Problem with gamma who dives. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 37 Old 09-13-2012, 05:17 AM
airscapes's Avatar
Quoted: 357 Post(s)
Liked: 289
You are as good as you can get with that meter. Remember there is a tolerance of +-2% with that meter So just because things look perfect, don't mean they are. You will need to spend $8-$10,000 USD for a meter that can get you close to perfect, but in the end, the display is a consumer display and is FAR from perfect. Those tiny little bibs in brightness at one stimulus level is not going to be seen when you watch content. You did a great job, now sit back and watch some movies!
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #32 of 37 Old 09-13-2012, 05:59 AM
1forsnow's Avatar
Quoted: 41 Post(s)
Liked: 54
bits-
are you using the "pattern autosense" feature within calman? also what is the delay set for? your panel might need a longer delay for the pattern to settle a bit before the meter takes a reading. just a thought....
1forsnow is offline
post #33 of 37 Old 09-13-2012, 06:39 AM - Thread Starter
Bits123's Avatar
I have The default settings in calman.
I mesure every level for lika 4 times so that Shod be good right?
I dont use autosens.
Bits123 is offline
post #34 of 37 Old 09-13-2012, 08:15 AM
Rolls-Royce's Avatar
Quoted: 254 Post(s)
Liked: 391
Originally Posted by Bits123 View Post
If I deside to fix gamma at 50IRE to 100 IRE 'll I mess the gamma upp at 50 IRE to 0 IRE?
I just want it perfect.
Honestly, when you factor in meter and display repeatability, an unvarying 'perfect' from run to run really isn't possible. Your display is good enough as it is now.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #35 of 37 Old 09-13-2012, 08:25 AM - Thread Starter
Bits123's Avatar
Ok, then i calibrate The cms to night.
I upload The results to night
Does some one know how i lock The expert settings at à lg?
Bits123 is offline
post #36 of 37 Old 09-13-2012, 09:03 AM
chunon's Avatar
Quoted: 2195 Post(s)
Liked: 1901
65C6 OLED
Time Warner Cable/Panasonic UB900/ Roku Premiere +/Sony S780 Soundbar/Harmony 650
Calman Enthusiast/Chromapure Standard with Auto Cal
chunon is offline
post #37 of 37 Old 09-13-2012, 11:36 AM - Thread Starter
Bits123's Avatar
Now I have been calibrated the CMS and holly sh*t it was totaly of like every were.
I did it like this:
I tryd to have all the primary colurs at the same Lumiance, is that right?
Then att det secoundary colour I tryd to have the all at the same luminance, thats right?
What do you think?
I could the red and green even more down in lumiance but not the blue colour, so did I do the right thing to have it at the same lumiance?
Edit:
New mesurement and calibration CMS:
After calibration when I did mesure it:
What do you think?
Bits123 is offline
Reply Display Calibration
