Cal-Day and Cal-Night modes nonexistent on Samsung EH series LED-LCDs? - AVS Forum | Home Theater Discussions And Reviews
Old 10-16-2012, 01:38 PM - Thread Starter
PlasmaPZ80U's Avatar
Quoted: 1963 Post(s)
Liked: 559
I have the Samsung UN46EH6000 and in the service menu there is no "Expert" section. Are the Cal Day and Night modes hidden elsewhere in the SM or are they nonexistent on the EH series models? Also, the "Advanced" section shows up on the main SM screen, but when you press 0000 all you get is a blank screen.
Here's a pic of the SM main screen:
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
Old 10-18-2012, 07:20 AM
freebits's Avatar
Quoted: 16 Post(s)
Liked: 26
What is the current region of the TV in SM? If it's not U.S., normally Cal-Day and Ca-Night are not shown, right?
freebits is offline
Old 10-18-2012, 10:35 AM - Thread Starter
Liked: 559
It's US, you can see it in the pic after OPTION: 46A1AF0D, US, 6000, NONE
Old 04-20-2013, 09:04 PM
ledtvme's Avatar
Doing a factory reset will get the advanced settings to work once you input 0 0 0 0. The expert menu option will appear as well but it's greyed out. I'm still unable to find cal-day/night anywhere. My guess is it's in the expert menu option but I don't know how to access it, it stays greyed out.
ledtvme is offline
Old 04-21-2013, 03:52 AM
buzzard767's Avatar
Quoted: 1618 Post(s)
Liked: 2393
Arrow down to SVC and press enter. Expert should be in there.
Buzz
THX Certified Level II Video Calibrator
CalMAN Ultimate license FS
buzzard767 is offline
Old 04-21-2013, 07:30 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Was looking at my friends EH5000 last night, didn't see anything other than 2 point in the user menu.. am I missing something? Day/Night just gives you 2 places to store a locked set of setting, correct?
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
Old 04-21-2013, 02:56 PM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
D/N is an option available on 6 series and higher. Not 5 series. The locking part has never worked right. You go back into the SM to lock the settings and when you come out, The D/N settings are locked all right ... based on reset values and not the stuff you did. Going into the SM often resets all values across the board on the user side.
Regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
Old 04-21-2013, 03:15 PM - Thread Starter
Liked: 559
Originally Posted by Michael TLV View Post
Greetings
Regards
it does work right on my EH6030, but this set lacks CMS and 10-pt white balance... the two areas that typically get reset
stuff like basic picture settings plus 2-pt white balance and gamma presets are retained when locking the N/D modes
Old 04-21-2013, 03:17 PM - Thread Starter
Liked: 559
only the ES6100 and higher models have CMS and 10-pt white balance in the user menu... the EH models don't (regardless of 6, 5, or 4 series)
Old 04-21-2013, 03:19 PM - Thread Starter
Liked: 559
does that apply to ES series only or also EH series?
Old 04-21-2013, 04:16 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Thanks, I figured if it had it, it would be in the User menu and not require SM access.
Doug
