autocal with calman5 - AVS Forum | Home Theater Discussions And Reviews
Old 09-16-2012, 05:29 AM - Thread Starter
allec's Avatar
somebody has a step by step how to autocal a panasonic gt/vt dt/wt with calman5
i am a newbie and dont know how to
allec is offline
Old 09-16-2012, 08:46 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Walk through the introduction workflow.
That will show you how to connect to hardware.
Once you're connected to a pattern source and the display, just go to a grayscale step an press the autocal button.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
Old 09-16-2012, 11:16 AM
fredman2005's Avatar
As I see the patterns in V5 Autocal are coming from an external source and are no longer inside the program, as in V4. So I don´t need to connect HDMI from my laptop to the TV. Is this ok and can I then let it prompt to pattern change?
fredman2005 is offline
Old 09-16-2012, 11:23 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Yes prompting for pattern change works fine, with DVD based patterns.
If you do want to use your computer for a pattern generator, inside CalMAN there is a button on the Pattern source tab to open a floating pattern window.
Joel Barsotti
SpectraCal
sotti is offline
Old 09-16-2012, 11:26 AM
Thanks Joel,
but I prefer an external source, fewer cables running thru the living room.
Old 09-16-2012, 11:28 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Thanks Joel,
Absolutely.
Just wanted you to know that it was still an option. We tried to make sure we didn't loose any functionality in CalMAN 5, that was in v4.
Joel Barsotti
SpectraCal
sotti is offline
Old 09-16-2012, 05:51 PM
I try tonight a Calibration with HT Enthusiast and my VT50E, probe was an i1Display Pro. But neither the HT-Enthusiast nor the HT-Advanced workflow has the Autocal-Button enabled.
Is it a bug or is it the user?
Old 09-16-2012, 06:48 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
It's a bug, the AutoCal button was disabled by mistake.
The quick analysis workflow correctly has gamut AutoCal enabled.
Joel Barsotti
SpectraCal
sotti is offline
Old 09-17-2012, 12:21 AM
Old 09-17-2012, 03:18 AM
derekjsmith's Avatar
Liked: 116
Should be mid week for a CalMAN 5 Home Video RC2.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
Old 09-17-2012, 04:59 AM
rachmat-d's Avatar
Derek,
Can you help me with the license.
I havent got any email regarding the V5.
rachmat-d is offline
Old 09-17-2012, 09:28 AM
Liked: 116
Originally Posted by rachmat-d View Post
Derek,
Sure if you could email all your contact info including your CalMAN 4 license info - derek@spectracal.com
Derek
