CalMAN 5 Home Video released - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 40 Old 09-23-2012, 09:38 AM - Thread Starter
derekjsmith's Avatar
Liked: 116
Originally Posted by samhain1 View Post
Hi there,
What facilities are available under the evaluation. I have used Calman 4 Commercial before and it had everything switched on. Is the evaluation fully open to all home user functionality including the multipoint CMS.
I have the radiance Mini 3d which I love and used the 4 to auto calibrate that and it worked beautifully. Presumably I need a firmware update for the Lumagen too?
The downloadable version of CalMAN 5 by default comes up in evaluation mode with most features enabled except you can't connect to a real meter just the internal simulated meter. We do have expiring demo licenses for professionals when they have been issued by our sales staff.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #32 of 40 Old 09-23-2012, 02:13 PM
drparker151's Avatar
Quoted: 54 Post(s)
Liked: 34
I'm having a problem with both RC1 and RC2 and the DPG2000. I can't get it to sync. It keeps going back to the home screen of the WD Live box and then gets lost. If I manually move it to the 90% pattern it will successfully advance to 100% pattern. But If I then click on the 90% box on the lower left it jumps back to the home screen on the WD Live and gets lost.
I'm new to the software and the DPG so It could be me.
drparker151 is offline
post #33 of 40 Old 09-23-2012, 02:38 PM
praz's Avatar
Liked: 26
Please see the thread linked below at SpectraCal. It contains both the proper configurations as well as known issues and the fixes.
http://www.spectracal.com/forum/viewtopic.php?f=94&t=4128
praz is offline
post #34 of 40 Old 09-23-2012, 03:01 PM
Quoted: 54 Post(s)
Liked: 34
Perfect, thanks for the link! now I'll go check firmware and change USB stick.
post #35 of 40 Old 09-26-2012, 11:38 AM
dannoooo's Avatar
Hello , Can anyone tell me the proper way to install drivers/software using an I1 Display pro with Calman5 On a Windows OS? Forum says remove all Xrite software and Xrite says to use their software. I just want to make sure my readings are correct
Also, anyone know if I am supposed to Calibrate or initialize the I1 Display Pro prior to use?
Many Thanx in advance!
dannoooo is offline
post #36 of 40 Old 09-26-2012, 11:52 AM - Thread Starter
Liked: 116
Yes you can uninstall and the X-Rite software or disable the X-Rite services. The i1 Display Pro is a HID based device so windows already has the devices driver built in no reason to have to install anything else.
Derek
post #37 of 40 Old 09-27-2012, 07:11 AM
dannoooo's Avatar
Thank You Derek
I will give it a try...
Any Idea on how to Calibrate my I1 Display pro without another meter or whether I need to do it at all?
dannoooo is offline
post #38 of 40 Old 10-02-2012, 09:54 AM
dannoooo's Avatar
Hello Derek
Is there a pdf user manual for Calman 5 that i can download?
dannoooo is offline
post #39 of 40 Old 10-02-2012, 10:09 AM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 334
Hello Derek
q
The most complete manual is the in application help (chm file). You can open it from the help entry in the main menu.
sotti is offline
post #40 of 40 Old 10-02-2012, 12:08 PM - Thread Starter
Liked: 116
Originally Posted by sotti View Post
q
Also the Introduction and Tutorial workflows.
Derek
Reply Display Calibration
