Questions about Spectracal Products - AVS Forum | Home Theater Discussions And Reviews
post #1 of 38 Old 10-01-2012, 03:33 PM - Thread Starter
TomButera's Avatar
This site has been a huge help in getting me interested in calibrating televisions. I am in the market to purchase equipment from Spectracal. I am however not sure which product I should purchase. I have $2000 to work with.
I have questions and would like to ask the community which would be the best way to go.
I found this package on Spectracal's website CalMAN DIY Software w/ SpectraCal C6 & DPG-1400 Pattern Generator that is on sale for around $1500. I also saw they are selling calMan 5 expert for around $1500 and buy calMan 5 for around $400.
From what I have read I can connect a laptop to the HDTV and use calMan 5 to do auto calibration.
I have never owned or purchased this type of equipment before. Which would be a better bet for me to get my hands dirty with calibration and allow me to do this for a living.
Any and all advice/ suggestions are graciously accepted.
Thank you.
TomButera is offline
post #2 of 38 Old 10-01-2012, 03:52 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
If you're a home user you want our CalMAN 5 Home Theater product, to use our software for business use you'd want CalMAN 5 for Business.
You can always upgrade your license from home use to professional use.
For hardware to start out with the C6 is a great meter that scales to professional use. The DPG on the other hand is a good home use pattern generator, but isn't considered a professional generator.
You can start off using even a free pattern disc as the pattern source. You can add an IR control to automate disc based players, then move into real pattern generators later.
TomButera likes this.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #3 of 38 Old 10-01-2012, 04:01 PM - Thread Starter
TomButera's Avatar
Awesome, thanks for the prompt reply. Currently I have spent countless hours using the AVSHD that I found on this site. That in conjunction with C6 and calMan 5 home would be the way to go?
post #4 of 38 Old 10-01-2012, 04:05 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
That would be a relatively inexpensive way to start down the path yes.
Our home product comes in 3 flavors, Basic, Control, and Enthusiast. You'd probably want to start with at least Control if not Enthusiast.
Joel Barsotti
SpectraCal
sotti is offline
post #5 of 38 Old 10-01-2012, 04:23 PM
CalWldLif's Avatar
Quoted: 248 Post(s)
Liked: 69
Thank you.
depends on what TV.
Get User feed back.
Loving D65
CalWldLif is offline
post #6 of 38 Old 10-12-2012, 07:55 PM - Thread Starter
TomButera's Avatar
I am continuing this thread so I don't have many different open threads.
I received my Spectracal C6 today and downloaded calMan5 enthusiast. As I am just familiarizing myself with the software please excuse my ignorance. My background is in IT and I love fiddling with things to see how they work and to make them as best as possible.
I am using my Bravia 46" 1080p connected to a ps3 via hdmi. For the pattern generator I am using AVSHD disc that I found on this forum.
Before using the C6 and spectracal enthusiast I used my eyes plus AVSHD to do a basic calibration on my tv. It looked pretty good. Here are the specs from that first run.
Backlight 8
Picture 85
Brightness 51
Color 55
Hue 0
Color temp neutral
Sharpness 3
No change to any of RGB.
Today I reset my tv to factory settings and began my journey with spectracal. I have the results of the calibration only printed out as screen shots, but I do not know how to read the results.
I am also not sure if I did all of the steps properly. I would like if possible to run what I did past other members on the forum in hopes of sorting this out and increasing my understanding. I will send the document with my first run results with calMan 5 if requested.
Lastly I saw that the AVSHD was designed for calMan 4, not 5. Does this impact what I am trying to do. If so which\what pattern generators would be excellent to start out with, price up to $600 or $700.
Any and all replies are welcome and thank you for your time.
Tom
post #7 of 38 Old 10-12-2012, 09:18 PM
Quoted: 1394 Post(s)
Liked: 589
Tom
Post your reports so we can take a look and comment.
Is your Bravia an LCD flat panel?
JimP is offline
post #8 of 38 Old 10-12-2012, 09:25 PM - Thread Starter
TomButera's Avatar
My Bravia is an LCD.
calibration first try.doc 846k .doc file
Sorry for the attachment in a word document. I forgot to save the settings as a report. I did take screen shots.
post #9 of 38 Old 10-13-2012, 11:07 AM
Rolls-Royce's Avatar
Quoted: 244 Post(s)
Liked: 369
Your AVSHD disc will work just fine with CalMAN 4 or 5. You can choose "generic calibration disc" or even AVSHD but use the player's remote to select the patterns. Use of a particular version of AVSHD is only required if you use the USB-UIRT device, since other versions have somewhat different chapter and pattern numbers than those the USB-UIRT config file is calling for.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #10 of 38 Old 10-13-2012, 11:20 AM - Thread Starter
TomButera's Avatar
Thank you, this is a trip figuring out how this works together. Fun but hard.
