Why correct gamma makes my display very dim? - AVS Forum | Home Theater Discussions And Reviews
Old 10-11-2012, 11:18 PM - Thread Starter
max90034's Avatar
Quoted: 24 Post(s)
I was trying to calibrate my plasma (Samsung) using radiance mini 3d and CP. It turned out that "before" gamma was very wrong going from ~1.2 at 90% to ~1.8 at 10%. Using either manual controls or CP autocalibration I could make gamma curve much flatter and close to 2.2. The problem is that it makes picture much dimmer! I know now that it is supposed to get dimmer when I rise gamma at right end from 1.2 to 2.2. So, technically it is much more correct after calibration but I just cannot stand that dim picture! Is this a problem with my display, my eyes, my brain?? Anything I can do to get correct gamma without dimming the picture?
max90034 is offline
Old 10-12-2012, 05:50 AM
PlasmaPZ80U's Avatar
Quoted: 1964 Post(s)
Liked: 560
can you increase peak white by turning up contrast? or is it already as high as it can go without clipping/discoloration?
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
Old 10-12-2012, 07:06 AM
Quoted: 1393 Post(s)
Liked: 587
max
You need to ask this in the Chromapure thread.
Sounds vaguely familiar but not sure if I read it there on the Calman thread.
JimP is offline
Old 10-12-2012, 06:03 PM
TomHuffman's Avatar
Quoted: 682 Post(s)
Liked: 613
If your peak output at 100% is near 120 cd/m2 and the gamma is in the 2.2-2.3 range, then this is what a calibrated display looks like. If you had gotten used to a gamma of 1.2, then this may look dim to you.
Tom Huffman
ChromaPure Software/AccuPel Video Signal Generators
ISF/THX Calibrations
Springfield, MO
TomHuffman is offline
Old 10-12-2012, 07:40 PM - Thread Starter
max90034's Avatar
Quoted: 24 Post(s)
It turned out that the problem was me using field model to calibrate plasma. It was reading gamma incorrectly and was trying to fix it by reducing brightness. Once I switch to window, gamma reading was much more reasonable and brightness was not change after calibration.
max90034 is offline
