Setting brightness: by measurement or using pluge? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 10-13-2012, 05:12 AM - Thread Starter
turboman123's Avatar
Quoted: 22 Post(s)
Liked: 25
Both Chromapure and Calman recommend to use a black pluge pattern to set brightness. I have tried to do this, but I found this method erratic and in the end, I kept wondering if I had the right setting.
The point of having a meter is to calibrate by measurement.
So I wondered if I could do it by measurement. I tried the following on a Samsung 55ES8000 using a Display2. My Display2 is 2years old and might not be accurate, but the point I want to show is that I want to detect when there is a change in Luminance, and this the Display2 can do.
Following are the measurements as average of 5 readings, at IRE 0%, 1%, 2%, 3% and 4%. Brightness settings are 43, 44, 45, 46, 47 and 48. Luminance is in cd/m2.
My observations are:
At brightness setting 44 or lower, the luminance at 1% is the same as at 0%. Blacks are crushed so setting is too low.
At brightness setting 47 or higher, the minimum black level MLL at 0% starts to go up. As I want lowest MLL, this brightness setting is too high.
So my conclusion is that I have to set brightness at 45 or 46. In order to select between the two values, I would use a visual obervation of a pluge, or calculate gamma (with MLL offset).
Please note that making this graph took quite some time. But that was only done for this thread. For setting brightness in a calibration, all it needs are a few measurements at near black.
My questions are:
- is this a reasonable method?
- is it more reliable than a pluge method?
turboman123 is offline
post #2 of 26 Old 10-13-2012, 06:32 AM
SierraMikeBravo's Avatar
Quoted: 335 Post(s)
Liked: 214
I would say not the best method. Keep in mind, regardless of instrumentation, your eye IS the final test. You can measure to your hearts content, but in the end, the result could be a very messed up picture. Brightness is part of a ratio for contrast and contrast varies depending on a number of factors. For this reason, your brightness level setting will vary depending on the amount of light in the room. A brightness setting set in a pitch black room will not be the same setting it should be set at when the lights are on. While going strictly by the numbers, you won't allow for this. One of the reasons for day and night settings. Vice versa, using PLUGE in a brightly lit room will result in a brightness level above that which would be desired for completely dark room. Really expensive colorimeter = $13,000. Eyeballs in their sockets working properly = priceless. smile.gif
kanti123 likes this.
Shawn Byrne
CEDIA Certified Professional EST II - HAA, THX.
Theater Design Information and Examples
skbyrne@sbcglobal.net
shawn@questai.com
SierraMikeBravo is offline
post #3 of 26 Old 10-13-2012, 07:33 AM
visca blaugrana's Avatar
I think in theory its a good way another way is to display a 100% black pattern, set brightness to its higest and then reduce it to the lightoutput dont drop any more.
however a real problem is that most meters are not 100% reliable with that little light, therefor a pluge pattern it still my prefered methode.
visca blaugrana is offline
post #4 of 26 Old 10-13-2012, 09:22 AM
Chad B's Avatar
Quoted: 493 Post(s)
Liked: 1179
Also, some displays mute or reduce their output with a 100% black pattern, throwing a monkey wrench in this process unless you use some sort of pattern that has a bit of content away from the measurement area to keep the display "alive".
Pluge patterns aren't hard to interpret.
Suggestions, especially for when you are calibrating a night mode or whenever you want to make sure you are not raising the black floor at all: use a low APL pluge pattern in a very dark room, and walk right up to the display and get really close to it. You'll be able to see the threshold easier then.
Chad B is online now
post #5 of 26 Old 10-13-2012, 09:50 AM
fredman2005's Avatar
Is this setting also usable for normal, not bright sunshine daylight viewing?
fredman2005 is offline
post #6 of 26 Old 10-13-2012, 10:00 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Not to mention you may have to take 3 or 4 sets of readings down that low will take several minutes, versus the instant feedback from manually looking at it.
