Can you calibrate a 3400k monitor, so it doesn't look orange? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-01-2012, 02:37 PM - Thread Starter
sefmiller's Avatar
Flux software moves the color temperature to 3400k. Can you calibrate this temperature, so the screen doesn't look orange?
sefmiller is offline
post #2 of 9 Old 10-01-2012, 03:02 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
That's like asking if you can make orange look white.
3400K is a very reddish orange shade.
The only way to make the screen look white is to not calibrate to 3400K, but use a bluer color like D55 or D65.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #3 of 9 Old 10-01-2012, 03:33 PM
GeorgeAB's Avatar
Quoted: 135 Post(s)
Liked: 240
That setting of white point is typically used when video or computer displays are part of a television program set (visible by the camera) which uses studio lighting of that same color temperature. If a normal white point is used for the display on the set, it would look EXTREMELY blue when the program recording is finally viewed. How are you using the monitor?
Best regards and beautiful pictures,
G. Alan Brown, President
CinemaQuest, Inc.
A Lion AV Consultants affiliate
"Advancing the art and science of electronic imaging"
GeorgeAB is offline
post #4 of 9 Old 10-04-2012, 01:08 PM - Thread Starter
sefmiller's Avatar
I use the monitor to play games watch video and browse the internet.
I like the flux software because of it claims to improve quality of sleep.
Here is a link:
http://stereopsis.com/flux/
post #5 of 9 Old 10-04-2012, 01:35 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
I like the flux software because of it's effects on sleep.
Do you have a link for the software? I've never heard of it.
Joel Barsotti
SpectraCal
sotti is offline
post #6 of 9 Old 10-04-2012, 01:42 PM
GeorgeAB's Avatar
Quoted: 135 Post(s)
Liked: 240
Then you need to calibrate your monitor for a D65 white point. Your second sentence makes no sense to me. Perhaps you could rephrase the statement.
GeorgeAB is offline
post #7 of 9 Old 10-04-2012, 06:05 PM - Thread Starter
sefmiller's Avatar
I've rephrased the post now
post #8 of 9 Old 10-04-2012, 06:28 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
The point of the software is to simulate sunset.
You can't have a blue sunset.
Either you live with the orange or you disable the software. The software's explicit purpose is to make your screen orange.
Joel Barsotti
SpectraCal
sotti is offline
post #9 of 9 Old 10-04-2012, 07:00 PM
GeorgeAB's Avatar
Quoted: 135 Post(s)
Liked: 240
Here is a link:
The electronic display industry standard recommendation for over a half century to reduce or eliminate eye strain has been: reduce screen brightness when the room is darkened, avoid screen reflections, and implement bias lighting. I haven't ever heard of the science behind the technique described at the link you provided. The consequence of the dramatically lower white point you have already identified. You get to choose which is your preference- sleeping better after late night viewing (I find this questionable), or having all the colors on the monitor seriously distorted.
GeorgeAB is offline
Reply Display Calibration