On the calMan options do you have any preference for which option to choose?
post #11 of 38 Old 10-15-2012, 11:45 AM
Joshua Quain's Avatar
Hi Tom, a couple of the CalMAN 5 workflows have been designed around the AVSHD 709 calibration pattern disc. If you open up the HT Basic Calibration workflow in CalMAN 5 (RC4) for home video calibration use, you will find that the examples in each layout are from the patterns on that disc. And if you enable pattern prompts from the Source drop down-tab on the top of the application, each measurement step in the video calibration process will provide a pop-up and tell you which pattern to use on that specific disc.
Hope this helps. Thank you for using CalMAN 5.
Joshua Quain
www.spectracal.com
Joshua Quain is offline
post #12 of 38 Old 10-15-2012, 11:48 AM
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 562
Which workflow(s) does Control add over Basic? And which does Enthusiast add over Control?
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #13 of 38 Old 10-15-2012, 01:35 PM - Thread Starter
TomButera's Avatar
Thanks for replying. Is there a way to change between basic and enthusiast workflows? I had purchased enthusiast, but when I activated they asked which workflow I would like to use and I selected enthusiast. I am trying to learn this on my own and feel lost.
post #14 of 38 Old 10-15-2012, 01:54 PM
praz's Avatar
Liked: 26
Select the different workflow template as Scotti shows in post #324 linked below.
http://www.avsforum.com/t/1423111/calman-5-release-notes-and-discussion/300#post_22493872
praz is offline
post #15 of 38 Old 10-15-2012, 03:03 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
You should select the workflow level based on your skill. The more advanced workflows have less hand holding and show more data.
You should definitely start off with the introduction and familiarize yourself with the app, then move on to tutorial basic. That will walk you through a calibration with quite a bit of explanation on what to do each step of the way.
Joel Barsotti
SpectraCal
sotti is offline
post #16 of 38 Old 10-17-2012, 08:14 AM
anikun07's Avatar
Quoted: 32 Post(s)
Liked: 47
Do more advanced workflows require more advanced options on th display being calibrated? I'm sure more advanced workflows could be used for simple 2 pt balance, but with more data big shown does that make the process easier?
anikun07 is offline
post #17 of 38 Old 10-17-2012, 09:02 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
The more advanced workflows do less explanation and sometime collapse multiple steps into single operations.
But the ultimate version of that is quickview which all levels have access to.
The only thing that really sticks out is that you need the Color Cube workflow to calibrate the radiance in 3D mode, which you can only do with enthusiast.
Joel Barsotti
SpectraCal
sotti is offline
post #18 of 38 Old 10-23-2012, 02:43 PM - Thread Starter
TomButera's Avatar
Thank you for pointing out the workflows. I used the basic and control today to calibrate my screen. If I post my report, would anyone mind looking it over for me.
I do have questions about the RGB Bias and Gain. Reading other posts in the forum, Gain is the High End and Bias covers the low end. Do I have this correct?
Also when I got to the DeltaE LCH, these are all affected by the Gain and Bias correct? Calibration 1.pdf 329k .pdf file
Any tips or pointers are greatly appreciated.
Thank you
post #19 of 38 Old 10-23-2012, 03:13 PM
Thank you
Hi Tom,
Feel free to post it up and we'll give you some feedback.
Yes, Gain = High, and Bias = Low. If you flip open the help panel on the right side of the "Setting Brightness and Contrast" page in CalMAN 5, their is a matrix that shows all of the known control type names for High and Low.
LCH is for adjusting the Color Management System (CMS) if you have CMS controls on your display.
L = Luminance (intensity of the output)
C = Chroma (saturation level, or how much color it has)
H = Hue (color shift or tint from or towards one color or another with respect to each primary and secondary)
If you need it, I have a couple of PDF's that show the movement of each control with respect to the color space you are calibrating too.
I hope this helps.
Joshua Quain
www.spectracal.com
post #20 of 38 Old 10-23-2012, 04:06 PM - Thread Starter
TomButera's Avatar
Hi Josh,
If you wouldn't mind sending those pdf's over. Those sound like an interesting read.
Tom Butera
post #21 of 38 Old 05-28-2013, 03:21 AM
gunhed's Avatar
Quoted: 22 Post(s)
Hey Josh or Joel,
I just need some advice about Calman 5 prior to placing an order.
As I understand it;
1. The autocal feature, which calibrates greyscale and CMS, works with lumagen processors, the AV foundry processor, the eecolor box and the iscan DUO.
