Radiance 3D LUT (5x5x5 Cube) Calibration with CalMAN 5 - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
Old 09-20-2012, 04:34 PM
Nudgiator's Avatar
Quoted: 31 Post(s)
Liked: 35
Originally Posted by sotti View Post
That is pretty close to what we'd expect out of the current build, hopefully I'll be able to get a little more light out the tweaks I've made for tomorrow's release.
Tomorrow's release: will there be two versions ... HOME version and BUSINESS version ?
Source: Samsung UBD-K8500 (UHD), Panasonic BDT-110 (BD), Toshiba HD-XE1 (HD-DVD), Vantage VT-1S (SAT), Kathrein UFS-924 (SAT)
Calibration: LightSpace CMS, SpaceMan, SpaceMatch, CalMAN 5 Prof., Chroma Pure, Lumagen Radiance Pro 4446, Chroma 5, SpectraCal C6, EODIS3, i1 pro 2, Klein K10-A
Target: JVC-X7000 (Beamer), Panasonic TX-P65VTW60 (Plasma TV)
Sound: Yamaha RX-V2067 (AVR), Teufel Theater LT 3 (Speaker)
Nudgiator is offline
Old 09-20-2012, 04:35 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
yes that is the plan.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
Old 09-20-2012, 04:57 PM
Nudgiator's Avatar
Quoted: 31 Post(s)
Liked: 35
Old 09-20-2012, 05:20 PM
derekjsmith's Avatar
Liked: 116
Yes CalMAN 5 Home Video 5.03 RC2 and CalMAN 5 for Business 5.03 RC1
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
Old 09-20-2012, 05:21 PM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
It's all targets based. So if you select power with an exponent of 2.35, all the saturation targets are calculated off of that.
I honestly haven't explored what tweaking the radiance gamma factor does to a cube post calibration.
But since we allow you to pick any old gamma formula and target exponent you want, I don't see a reason why you wouldn't just select your targets pre-cal. If you wanted to just turn the gamma down for daylight viewing, that's no big deal since it's not color critical anyway. If you did want a color critical version with a lower gamma, then just do that on a separate CMS entry.
If something goes sideways during the calibration, then we need to stop the calibration and re-run it. Usually we can correct from a bad reading or two, but in the above example I suspect what happen is was the gamma was all based off of the a mis-calibrated white point, so the target luminance was wrong during the the autocal portion. Upon remeasuring you see the final result.
Thanks for the info!
Geof
Geof is offline
Old 09-20-2012, 05:27 PM
Liked: 116
Geof, we just finished up testing the latest Radiance firmware 090712 on our JVC RS-55 in all filters modes and they all worked out well. I will get some data posted for each of the RS-55 filter modes.
Derek
Old 09-20-2012, 05:42 PM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Looking forward to that. My Blue primary has low saturation and when that is fixed it's luminance falls. There is a fine line where both are acceptable (but not great). No matter what was done blue had too much red tho and Cyan luminance is horrible and unfixable. This was using the Stage profile and the internal CMS to correct the colorspace as best I could before using the 125 pt cal. Out of curiosity do you know how many hours are on the lamp of your RS55?
Geof
Geof is offline
Old 09-20-2012, 06:10 PM
Liked: 116
The ones we found where the best to start with was Vivid and Adobe. Not sure on the lamp I will have Darrell check. All of our tests were done with the RS-55 reset to factory.
Derek
Old 09-20-2012, 06:38 PM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
I started fiddling with the Adobe profile right after I posted above. I used the internal CMS and got it close but that damn blue hue is too red and I can't quite get the undersaturation corrected. Everything else should be okay i think. You know when it's difficult to eek out a Rec709 colorspace from the supposed Adobe RGB colorspace something just doesn't seem like it was designed properly (maybe lamp age is a contributing factor here??). I may give vivid a try and see how that compares to Adobe. Thanks!
Geof
Geof is offline
Old 09-20-2012, 06:42 PM
SJHT's Avatar
Quoted: 244 Post(s)
Liked: 124
Thanks for this info! Did you tweak anything on the JVC RS55 (e.g. CMS) before starting after you reset to factory? SJ
SJHT is offline
Old 09-20-2012, 07:12 PM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Derek,
I just looked at vivid and after a little tweaking with the internal CMS it looks to be the way to go. I'll try a cube cal with this profile (but not tonight any longer). Regardless this looks to be the best starting point I've found yet.
Geof
Geof is offline
Old 09-20-2012, 07:13 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
I believe we calibrated the cuts and gains and brightness and contrast. But I believe that was it.
