LG 42LM6200 Calibration help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-17-2012, 02:37 AM - Thread Starter
gvamp's Avatar
I just got the LG 42LM6200 3D LED Smart TV and would like some recommended settings for it. I have the following inputs in use:
-HDMI 2: Cable box on HDMI 1.3a
-PS3 HDMI 1 on HDMI 1.4 I think I know it's the latest specification that supports 3D, Ethernet and Audio return.
-Xbox 360 on the same cable as the PS3
I have a Wii on the component input but that'll be upgraded to a Wii U in a month so it's no big deal if I get calibration settings for that
Any links to help properly calibrate would be apperciated and if it helps I do have a Blu-ray burner so I could burn a BD of calibration software. I tried searching for settings on here and on the web but to no avail.
gvamp is offline
post #2 of 2 Old 10-17-2012, 08:03 PM
GeorgeAB's Avatar
Quoted: 135 Post(s)
Liked: 240
First off, using the picture menu settings values from another TV like yours will not result in a calibrated display, as explained in this "sticky" thread from the top of this section of the forum:
'Sharing display menu settings?'
http://www.avsforum.com/avs-vb/showthread.php?t=1055906
This link offers additional explanation and documentation: http://forums.hdtvtest.co.uk/index.php?topic=7202.0 .
Secondly, the AVS HD709 calibration program can be burned to a DVD. The files can be read by most Blu-ray Disc players. Here's the link that explains how it works: http://www.avsforum.com/t/948496/avs-hd-709-blu-ray-mp4-calibration .
GeorgeAB is online now
Reply Display Calibration
