Blue is magenta tinted after iscan Duo auto cal - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 09-29-2012, 08:24 PM - Thread Starter
goro007@ozemail.'s Avatar
Hi guys - I hope someone can help me with this strange problem.
I have calibrated my Pioneer Kuro PDP508 (Australia) using the iscan Duo and I1 Display2, Autocal and interactive workflows (PS3 source). No matter what I do I always end up with a blue with a 'magenta'/pink tint. The calibrated blue point is inside the CIE chart (Red and Green and secondaries all with DE's <2). The delta for blue is 5.76. If I manually move the point using interactive it will give me a visual 'blue' but I can't get the delta E any lower than 15 at best. Should the Duo be able to give me a more accurate 'blue' (i.e. low Deltas etc) or is this a problem with the Pioneer? My results without the Duo seems overall more visually acceptable.
Cheers
Goro007
goro007@ozemail. is offline
post #2 of 14 Old 09-29-2012, 09:15 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Cheers
Goro007
Could you post some charts for your results?
My guess is that your blue is undersaturated, so a dE of 5 may be as cloas as you can get.
Also what software are you using?
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #3 of 14 Old 09-29-2012, 09:23 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
The I1D2 is doing it if you have not profied it.
What city are you in?
Loving D65
CalWldLif is offline
post #4 of 14 Old 09-30-2012, 02:38 AM - Thread Starter
Hi guys - thanks for the response.
I'm in Melbourne Aus.
I'm running Calman 4.6.4 (latest version).
Here are the charts.
AutoCal version which gives the magenta blue
Autocal.jpg 123k .jpg file
Manual correction which gives way off delta
Gamma.jpg 21k .jpg file ColorGamut.jpg 69k .jpg file RGB.jpg 69k .jpg file Grayscale.jpg 79k .jpg file
CalWldLif how do you profile the meter?
Thx Goro007
ID:	64006   Click image for larger version
ID:	64007   Click image for larger version
ID:	64008   Click image for larger version
ID:	64009   Click image for larger version
post #5 of 14 Old 09-30-2012, 04:29 AM
derekjsmith's Avatar
Liked: 116
Thx Goro007
From the charts it looks like your blue gamut is well under luminance. The white limiter control on the Duo needs to be lowered. This can be done via thr Duo's OSD or in CalMAN DDC. SInce you have CalMAN v4 you should be using the Duo workflow which includes a step for adjusting the white limiter.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #6 of 14 Old 09-30-2012, 05:09 AM - Thread Starter
Hi Derek
Where exactly on the Duo do I find the 'white limiter'?
Goro007
post #7 of 14 Old 09-30-2012, 05:34 AM
Liked: 116
Hi Derek
Goro007
From the Duo OSD: Output Setup > CMS > Color Gamut > White-Y (note that is the big Y not small) reduce it to -0.2
From CalMAN DDC: 100% White Y (again this is the big Y) reduce it to -20
Remeasure your Blue gamut luminance
Derek
post #8 of 14 Old 09-30-2012, 09:45 AM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
Cheers
Goro007
Thx Goro007
The D2 color meter can read red and blue wrong.
They work well when profiled against a spectro
In Calman there is a process for creating the profile.
But you need a reference meter to do it.
f you were close to me I could make you a profile.
Sorry.
Loving D65
post #9 of 14 Old 09-30-2012, 10:01 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
If you purchased CalMAN 4 within the last year, you are eligible for an upgrade to CalMAN 5, which does a much better job with gamut AutoCal.
Joel Barsotti
SpectraCal
sotti is offline
post #10 of 14 Old 10-01-2012, 05:31 AM - Thread Starter
Thx Derek. I haven't had the chance to try this yet. Should I then need to recalibrate the whole color gamut?
Sorry.
Thx anyway. I might look at upgrading.
post #11 of 14 Old 10-07-2012, 04:30 AM - Thread Starter
Hi guys. Thanks for all the suggestions.
I upgraded to Calman 5. It's really made a big difference. Straight up my my gamut luminance has improved. Blue is much better at DE of under 5. I'm still going to try and get this down (I'm a perfectionist) but I'm pretty happy as is.
Derek what does changing the White Y do?
Goro007
ISF Night DVDO.pdf 304k .pdf file
post #12 of 14 Old 10-07-2012, 07:22 AM
1forsnow's Avatar
Quoted: 41 Post(s)
Liked: 54
^^^^ according to your report, blue is undersaturated. There isnt much calman nor the Duo can do about that because they cant add color. Nice job on everything else.....
1forsnow is offline
post #13 of 14 Old 10-07-2012, 09:32 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Yes but CalMAN 5 has some very specific code to handle undersaturated primaries where CalMAN v4 does not. CalMAN v4 AutoCal can do bad things with undersaturated primaries.
Joel Barsotti
SpectraCal
sotti is offline
post #14 of 14 Old 10-09-2012, 05:59 AM - Thread Starter
Hi Joel - really great effort on version 5. As from my charts, a great result achieved within an hours work. smile.gif
Reply Display Calibration