I think it will always be adjust with the pluge pattern, then possibly verify with a meter.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #7 of 26 Old 10-13-2012, 12:39 PM
hungro's Avatar
Quoted: 164 Post(s)
Liked: 111
Ok, so then on a 0 ire pattern what do you want this too look like. At the point where there is no pixels firing or creating light not even the faintest. I have spots on my tv near the bottom that goes across where it looks like green pixles very very faint with the nose up to the screen that no matter where I set the black level of the tv it's a pn51d6500 the green pixles don't disappear. In the upper portion of the screen there is zero pixle activity at the point where the set doesn't get any darker if you continue lowering brightness any lower. What might be causing this? Could this be a uniformati issue? I have set all my panel voltage settings to factory sticker values.
hungro is offline
post #8 of 26 Old 10-14-2012, 03:12 AM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 352
The pattern that really works best is not a PLUGE patter, but a pattern with steps from 0-25 or so. If there is a square of gray for each 1% step, the results are VERY non-ambiguous.
Meters used for calibration are light meters... they measure light. And they suck at measuring dark. I have a $14,000 meter that is good down to maybe 3% white on panel displays. It will make readings below 3%... they just won't be meaningful/accurate. Averaging 3 inaccurate readings gives you an inaccurate average. There's no way an inexpensive meter is accurate at 4% let alone at steps below 4%.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #9 of 26 Old 10-14-2012, 09:52 AM
PlasmaPZ80U's Avatar
Quoted: 1962 Post(s)
Liked: 559
Good examples are the Black Clipping pattern on the AVS (and now GCD) disk and the Advanced Brightness pattern on the Disney WOW BD, which uses 1% steps.
Just out of curiosity, what digital value does 1% stim correspond to?
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #10 of 26 Old 10-15-2012, 12:27 PM
Quoted: 188 Post(s)
Liked: 352
^^ 235 divided by 100 = 2.35 digital increments per 1% step. Which is one reason you want to use a ditigal step pattern for the best resolution of whether you have the best Brightness setting
THX -- ISF -- HAA
post #11 of 26 Old 10-16-2012, 07:50 AM
dominickwok's Avatar
Should the calculation be (235-16+1) steps / 100 = 2.2 digital increments per 1% step?
dominickwok is offline
post #12 of 26 Old 10-16-2012, 01:48 PM
Quoted: 188 Post(s)
Liked: 352
^^^ DuhOh - yes. I should have thought for 5 seconds more before clicking "send" tongue.gif
THX -- ISF -- HAA
post #13 of 26 Old 10-16-2012, 02:04 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
And to be very technically precise it is 2.19 bits per percent, you don't add the 1 back in. 220 levels but only 219 steps.
Joel Barsotti
SpectraCal
sotti is offline
post #14 of 26 Old 10-16-2012, 05:41 PM
Liked: 559
so 1% gray is the equivalent of digital (2.19+16) 18.19?
post #15 of 26 Old 10-16-2012, 06:05 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Rounded down to 18.
You can see all the rounded bit levels in CalMAN.
Joel Barsotti
SpectraCal
sotti is offline
post #16 of 26 Old 11-15-2012, 09:09 PM - Thread Starter
Quoted: 22 Post(s)
Liked: 25
Rounded down to 18.
Errors resulting from discrete bit levels.
If I take this a step further, and calculate e.g. 50% stimulus. Then this would be 16 + 0.5*219 = 16 + 109.5.
In bit level, then 16 + 109 or 16 + 110 has to be chosen, which is stimulus 49.7717% or 50.2283%.
How is this treated by calibration programs and calibration disc?
- Does a calibration program select one of the two levels and calculates gamma for that level? E.g it choses 16+110 and calculates gamma asuming the stimulus is 50.2283. Gamma is then calculated correctly.
Or does a program selects a bit level of 16+109 or 16+110 for the pattern, but calculates with a stimulus level of 50%. This would create an error in gamma.
- What happens if calibration patterns and programs form different sources are mixed?
E.g. a calibration disc from one source which uses a bit level of 16+109, and a calibration program which assumes the pattern is 16+110. That would introduce a gamma error of 0.05 which a calibrator sees as a perceived deviation even if it is not there.
Just some basic questions. Am I seeing things wrong? Can someone explain.
post #17 of 26 Old 11-15-2012, 09:40 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
CalMAN uses the built-in round function for .net which is an http://grouper.ieee.org/groups/754/ standard for rounding.
So 50% rounds up to 126.
CalMAN calculates all it's values off of the discrete 8bit values.
