HD350 - Calibrated but need help with gamma curve! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-30-2012, 07:33 PM - Thread Starter
DamoSyzygy's Avatar
Heya all.
Ive been calibrating my JVC HD350 and everything is getting close regarding colour/greyscale/bright/cont but when looking at the gamma graph it seems too high at 20% (around 2.5) and moves on an almost linear downward gradient to end up too low (at around 1.7) by 90% white.
What control needs to be adjusted to flatten the gradient of the gamma more evenly across the board?
Any help would be greatly appreciated
DamoSyzygy is offline
post #2 of 3 Old 10-03-2012, 03:16 PM
Nudgiator's Avatar
Quoted: 32 Post(s)
Liked: 35
You should use the gamma equalizer of the HD350. But it's a little bit tricky to use is correctly.
Source: Samsung UBD-K8500 (UHD), Panasonic BDT-110 (BD), Toshiba HD-XE1 (HD-DVD), Vantage VT-1S (SAT), Kathrein UFS-924 (SAT)
Calibration: LightSpace CMS, SpaceMan, SpaceMatch, CalMAN 5 Prof., Chroma Pure, Lumagen Radiance Pro 4446, Chroma 5, SpectraCal C6, EODIS3, i1 pro 2, Klein K10-A
Target: Panasonic TX-P65VTW60 (Plasma TV)
Sound: Yamaha RX-V2067 (AVR), Teufel Theater LT 3 (Speaker)
Nudgiator is offline
post #3 of 3 Old 10-04-2012, 02:49 AM - Thread Starter
DamoSyzygy's Avatar
Thanks for the reply Nudg.
I managed to get it tracking close to 2.2 all the way up, but to do so I had to put the Lens apertur on 3 and reduce the contrast heavily.
Everything is reading pretty close to correct, but I now have quite a low FtL, reading, around 10.
Looks ok to my eyes, perhaps a little washed out as I had to reduce the colour significantly to compensate for the HD350's incessant need to oversaturate green and blue.
I have cleaned the lenses after reading about the fogging issue on these projectors, and I'm sitting about 4m away and throwing onto a 110" screen.
Cant seem to get the screen any brighter though - maybe I need a new lamp!
One powerball and Ill be buying a Lumagen Radiance!
Reply Display Calibration