2 The more accurate 3D colorcube calibration, which is also automatic, works with the lumagen processors, the AV foundry processor and the eecolor box only and NOT the iscan duo ?
Is this correct ?
Also the ee/spectracal colorbox has "•Six selectable full 3D color cube LUT memories." . Are these fixed, in-built LUTs with one user definable LUT or 6 user definable LUT's ?
I realise the Lumagen mini is probably better value than the eecolor box as you get a processor thrown in as well for the same price or less.
Your website is a bit confusing as there are so many hardware/software combinations and software variations.
Thanks for your help in advance.
gunhed is offline
post #22 of 38 Old 05-28-2013, 10:44 AM
Hi Josh,
Tom Butera
Hi Tom, the PDF document that shows LCH movement in relationship to the CIE diagram can be viewed on the other side of this page towards the bottom of the page: http://studio.spectracal.com/webinar/calman-colorchecker-recording. It's more an info-graphic that an article. Please let me know if you have any questions or would like additional information. I hope this helps.
Joshua Quain
www.spectracal.com
post #23 of 38 Old 05-28-2013, 10:50 AM
Is this correct ?
Yes, correct.
The SpectraCal ColorBox has user definable LUTs. Meaning you create them when you calibrate/correct a LUT in a video system. Although the hardware is the same, the EE box, has pre-loaded LUTs. So ColorBox can be calibrated with all custom LUTs on all memory spots, and the EE box is for using the pre-existing LUTs. I hope this helps.
Joshua Quain
www.spectracal.com
post #24 of 38 Old 05-28-2013, 11:36 AM
ConnecTEDDD's Avatar
Quoted: 1077 Post(s)
Liked: 1543
Is this correct ?
Yes, correct.
eeColor/ ColorBox = Same Hardware, the differencies have to do with Faceplate Design & Color / Firmware / Price.
Both boxes have 6 Memory Slots, each slot has 1D + 3D LUT Table.
Using them with CalMAN you can calibrate and store the generated LUT''s using any of the 6 selectable Memory Slots you like.
The difference is how CalMAN handles each box, that means:
Using ColorBox -> CalMAN Calibrates the 1D LUT (RGB-Balance & Gamma) & After that it performs 3D LUT Cube. (The Box Can be used with CalMAN Only Software)
Using eeColor -> Don't Touch/Calibrates the 1D LUT (RGB-Balance & Gamma) & it performs 3D LUT Cube only. (The Box Can be used with CalMAN and also with other Calibration Solutions)
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #25 of 38 Old 05-28-2013, 01:44 PM
buzzard767's Avatar
Quoted: 1619 Post(s)
Liked: 2394
So ColorBox can be calibrated with all custom LUTs on all memory spots, and the EE box is for using the pre-existing LUTs. I hope this helps.[/B]
You must have missed this: http://www.avsforum.com/t/1462960/eecolor-processor-calman-3d-luts
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
post #26 of 38 Old 05-29-2013, 02:18 AM
gunhed's Avatar
Quoted: 22 Post(s)
Hey thanks for the information,
Just 2 more though;
1. Does Calman 5 perform 3D colorcube calibration with both AV foundry processors videoeq pro AND the videoeq ?
2. it seems the spectracal variety of the eecolor box is still better than the standard model as RGB balance and Gamma are also corrected OR as 3D luts are calibrated in both the resulting picture will be the same ?
It seems the iDuo and higher end Lumagen boxes are more convenient as you don't have to manually change calibrated settings for each input device as each input can be pre-calibrated. The Lumagen boxes of course calibrated more accurately due to 3D lut capability.
Thanks in advance !
gunhed is offline
post #27 of 38 Old 05-29-2013, 09:04 AM
buzzard767's Avatar
Liked: 2394
You can choose either the ee or spectracal version no matter which box is present. The software doesn't know the difference.
Buzz
post #28 of 38 Old 05-30-2013, 01:53 AM
*Harry*'s Avatar
Quoted: 22 Post(s)
Liked: 40
No, the VEQ's doesn't support 3D LUTs.
They are just for calibrating grayscale RGB balance/gamma and the gamut (RGBCMY) at one luminance level (usually 75% stimulus).
_________
Harry
*Harry* is offline
post #29 of 38 Old 05-30-2013, 03:54 AM
derekjsmith's Avatar
Liked: 116
Yes it does. In fact if we find a virgin eeColor and you connect as a ColorBox we will overwrite the input, output 1D ramps and 3D cube to linear before doing anything else.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
post #30 of 38 Old 05-30-2013, 05:43 AM
buzzard767's Avatar
Liked: 2394
So it prepares the eeColor Processor to be the same as the Spectracal ColorBox, without, I assume, changing the original on screen displays?
Buzz
Reply Display Calibration