Joel Barsotti
SpectraCal
sotti is offline
post #18 of 26 Old 11-20-2012, 06:36 AM
Chronoptimist's Avatar
Liked: 532
On modern displays, assuming you don't have a display which is doing any kind of adjustment with a full black field (which is quite an assumption to make now) you should be able to set it in about five seconds with the brightness control.
When you turn down the brightness, there will be a point at which black stops getting any darker, and any upwards adjustment raises the black level. Congratulations, you now have brightness set correctly.
Even if the panel clips the lower 1-2% you're still better off with the display set to give you the darkest black level it can do, because today's display contrast is so low.
Even the Kuros lose all black level advantage if you set them using a brightness pattern rather than setting brightness at the point where the panel turns its darkest.
Chronoptimist is offline
post #19 of 26 Old 11-20-2012, 09:09 AM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
I think I read this somewhere, on a blu-ray or something, sometimes they "fade to black" in between scenes. Pauze at the darkest piont, then turn down brightness untill it doesnt get any darker, done.
Or, on this "fade to black "pattern"", turn down brightness completely, then turn up 1 click at a time untill the screen gets brighter, then one click down again, done.
Wouter73 is offline
post #20 of 26 Old 11-20-2012, 06:33 PM - Thread Starter
Quoted: 22 Post(s)
Liked: 25
Exactly, that is the point I wanted to make with my original post.
In my case on the Samsung 55ES8000, avoid dimming by using movie mode or large APL pattern, display black, measure and set brightness from a higher to a lower setting. At brightness setting 46, black level stops geting darker. Mission accomplished. Easier than using pluge.
post #21 of 26 Old 11-21-2012, 03:58 PM
Liked: 532
There is nothing to guarantee that a "fade to black" is actually properly fading to black. You should use test patterns for this.
http://www.avsforum.com/content/type/61/id/76970/width/500/height/1000
Yes, as long as you are sure that you are able to avoid dimming etc. this is the easiest way to set brightness correctly.
post #22 of 26 Old 11-22-2012, 01:11 AM
Wouter73's Avatar
Quoted: 13 Post(s)
Liked: 35
Wouter73 is offline
post #23 of 26 Old 11-22-2012, 11:00 AM
buzzard767's Avatar
Quoted: 1618 Post(s)
Liked: 2393
One caution for DLP RPs in general. If there is any menu OSD the measured light level will usually continue to decrease all the way down to a brightness setting of 0. You'll need to exit the menu after each settings change.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
post #24 of 26 Old 11-22-2012, 11:13 AM
ndaa75's Avatar
OK, perhaps im doing something wrong here.
I have a 55VT30 - setting the correct brightness using the AVSHD disk means my gamma is stuck at about 2.13 - increasing it to 2.2 crushes blacks confused.gif
Benq W1080ST Projector, Panasonic TXP55VT30 plasma, Yamaha RXA3020 AVR, Denon DVD-2500BT, Q Acoustics 1010i in 7.1, i1 Pro spectro, i1 Display Pro, Calman 5 Enthusiast, PS3, Xbox 360, Wii
Calibration Management Disc
ndaa75 is offline
post #25 of 26 Old 11-23-2012, 01:32 PM
Quoted: 188 Post(s)
Liked: 352
Gamma won't "crush blacks" all by itself... something else has to be changing or the "new" gamma setting isn't proper/linear/uniform. Measurements would probably show a change in response in darker steps that explains what is going wrong with the darker gamma setting. Just because the TV has a gamma control doesn't mean the control does what it is supposed to do... nor does the presence of a control mean you get the real gamma value that the control is labeled for (in other words, setting the control to 2.2 doesn't mean that's the ACTUAL display gamma, nor does it mean you get 2.2 at every grayscale step... you might measure 2.5 at dark steps, 2.3 in some gray steps, 2.2 at 60%, and 1.9 from 80%-100%... you just never know what you are getting with different gamma settings when you don't have a meter to see what's really happening at each setting.
THX -- ISF -- HAA
post #26 of 26 Old 11-23-2012, 02:42 PM
ndaa75's Avatar
I am using a metre. Perhaps its the pattern type I'm using - perhaps it's because im still learning this set which is much more of a challenge than my previous sammy???
ndaa75 is offline
Reply Display Calibration
