
Yes indeed, and it looks like Sharp is never going to come up with the 12 month old tracking fix they promised. 3D LUTs send a "fake" signal to the TV knowing that that TV will think it is doing the right thing but actually produces a picture that was meant to be originally. Make sense?
Buzz
THX Certified Level II Video Calibrator
buzzard767 is offline
post #105 of 834 Old 09-14-2012, 09:47 PM
rjyap's Avatar
Quoted: 44 Post(s)
Got the license key this morning and done the 3D LUT 125point calibration on Panny PY800. The skin tone never look this good before. Lumagen and Spectracal 5 is awesome in giving us 3D LUT and AutoCal which completed in around one hour. The basic greyscale, gamma and 1D CMS still need to be perform on your display before running the 125 points cube calibration.
rjyap is offline
post #106 of 834 Old 09-15-2012, 04:06 AM
njfoses's Avatar
Quoted: 159 Post(s)
Liked: 109
So the software pauses between grayscale and the cube portion to allow for a dark reading?
post #107 of 834 Old 09-15-2012, 04:07 AM
njfoses's Avatar
Quoted: 159 Post(s)
Liked: 109
I can understand getting grayscale and gamma in the ballpark before starting but shouldnt the cube take care of all cms work?
post #108 of 834 Old 09-15-2012, 07:21 AM
Gordon Fraser's Avatar
Quoted: 168 Post(s)
Liked: 180
You don't need to run any 1d cms before running the 125 point cube. you just do your greyscale and set your gamma how you want it then run the 125point CMS. No need to do the old style 8 point one first.
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is offline
post #109 of 834 Old 09-15-2012, 07:37 AM
rjyap's Avatar
Quoted: 44 Post(s)
The CMS is done on the display, not lumagen. Need to calibrate the display first before running Cube calibration so that the mapping is not too far off.
Anyway, just done BENQ W6000 cube calibration. Found out that BENQ internal color processing for saturation is quite linear.
rjyap is offline
post #110 of 834 Old 09-15-2012, 08:21 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
They are two discrete steps, so yes their is a break between them.
sotti is offline
post #111 of 834 Old 09-15-2012, 08:23 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
That all depends on the quality of the CMS in your display. Some CMSs do more harm than good, creating artifacts or making the display's linearity issues worse.
In the case of a bad CMS, leaving it alone is fine. If you've got a decent CMS, leaving it just slightly over-saturated means less adjustment in the radiance, which is always better the less processing you have to do.
sotti is offline
post #112 of 834 Old 09-15-2012, 09:00 AM
cal87's Avatar
Quoted: 37 Post(s)
Liked: 32
I'll ask before someone else does.
Calibrate with Darbee on or off?
cal87 is offline
post #113 of 834 Old 09-15-2012, 09:11 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
Since the Darbee is just a sharpness control on steroids, it shouldn't have any effect on solid swatches.
If leaving it on, has an effect, we'd effectively be calibrating out it's "enhancements". So I think from that perspective you'd want to turn it off while calibrating.
sotti is offline
post #114 of 834 Old 09-15-2012, 12:11 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 353
I still feel like doing calibration as complete as 20 grayscale steps (with 20 gamma corrections) and even the 8-point CMS (let alone the cube matrix calibration), then applying Darbee or any other processing device to partially un-do the highly accurate calibration is a bit of whatever you'd call a calibration oxymoron. Here you are making a display as accurate as possible so you can see the precise intent of whoever directed or shot the program (movie or TV) thinks is "perfect" and you are taking that "perfect" and making it "less perfect" with the add-on box just to make the images "prettier" than the originals. It just seems contradictory.
giraffejumper likes this.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #115 of 834 Old 09-16-2012, 04:54 AM
dazzerxxx's Avatar
I'd appreciate some help with a problem I'm encountering. Running the color cube workflow template I can get as far as successfully completing RGB autocal but nothing appears to happen on the "calibrate 3d coloe cube lut" screen when I select the autocal button. I may be missing something obvious in the settings but I'm not sure what.
The Radiance is set in both display control and pattern gen and I appear to be able to take gamut readings using the series read button on the calibrate 3d lut color cube screen.
Any ideas` ?
dazzerxxx is offline
post #116 of 834 Old 09-16-2012, 06:18 AM
buzzard767's Avatar
Liked: 2439
Any ideas` ?
For Direct Display Control you need to select Lumagen Radiance 3D LUT, not Lumagen Radiance CMS.
Buzz
post #117 of 834 Old 09-16-2012, 07:08 AM
SJHT's Avatar
Quoted: 495 Post(s)
Liked: 233
I have a Rad XE3D and ran this last night. Very impressive. I have a basic question. Seems like the Rad automatically SAVES after? I'm used to doing this manually after changes prior to powering off. SJ
SJHT is offline
post #118 of 834 Old 09-16-2012, 07:17 AM
dazzerxxx's Avatar
Originally Posted by buzzard767 View Post
For Direct Display Control you need to select Lumagen Randiance 3D LUT, not Lumagen Radiance CMS.
Thanks Buzz
Where do I make this selection ?
Under "display control" tab there only appears to options for "Direct Display Control" or "Lumagen Radiance CMS".
post #119 of 834 Old 09-16-2012, 07:48 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
Thanks Buzz
What license do you have for CalMAN? You need to have an enthusiast license to use the Cube 3D Lut calibration.
sotti is offline
post #120 of 834 Old 09-16-2012, 07:54 AM
dazzerxxx's Avatar
According the the email I received it's "Enthusiast license level" because I had additional add-on keys under v4. This is confirmed under the licensing menu item.
EDIT :-
Doh ! Think I spotted the issue. Under DDC "find display" I selected the wrong Radiance option i.e. CMS and not LUT. Thanks Buzz
Reply Display Calibration
