How to calibrate at 75% saturation using calman - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-01-2012, 09:20 AM - Thread Starter
jbrady3324's Avatar
Quoted: 20 Post(s)
I am a little confused on how to set this up. Currently, under options I have 75% stimulus selected, but I can't figure out how to get calman to change the target values to 75% saturation. Maybe I am just thinking/looking at this the wrong way.
Can anyone provide some steps on how to calibrate at 75% saturation using Calman?
Pioneer KRP-500m
Panasonic 65VT50
M&K LCR-750s Fronts and Center
M&K M-4T Surrounds
X-Rite i1pro
jbrady3324 is offline
post #2 of 9 Old 10-01-2012, 09:56 AM
sotti's Avatar
Quoted: 330 Post(s)
Liked: 332
Right now it's only been added to the Quick Analysis workflow.
Once you open up that workflow, you can open the left panel to jump around to the different steps, and you'll want to pick saturation sweeps. Once you've selected that, you can change which saturations you want to measure by clicking the gear icon on the right.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #3 of 9 Old 10-01-2012, 10:19 AM - Thread Starter
jbrady3324's Avatar
Quoted: 20 Post(s)
Is this only for Calman 5?
Pioneer KRP-500m
Panasonic 65VT50
M&K M-4T Surrounds
X-Rite i1pro
post #4 of 9 Old 10-01-2012, 11:05 AM
sotti's Avatar
Quoted: 330 Post(s)
Liked: 332
Yes.
Joel Barsotti
SpectraCal
sotti is offline
post #5 of 9 Old 10-01-2012, 12:34 PM - Thread Starter
jbrady3324's Avatar
Quoted: 20 Post(s)
How is this done in ColorHCFR?
Pioneer KRP-500m
Panasonic 65VT50
M&K M-4T Surrounds
X-Rite i1pro
post #6 of 9 Old 10-01-2012, 11:37 PM
HDTVChallenged's Avatar
Liked: 215
With considerable effort and with the aid of various Excel spreadsheet based tools, which are floating around somewhere in this forum ...
HDTVChallenged is offline
post #7 of 9 Old 10-02-2012, 02:34 AM
dominickwok's Avatar
This post outlines the detailed steps and includes the spreadsheet for calibrating using 75% saturation method with ColorHCFR:
http://www.avsforum.com/t/1134710/epson-calibration-guide-1080-1080ub-6100-6500ub-7500ub#post_16166537
dominickwok is offline
post #8 of 9 Old 10-02-2012, 05:24 AM - Thread Starter
jbrady3324's Avatar
Quoted: 20 Post(s)
Thank you. I was hoping that was all built into ColorHCFR. Maybe I will try Chromapure
Is it possible to do this in calman by eye? Since we know the target values for 75% saturation, couldn't eye just take the measurements and rely on the numbers to figure out if I am close?
Pioneer KRP-500m
Panasonic 65VT50
M&K M-4T Surrounds
X-Rite i1pro
post #9 of 9 Old 10-02-2012, 07:11 AM
sotti's Avatar
Quoted: 330 Post(s)
Liked: 332
You can always do that.
But if you have CalMAN v4, the cost of upgrading to CalMAN 5 is minimal, and if you purchased in the last year Free!
Joel Barsotti
SpectraCal
sotti is offline
Reply Display Calibration
