Calibrators - Gear Storage and Transport - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-03-2012, 12:40 PM - Thread Starter
Smackrabbit's Avatar
Quoted: 30 Post(s)
Liked: 90
Though most of my work is done at home for reviews, I wanted to ask the pros out there what they used for storing and transporting their gear around. Right now I'm just using a combination of the i1Pro case and some other bags, but would like to keep everything in a single, sealed case that is well organized if possible. I'm hoping those that travel around a lot have a suggestion for that they use. Thanks.
Chris Heinonen
Writer, The Wirecutter
Founder/Editor, ReferenceHomeTheater.com
ISF Level II Certified Calibrator
Previously: Senior Editor, Secrets of Home Theater and High Fidelity, Displays Editor, AnandTech.com, Contributor, HDGuru.com and Electronic House
Smackrabbit is offline
post #2 of 4 Old 10-03-2012, 12:43 PM
turbe's Avatar
Liked: 95
Take a look at the Pelican 1510 w/ Pick-N-Pluck
Calibration Kit example
Need to find a Professional Calibrator? Click Here to PM me with your Display & City
Calibrator List - Pioneer ISFccc Interface
Calibration Reports - Pioneer
ControlCAL™
Designed by Calibrators for Calibrators™
No need to fumble through the Display's Menu with its Remote Control™
turbe is offline
post #3 of 4 Old 10-03-2012, 01:23 PM - Thread Starter
Quoted: 30 Post(s)
Liked: 90
A Pelican was my initial thought, but I had seen some people complaining that the foam starts to fall apart from continually inserting and removing gear over and over. Any issues like that?
Chris Heinonen
post #4 of 4 Old 10-05-2012, 10:27 PM
Rayjr's Avatar
Quoted: 175 Post(s)
Liked: 214
Send a message via AIM to Rayjr Send a message via Yahoo to Rayjr Send a message via Skype™ to Rayjr
I use a storm case...pretty much like a Pelican.
Later
RayJr
Rayjr is offline
Reply Display Calibration
