i1pro hcfr plasma measurements - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 09-17-2012, 02:51 PM - Thread Starter
delphiplasma's Avatar
Quoted: 12 Post(s)
Hi,
Just wondered if plasma screens can be calibrated using the above set-up? Or has the meter got a built in infra red filter?
delphiplasma is offline
post #2 of 7 Old 09-17-2012, 03:13 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Originally Posted by delphiplasma View Post
Hi,
i1 Pros don't need filters, they read the spectrum and know how much weight each wavelength contributes to the measurement.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #3 of 7 Old 09-18-2012, 12:17 PM - Thread Starter
Quoted: 12 Post(s)
Thanks. What I meant to say was does the i1pro have built in infra red correction for plasma display calibration?
post #4 of 7 Old 09-18-2012, 12:29 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
There is no such thing.
The color matching function is what gates infrared's contribution to the X value of the XYZ measurement. If infra-red effects a colorimeter it's because it has bad filters. Spectro's don't have this issue at all. They see the infrared, but know it is infrared.
Joel Barsotti
SpectraCal
sotti is offline
post #5 of 7 Old 09-18-2012, 02:15 PM - Thread Starter
Quoted: 12 Post(s)
Thanks. I was comparing my i1lt with the i1pro. The i1pro saw the plasma red output down by around 5%. The LT was set to 'plasma' for it's reading and measured red on the line. I suppose I need to do my tests using an LCD display. Many thanks sitting for the well constructed response
post #6 of 7 Old 02-13-2013, 09:08 AM
Quoted: 1394 Post(s)
Liked: 589
What did you find out?
JimP is offline
post #7 of 7 Old 02-13-2013, 12:27 PM - Thread Starter
Quoted: 12 Post(s)
Hi,
I never managed to check with LCD. However, I managed to compare with a broadcast monitor which had been professionally set up. A side by side greyscale ramp showed that the ione pro was more correct. The lt la lacking red
Hope that helps?
Reply Display Calibration
