Colormunki Display vs i1 Display Pro - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 10-10-2012, 01:11 AM - Thread Starter
daMaster's Avatar
Does the Colormunki Display have the exact same hardware as the i1 Display Pro (aka Display 3)? The Xrite website comparison says the Colormunki Display isn't as fast in taking measurements but I wonder if that's just a consequence of the software they ship with the Colormunki vs the software they ship with the i1 Display Pro.
daMaster is offline
post #2 of 15 Old 10-10-2012, 05:40 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
display pro is a colorimeter the munki is a spectro, 2 different animals. Sectro is very accurate but not as fast and does not work as well in low light. Most pros either have a VERY expensive spectro that is fast, or they have a lesser priced spectro and a higher end colorimeter that they profile against the spectro. Best setup for a home user that want the best accuracy for the buck is an entry level specto and and i1 display pro. Lots and lots of discussion on the topic over the past years.. Do some searches in this forum on "profiling"
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 15 Old 10-10-2012, 07:29 AM
fredman2005's Avatar
Some correction:
At least the newest Colormunki Display is a colorimeter and not a spector. The Colormunki Photo is a spectrophotometer.
fredman2005 is offline
post #4 of 15 Old 10-10-2012, 07:32 AM
PlasmaPZ80U's Avatar
Quoted: 1962 Post(s)
Liked: 559
colormunki display is essentially a D3 colorimeter
colormunki photo is a spectro
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
post #5 of 15 Old 10-10-2012, 07:36 AM
rahzel's Avatar
Liked: 148
As far as we know, the only differences are measuring speed, and the i1D3 has ambient color + luminance measuring vs just luminance on the CMD.
rahzel is offline
post #6 of 15 Old 10-10-2012, 09:49 AM - Thread Starter
daMaster's Avatar
Please read my question carefully. I am aware that the Colormunki is a spectro, but I was asking about the Colormunki Display which is a colorimeter that looks just like the i1 Display Pro (D3).
Is the speed difference between the CD and D3 a software limitation only, i.e. do they both measure at the same speeds when used with HCFR or Chromapure, etc.? I already have a Display Lt and I'm looking for a used i1 Pro but they're not easy to find. I was considering instead to get a brand new Colormunki Display if and only if it's identical (hardware-wise) to the D3. That's what I was looking for validation on.
daMaster is offline
post #7 of 15 Old 10-10-2012, 02:19 PM
rahzel's Avatar
Liked: 148
AFAIK, it's a limitation on the device.
rahzel is offline
post #8 of 15 Old 10-10-2012, 02:39 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Also the Colormunki Display will only work with X-Rite software or HCFR, there is no official 3rd party support for the meter.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #9 of 15 Old 12-17-2012, 10:54 PM
guida74's Avatar
Has this been confirmed? Will ColorMunki work with CalMan 4 or 5?
guida74 is offline
post #10 of 15 Old 12-18-2012, 12:08 AM
MechanicalMan's Avatar
Look at sotti's signature. smile.gif I'm not sure if this is accurate, but I believe that licensing restrictions prevent authorized OEMs like SpectraCal and ChromaPure from supporting the ColorMunki Display..? So while there is support for the ColorMunki Display in free software, such as HCFR and Argyll, it is not supported by CalMAN or ChromaPure. If you want to use one of the "Display 3" meters with CalMAN, then you can purchase either an OEM or retail i1Display Pro.
MechanicalMan is offline
post #11 of 15 Old 12-18-2012, 12:11 AM
Rolls-Royce's Avatar
Quoted: 239 Post(s)
Liked: 352
It has been confirmed for a while. It will NOT work with any CalMAN version. X-Rite has locked the meter to their software and have not released its SDK to 3rd party vendors including SpectraCal. HCFR's support is reverse-engineered and not "official".
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is offline
post #12 of 15 Old 12-19-2012, 09:56 AM
guida74's Avatar
How accurate is the ColorMunki Display? I bought this meter a week ago (brand new) and have been using it with HCFR v.3.0.4.0 to calibrate my DLP projector. For some reason I think that this colorimeter or at least mine may be providing higher readings for the blue primary, green and red seem to be on par. The reason I think this is becuase of all the professional reviews I have read for my projector (Optoma HD8200) the default warm color temperature setting for cinema or reference mode is +/- 7500K and I obtain consistent readings of upwards 7900K-8000K. On the RGB levels graph, the red, green and blue track linear per the professional reviews; (plus blue, green close to 6500K and minus red).
The picture looks much better after I calibrated to 6500K, but I keeping thinking in the back of my head; is the meter off??? I realize that these lower cost meters have limitations and cannot compare to the higher end professional equipment; but a 400K to 500K color temp. error seems substantial.
In HCFR I select my meter ColorMunki Display, display type refresh (single chip DLP), reading type non-contact, Spectral Sample Projector. Advanced menu, Preferences, General uncheck the use measured colors box. References tab select HDTV - REC 709 as the standard, Advanced tab I checked the Do not use luminance in delta E formula. From there I just followed the CurtPalme GREYSCALE & COLOUR CALIBRATION FOR DUMMIES.
PS I don't think that the ColorMunki Display requires calibration before taking any measurements.
guida74 is offline
post #13 of 15 Old 12-19-2012, 10:32 AM
guida74's Avatar
Another thing that just came to mind and enters the equation is my screen material; maybe there is a colour shift towards blue? I have a 92" Elunevision Reference Studio 4K Tab-Tensioned motorized screen with 1.0 Gain? Thoughts?
guida74 is offline
post #14 of 15 Old 01-08-2014, 09:58 AM
iMilazzo's Avatar
Guilda74, could you please tell us what and how did you to make Colormunki Display works with Color HCFR? I have one and I'm not able to use with this software yet!!
Thank you
Ivan Milazzotti
[Mundo iMilazzo]
Onkyo TX-NR5010|Cambridge CXA80
M.A. Gold GX100 [Kimber 8TC BI-AMP]|Gold GXC150|Gold GX-FX|RXW12
Panasonic TC-P65VT60B|WDTV Live|Apple TV 4|Claro HDTV|Pioneer BDP450
Savage DMA3000ex
iMilazzo is offline
post #15 of 15 Old 01-08-2014, 10:08 AM
guida74's Avatar
Ivan,
Its been a while since I used the ColorMunki and I have since sold it....
It does work with Color HCFR, just search on AVS and there is a wealth of info on it with tutorials on getting it set-up; if I recall I had to install a USB driver which was on the supplied CD to get HCFR to recognize it.
Good Luck!
iMilazzo likes this.
guida74 is offline
Reply Display Calibration
