Colormunki vs i1 basic pro? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 09-15-2012, 07:58 AM - Thread Starter
Bits123's Avatar
Bits123 is offline
post #2 of 27 Old 09-15-2012, 08:17 AM
sotti's Avatar
Quoted: 330 Post(s)
Liked: 332
The i1 Pro is a little more accurate.
Quite a bit of the internals is shared between the two meters.
If you're measuring print or other reflective measurements the i1 Pro has a much better internal lamp. For Emissive measurements (measuring displays) they are much closer to each other.
Probably the big difference for our use is the i1 Pro has glass optics while the Munki has plastic. You've seen what clear plastic looks like in 3 or 4 years compared to glass.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #3 of 27 Old 09-15-2012, 09:58 AM - Thread Starter
Bits123's Avatar
Then the i1 basic pro it is.
Bits123 is offline
post #4 of 27 Old 09-15-2012, 10:06 AM - Thread Starter
Bits123's Avatar
Do i1 pro need to calibrat against black before using?
Bits123 is offline
post #5 of 27 Old 09-15-2012, 10:32 AM
sotti's Avatar
Quoted: 330 Post(s)
Liked: 332
both the munki and i1 Pro need periodic dark cals
Joel Barsotti
SpectraCal
sotti is offline
post #6 of 27 Old 09-16-2012, 02:37 PM - Thread Starter
Bits123's Avatar
Ok, does it need to be warmd up?
If yes, how long time?
Bits123 is offline
post #7 of 27 Old 09-16-2012, 02:43 PM
sotti's Avatar
Quoted: 330 Post(s)
Liked: 332
Not really, that's what the periodic dark cals take care of.
Joel Barsotti
SpectraCal
sotti is offline
post #8 of 27 Old 09-18-2012, 09:53 AM - Thread Starter
Bits123's Avatar
How do i dark cal it? Do i use The White tile who come with The i1pro?
Bits123 is offline
post #9 of 27 Old 09-18-2012, 10:00 AM
derekjsmith's Avatar
Liked: 116
Yes or just a dark surface for the i1Pro. The i1Pro 2 requires it's dark cal on the cal plate only.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #10 of 27 Old 09-18-2012, 11:28 AM
airscapes's Avatar
Quoted: 371 Post(s)
Liked: 297
The way I was told to do the i1pro was, in calman set the button action to initialize. Then when you need to do a dark reading you put your finger over the hole and press the button on the side of the i1pro.. done. Very fast and simple to do once you get rolling in your calibration, takes all of 3 seconds.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #11 of 27 Old 09-18-2012, 11:50 AM
sotti's Avatar
Quoted: 330 Post(s)
Liked: 332
Ever put a flash light up to your finger?
I'd use something more opaque.
Joel Barsotti
SpectraCal
sotti is offline
post #12 of 27 Old 09-18-2012, 12:56 PM - Thread Starter
Bits123's Avatar
I did get my i1Pro today, and the certification was made 5 october 2010 and it expired 1 May 2012.
But it's new so do I need to check it out or can I just use it?
It shod be more accurat then my 1 year old i1display pro 3 right?
The cert:
Bits123 is offline
post #13 of 27 Old 09-18-2012, 01:08 PM
airscapes's Avatar
Quoted: 371 Post(s)
Liked: 297
?? If you tv is putting out that much light you would be blind, don't you think?
Doug
post #14 of 27 Old 09-18-2012, 02:06 PM
sotti's Avatar
Quoted: 330 Post(s)
Liked: 332
The cert:
Yes indeed. Since spectros don't have filters, they don't really age just sitting around in a box like a colorimeter. Nearly all the i1 Pro's we get in for re certification pass with flying colors.
If it really does bother you, I'd contact whoever sold it to you and complain. Getting shipped a meter with an expired certificate is a legitimate gripe, but I wouldn't worry too much about the accuracy.
Joel Barsotti
SpectraCal
sotti is offline
post #15 of 27 Old 09-18-2012, 02:21 PM - Thread Starter
Bits123's Avatar
Amazon dont have it left in stock, so no.