Joel Barsotti
SpectraCal
sotti is offline
Old 09-20-2012, 08:19 PM
Liked: 116
Derek,
Here is Vivid on our RS-55 it should be more than enough to work with, maybe too much smile.gif
Derek
Old 09-20-2012, 09:33 PM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Mine is not nearly that nice but I was able to adjust the internal CMS to make everything saturated or over saturated and almost all colors had enough luminance. I did rein in green a bit.
Geof
Geof is offline
Old 09-21-2012, 07:25 AM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Here is what I'm seeing. This is about the best case blue hue I've seen. This was right after a factory reset and was taken using the Standard profile and a fresh new lamp (w/0 hours) but I get nearly nearly identical results with my existing lamp (lower luminance's tho). I used the internal JVC patterns but the results match those I've gotten using the Radiance patterns. I can diddle the internal CMS control to improve this somewhat but nothing I've tried gets blue hue any better. It appears to have a purplish shade when looking at the pattern but fortunately it's is not horribly apparent when viewing real content.
PS: Forgive the CP screenshot....rolleyes.gif
Geof
Geof is offline
Old 09-21-2012, 08:05 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Any reason you didn't use vivid like we recommended?
Joel Barsotti
SpectraCal
sotti is offline
Old 09-21-2012, 08:07 AM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
I have not gotten to do a cube cal yet but even with vivid blue hue is about the same as shown above. It just doesn't get any better....but it's obvious your machine is much better in that dept.
Geof
Geof is offline
Old 09-21-2012, 08:56 AM
SJHT's Avatar
Quoted: 244 Post(s)
Liked: 124
What workflow is good to adjust the JVC cuts/gains? Thanks. SJ
SJHT is offline
Old 09-21-2012, 09:08 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Everything you need to do a Cube, including cuts and gains is in the Cube workflow.
Joel Barsotti
SpectraCal
sotti is offline
Old 09-21-2012, 09:10 AM
Nudgiator's Avatar
Quoted: 31 Post(s)
Liked: 35
Just a hint: DON'T touch the CUT controllers ! Do this:
1. Adjust white and black level with the controllers of the JVC
2. Adjust 100 IRE white point ONLY with the GAIN controllers of the JVC (go to a workflow where you can see a 100 IRE test pattern and adjust RGB balance)
3. Run autocal of grayscales, gamma ... then 125 point cube.
Old 09-21-2012, 12:57 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
What color is your room?
Joel Barsotti
SpectraCal
sotti is offline
Old 09-21-2012, 01:28 PM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Mostly black (velvet) with some dark gray.
Geof
Geof is offline
Old 09-21-2012, 01:39 PM
Liked: 116
Geof do you have access to a spectro? I would like to see the SPD of your RS-55 it should not be that far off even with an older lamp. Aged lamps usually become red deficient before any other color.
Derek
Old 09-21-2012, 02:11 PM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Yes I have Rev A i1Pro.
BTW, Tom also used a spectro to train his colorimeter and my i1D3 appears to be accurate in chroma but off a tad in luminance. I am going to play some more with this tonight but this problem has been remarkably consistent. Various color profiles, lamps, and pattern sources all show similar hue issues with blue. In fairness I do have a dark burgundy carpet but the screen is not close and no other colors are exhibiting a red influence. I think I'm narrowing in on either some mis-adjustment or something is amiss in the projector as no one else seems to have this problem. I did email JVC support but have not heard back.
Geof
Geof is offline
Old 09-21-2012, 02:17 PM
Liked: 116
If you could shoot a SPD with your i1Pro I will pass it onto our lab and have them take a look. The SPD charts are on our Quick Analysis workflow.
They look something like this, from my LG LED:
Derek
Old 09-21-2012, 02:19 PM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
I'll try to do this with the i1pro facing the projector. Should I use a properly white balanced 100% pattern?
Geof
Geof is offline
Old 09-21-2012, 02:25 PM
Liked: 116
Facing the projector if you have the white diffuser attachment for your i1Pro and in CalMAN 5 use "Facing Projector" display type. The calibrations should not matter but you should shoot with the profile off so we can see the native lamp and not the filters. Then again with Vivid to see the filters in the light path.
Derek
Old 09-21-2012, 02:30 PM
Geof's Avatar
Quoted: 44 Post(s)
Liked: 50
Good point on the diffuser....I'm not sure if I have one for the i1Pro. Screen it is if not.
Geof
Geof is offline
Old 09-21-2012, 05:41 PM
Liked: 116
Here is ours RS-55:
Derek
Old 09-21-2012, 05:44 PM
RonF's Avatar
Quoted: 257 Post(s)
Liked: 258
Is this workflow information for both the "pre" things that need to be done such as the cuts and gains and contrast and gamma and grayscale, plus the instructions for when ready to push the button on the cube 125 point auto cal.....contained in a document on line anywhere yet? So a newcomer such as myself considering going this route can take a look at how much is there to walk me through the whole process?
thanks
RonF is offline
