Profiling Colorimeter To Spectro - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 09-09-2012, 09:23 PM - Thread Starter
Iron Mike's Avatar
Quoted: 64 Post(s)
Liked: 408
Hi,
I have a D3 (i1 Display Pro) here which I will profile to the i1 Pro (Rev D) I just purchased.
It appears that this spectro / colorimeter combo is a good consumer level solution, I wonder would the Discus / i1 Pro combo give me better results ? I'm assuming the only improvement would be the better repeatability accuracy of the Discus over the D3... Anything else that the Discus brings to the table as an improvement to the D3 in a combo solution ?
Regarding the profiling process and workflow:
1) For my previous calibrations (using just the D3) I have placed the D3 directly on the screen - do I place it directly on the screen for the profiling process as well ?
2) what is the placement of the i1 Pro when profiling ? on screen ? on a tri-pod a few inches away ?
3) use the (profiled) colorimeter for grayscale & gamma and the spectro for gamut work ?
Thanks for any help, input and general info on this process.
- M
calibration & profiling solutions: Lightspace, Spaceman, Calman, Argyll, ColorNavigator, basICColor
profiling & calibration workflow tools: Display Calibration Tools
meter: CR-250, Klein K-10 A, i1Pro, i1D3
AVS thread: Lightspace & Custom Color Patch Set & Gamma Calibration on Panasonic 65VT60
Iron Mike is offline
post #2 of 23 Old 09-11-2012, 01:14 PM
ndaa75's Avatar
Originally Posted by Iron Mike View Post
Hi,
- M
Hi ironlike,
In answer to your questions;
1). directly
2). On screen using the adaptor
3). Upto you, D3 better at low light, pro more accurate at everything else.
Benq W1080ST Projector, Panasonic TXP55VT30 plasma, Yamaha RXA3020 AVR, Denon DVD-2500BT, Q Acoustics 1010i in 7.1, i1 Pro spectro, i1 Display Pro, Calman 5 Enthusiast, PS3, Xbox 360, Wii
Calibration Management Disc
ndaa75 is offline
post #3 of 23 Old 09-11-2012, 03:58 PM - Thread Starter
Iron Mike's Avatar
Quoted: 64 Post(s)
Liked: 408
@ndaa75: thank you for your response.
just to make sure I'm not misunderstanding calibration fundamentals here: when we talk about "low light" (where the colorimeter is more accurate), we talk about usage in grayscale & gamma, correct ?
Also, I just chatted with another AVS member regarding WARM UP TIME, and we are both a little bit confused as there are so many posts that say different things:
> obviously the display needs to warm up properly (1-2 hours)
4) Is there a warm up time for colorimeters, for example the i1 Display Pro ?
5) can I leave the colorimeter on screen for the duration of the calibration or will the heat of the display throw off the colorimeter over time ?
6) Is there a warm up time for spectros, for example the i1 Pro ?
7) can I leave the spectro on screen for the duration of the calibration (e.g. gamut work) or will the heat of the display throw off the spectro over time ?
Thanks again.
- M
post #4 of 23 Old 09-11-2012, 07:46 PM
wildgoose's Avatar
Quoted: 12 Post(s)
How low is 'low light'? ie, are we talking about 10, 20%? or slightly higher? How accurate is the Pro at those brightness settings. Obviously it may not be as accurate as the D3, but how much error are we talking about?
wildgoose is offline
post #5 of 23 Old 09-11-2012, 11:58 PM
HDTVChallenged's Avatar
Liked: 215
Originally Posted by wildgoose View Post
How low is 'low light'? ie, are we talking about 10, 20%? or slightly higher?.
It's not really a function of %stimulus, "low light accuracy" of the i1pro is a function of absolute luminance. In my (limited) experience with the i1pro, it starts getting a bit wonky below ~1.0 to 1.5 nits (or ~15% stim on my display.) Of course, I never got around to profiling my colorimeter for comparison as I originally planned. YMMV ...
HDTVChallenged is offline
post #6 of 23 Old 09-12-2012, 12:31 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
That's about dead on.
Also to note, is that it's not like it hits a point and falls off a cliff, it just starts getting off at maybe even 2-3 cd/m and just continues to be further and further off as the light levels drop.
So If you have a bright flat panel that point is pretty low, but if you have a dim projector, then that threshold is much more significant.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #7 of 23 Old 09-12-2012, 01:57 PM
Quoted: 1394 Post(s)
Liked: 589
Scotti
So, what you're saying is that the readings start becoming inaccurate? I thought you just started getting readings that bounce around alot..
JimP is offline
post #8 of 23 Old 09-12-2012, 02:38 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Originally Posted by JimP View Post
Scotti
Repeatability is closely tied to accuracy.
Whenever you lose repeatability accuracy drops. CalMAN has some advanced handler code to take multiple readings and do intelligent averaging, but even then your accuracy is going to decline as luminance levels drop.
Joel Barsotti
SpectraCal
sotti is offline
post #9 of 23 Old 09-12-2012, 04:26 PM - Thread Starter
Iron Mike's Avatar
Quoted: 64 Post(s)
Liked: 408
can anybody comment on the warm up periods, points 4) 5) 6) 7) ?