But I can use it, I can re-calibrate it against a Jeti or something later.
Bits123 is offline
post #16 of 27 Old 09-18-2012, 02:30 PM
sotti's Avatar
Quoted: 330 Post(s)
Liked: 332
Re-calibrations with spectros are a bit different than creating profile.
But I would use it and wouldn't even worry about it.
Joel Barsotti
SpectraCal
sotti is offline
post #17 of 27 Old 09-18-2012, 02:41 PM - Thread Starter
Bits123's Avatar
Shod I store the i1 pro in a plastic bag and then i the original bag or can I just store it in the bage without the plastic bag around it?
Which one is best?
I guess that it can moisture in the bag right?
Bits123 is offline
post #18 of 27 Old 09-18-2012, 03:08 PM
sotti's Avatar
Quoted: 330 Post(s)
Liked: 332
Which one is best?
Moisture isnt' a huge issue with the i1 Pro, but it's always better to take better care of it.
Mine has been sitting on my desk for 3 years.
Joel Barsotti
SpectraCal
sotti is offline
post #19 of 27 Old 09-18-2012, 03:25 PM
slb
slb's Avatar
Joel,
Has anyone a SpectraCal had an opportunity to re-evaluate a ColorMunki spectro after a significant period of time? Mine is just over a year old, and I'm curious about its long term stability. I currently use it to generate a profile for my D3.
slb is offline
post #20 of 27 Old 09-18-2012, 03:35 PM
PlasmaPZ80U's Avatar
Quoted: 2194 Post(s)
Liked: 659
Regarding dark readings for the original i1 Pro, after doing the inital dark reading at the start of the calibration session, how far can you go before you really need to do another dark reading? (on a LED-LCD flat panel used in contact mode)
Current Setup REW FR measures
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Sony SS-CS5 Surrounds, Cambridge S20 Rear Surrounds, Rythmik LV12R; PS4 Slim, Xbox One, Xfinity X1
PlasmaPZ80U is online now
post #21 of 27 Old 09-18-2012, 03:35 PM
sotti's Avatar
Quoted: 330 Post(s)
Liked: 332
Originally Posted by slb View Post
Joel,
I don't know that we have. I'll ask around when I have the chance.
Joel Barsotti
SpectraCal
sotti is offline
post #22 of 27 Old 09-18-2012, 03:50 PM
Liked: 116
Joel,
Has anyone a SpectraCal had an opportunity to re-evaluate a ColorMunki spectro after a significant period of time? Mine is just over a year old, and I'm curious about its long term stability. I currently use it to generate a profile for my D3.[/quote
We use them in the rental program so Darrell should know.
Derek
post #23 of 27 Old 09-18-2012, 04:29 PM
sotti's Avatar
Quoted: 330 Post(s)
Liked: 332
Depends if you are going to be measuring stuff below about 5 cd/m.
If you are going to measure things that are dim, then probably 10-15 minutes.
Joel Barsotti
SpectraCal
sotti is offline
post #24 of 27 Old 09-18-2012, 05:43 PM
slb
slb's Avatar
Anything you could share would be great. BTW, I'm really liking CalMan 5 so far. I'm going to try an autocal on my Duo soon and see how it compares to my manual CalMan 4 results.
slb is offline
post #25 of 27 Old 09-18-2012, 07:29 PM
turbe's Avatar
Liked: 96
Joel,
Though I'm not SpectraCaI, I have, with 7 ColorMuni Spectros now..
There is no difference, all seven are from the original release
Purchase your Colormeter as your only meter, lets have this conversation again in a few years smile.gif
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #26 of 27 Old 09-18-2012, 09:49 PM
Liked: 659
In my case, under 5 cd/m only includes 20% gray (I do 9-step grayscale with the spectro). So, I should be fine from 30% on up.
post #27 of 27 Old 09-19-2012, 10:30 AM
slb
slb's Avatar
Thanks Turbe. Surprisingly, except for luminance, my D3 and ColorMunki agree fairly well on my GT50 plasma and Samsung CCFL LCD.
slb is offline
Reply Display Calibration
