Dramatically Different Results with Spyder4 vs AVS 709 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-03-2012, 10:26 PM - Thread Starter
Neomic's Avatar
So I've been using the AVS 709 discs for a few years now, but I ended up getting a Spyder4TV HD from Datacolor today to review at the website I work at. After comparing my results with each, I've gotten results that differ dramatically between each. When I use the Spyder4TV HD and calibrate my display, it tells me that my contrast should be at 98, color at 41 , and tint G45|R55. When I pop in the AVS 709 disc, it shows that the settings are incorrect. Contrast is over-blown where the grey's have a pink hue (so I turn it down to 89), color and tint are off as well, with the settings showing correct results (in Blue mode) at 36 and G46|R54 respectively.
It bring some concern as to whether the Spyder4TV HD is calibrating correctly. Should I be getting these vastly different results between the two? If I had another Blu-ray with patterns besides T2: Skynet (which I've read yield poor results, since it's apparently REC601), I would triple check, but I don't as far as I know. Does anyone have any information on this, or can help me out? I'd love to use this and finally get some truly accurate results, but so far it's proving that my eye-sight may be doing me better... Which doesn't seem right,
Neomic is offline
post #2 of 5 Old 10-03-2012, 11:26 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
The numbers the meter reads and reports to the software aren't that bad.
The spyder 4 isn't the best meter, but it isn't horrible.
But there are many better pieces of software for running the meter our there.
The AVS disc's brightness and contrast are far more likely the correct settings. We've been working a bit on using a meter to set brightness and contrast and at most it's a click or two different from what we see with our eyes. If it's drastically different, something has gone wrong in the software.
sotti is offline
post #3 of 5 Old 10-04-2012, 12:55 PM - Thread Starter
Neomic's Avatar
Isn't the pink hue showing up in the grey test patterns a bad thing?
Neomic is offline
post #4 of 5 Old 10-04-2012, 01:22 PM
sotti's Avatar
Quoted: 331 Post(s)
Liked: 335
The pink hue is definitely wrong.
sotti is offline
post #5 of 5 Old 10-04-2012, 02:55 PM
PlasmaPZ80U's Avatar
Quoted: 2315 Post(s)
Liked: 716
+1, back when I had a D2 I had that issue
-7.1ch Bedroom HT-
Samsung UN46EH6030
Yamaha RX-A2070
SVS Prime Bookshelf and Prime Center
Sony SS-CS5 Surrounds and Cambridge S20 Rear Surrounds
Rythmik LV12R
PlasmaPZ80U is offline
Reply Display Calibration
