Favor request from anyone with a i1display pro, plasma and reference meter. Need a .ccss. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-11-2012, 02:36 PM - Thread Starter
Shinyav's Avatar
I want to run a XYZ lut + matrix in Dispcal and then load that 3DLUT into yCMS for videos through MPC and MadVR.
However my problem is the i1Display Pro requires a .ccss for plasmas otherwise it seems to be quite off according to the HCFR thread and my own experience.
For HCFR I was able to use a 4 color matrix. I don't think its possible to use that in anyway for dispcal.
What I need is a .ccss from a reference meter for a i1Display Pro used on a plasma.
If anyone could help me out I would be very appreciative.
Or if there is any alternative, some information on it would be great.
Shinyav is offline
post #2 of 4 Old 10-13-2012, 08:14 AM
zoyd's Avatar
Quoted: 1315 Post(s)
Liked: 1051
zoyd is offline
post #3 of 4 Old 10-13-2012, 10:56 AM - Thread Starter
Shinyav's Avatar
Thank you!
I did not realize the correction would be the same for a spyder 4.
Shinyav is offline
post #4 of 4 Old 10-13-2012, 08:09 PM
zoyd's Avatar
Liked: 1051
zoyd is offline
Reply Display Calibration
