3D Pattern Generator for Calman 5 - Radiance 3D? AccuPel? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-05-2012, 01:41 AM - Thread Starter
wchris's Avatar
Hi!
I is there anyone using 3D pattern generator? Will one of these generators do well:
- Lumagen Radiance mini 3D
- AccuPel 5000
- VideoEq Pro 3D
Both of them are able to generate 3D frame packing patterns but does it work with all calman features like saturation sweeps & colour checker?
Which one would you buy and why?
wchris is offline
post #2 of 4 Old 10-11-2012, 05:32 PM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
The AccuPel certainly supports frame-packing 3D format, but you'll probably have to select it from the on-screen menu before starting.
It will also generate any user-defined color in 8-bit from 16-255 (% mode 0%-109%) and in 10-bit mode from 4-1019.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is online now
post #3 of 4 Old 10-12-2012, 12:11 AM
ConnecTEDDD's Avatar
Quoted: 1055 Post(s)
Liked: 1518
Originally Posted by wchris View Post
Hi!
- VideoEq Pro 3D
Video EQ is not a pattern generator.
* It can display only 6 patterns of RGBCMY 100% Saturation - 100% Amplitude - Only Full Screen Patterns from inside LUTBuilder Software. Not any Grayscale patterns).
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is offline
post #4 of 4 Old 10-12-2012, 12:27 AM
venkatesh_m's Avatar
Quoted: 33 Post(s)
Liked: 26
I believe he meant the Video Forge from AV Foundry.
Sent from my GT-I9100 using Tapatalk 2
venkatesh_m is offline
Reply Display Calibration