Thanks !
- M
post #10 of 23 Old 09-12-2012, 05:08 PM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
Thanks !
- M
From everything I have read, both meters have temperature compensation built in and should not be effected.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #11 of 23 Old 09-12-2012, 07:39 PM - Thread Starter
Iron Mike's Avatar
Quoted: 64 Post(s)
Liked: 408
is there a necessary warm up period for either colorimeter or spectro ?
post #12 of 23 Old 09-12-2012, 07:45 PM
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 562
the D3/C6 has built-in temp comp? I find I need about 30 mins of warm up on the display to get stable, accurate readings (and the display needs to be warmed up for a hour or more)
I assume the i1Pro uses the dark readings for temp comp? am I right?
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #13 of 23 Old 09-12-2012, 08:51 PM
airscapes's Avatar
Quoted: 353 Post(s)
Liked: 285
I could swear I recall Derek or someone from specracal saying the C6 has thermal compensation built in. BUT, I have been wrong before.. just ask my wife! biggrin.gif
I think most folks that use a meter in contact mode hang as soon as they start the display so it warms up with the display but if you are using a tripod in non contact mode it really wouldn't need that.. so your readings become stable would seem to be more of a display stabilization issue than meter wouldn't you think?
Doug
post #14 of 23 Old 09-12-2012, 09:48 PM
Liked: 589
Any temperature compensation for the i1Display3 pro?
JimP is offline
post #15 of 23 Old 09-12-2012, 10:21 PM
slb
slb's Avatar
According to this review, the i1 Display Pro (a.k.a. D3) does have some temperature compensation.
slb is offline
post #16 of 23 Old 09-12-2012, 10:35 PM
Liked: 215
Exactly ... It (the i1Pro) was good enough on my LCD to do the traditional power law (+BLC) curve without dragging out the colorimeter to get the 10% point.
I originally planned to profile my D2 (which for the record was reading ~4 dE "off" from the i1pro) and redo my BT1886 curve, but I haven't gotten around to that yet.
From all the horror stories, I expected the D2 to be much worse than it was. wink.gif
Edit: I should clarify that the i1pro said the previous D2 run was off by ~4 dE (not enough green.) For those that care about such things. smile.gif
post #17 of 23 Old 09-13-2012, 07:07 AM
Liked: 589
What it doesn't address is whether or not its software based similar to the i1pro2. I think it's more likely that they'd use the same logic on both.
JimP is offline
post #18 of 23 Old 10-05-2012, 06:17 PM - Thread Starter
Iron Mike's Avatar
Quoted: 64 Post(s)
Liked: 408
I can definitely confirm that my i1D3 needs a warm up time on screen (about 30 min)... I did a full 125 point calibration with the Lumagen on my RPTV yday and the initial readings by the i1D3 were bogus (4-5 dE off), it stabilized later...
post #19 of 23 Old 10-05-2012, 06:27 PM
Chad B's Avatar
Quoted: 496 Post(s)
Liked: 1195
That's surprising. I've not known an RPTV screen to get warm. Was the meter colder than room temperature at the beginning?
Chad B is online now
post #20 of 23 Old 10-05-2012, 06:47 PM - Thread Starter
Iron Mike's Avatar
Quoted: 64 Post(s)
Liked: 408
hmmm, hard for me to say but I don't think so - i mean I didn't have the i1D3 in the freezer... ;-) btw Chad, the RPTV I'm referring to is the model you used to own as well: Sony KDS-R60XBR1... ;-)
in my scenario yday, the display was warmed up (3-4 hours), I put on the i1D3 and ran a verification report again in Calman 5 on a calibration I did a day earlier... numbers were completely off (4-5 dE) from what I wrote down a day earlier... I thought I had an issue with the Lumagen... after checking everything and coming back to it 20 min later or so, I ran the verification again and numbers now matched from a day earlier (+- 0.2 dE for the usual inaccuracy in repeatability with colorimeters)...
I will definitely from now on make test readings with the i1D3 before starting to calibrate to make sure it returns consistent, stable, accurate readings...
post #21 of 23 Old 10-06-2012, 07:15 PM
Liked: 589
Iron Mike,
Could it be that just having the i1D3 connected to your laptop with it on runs enough power through it, that in 20-30 minutes it stabilizes? That's what I'm finding using Chromapure and didn't know if Calman performed the same way.
JimP is offline
post #22 of 23 Old 10-06-2012, 09:19 PM - Thread Starter
Iron Mike's Avatar
Quoted: 64 Post(s)
Liked: 408
I don't think that the power stabilizes over a while on a USB connection - it should be consistent from the moment you plug it in... will make more tests later tonight when I do another calibration...
post #23 of 23 Old 10-07-2012, 03:01 PM
<^..^>Smokey Joe's Avatar
Quoted: 61 Post(s)
Liked: 91
Light is radiation energy, transform it by sensor absorbing the energy and you have heat.
Masterpiece Calibration Ltd
Christchurch NZ
<^..^>Smokey Joe is offline
Reply Display Calibration
