Can Sharp 80LC632 or 633 be calibrated to ISF levels. Opinions from ISF folks are needed. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-21-2012, 06:13 PM - Thread Starter
dvzzz's Avatar
Quoted: 99 Post(s)
Liked: 31
Folks, can any of those 2 TV's be calibrated to the solid ISF performance. Questions I have:
1. Will ISF calibration take into account daytime viewing (ideally I would like to store two profiles Day and Night ISF).
2. Are these TV's more or less expensive to be calibrated?
Anybody in the Chicagoland is willing to come out and do the calibration for me? Pls PM me.
For sale Sony VPL-HW40ES Projector, 720 hours on Eco Mode http://www.avsforum.com/forum/252-fr...-oem-bulb.html
dvzzz is offline
post #2 of 5 Old 10-22-2012, 08:15 AM
Chad B's Avatar
Quoted: 496 Post(s)
Liked: 1195
Yes, I have calibrated many 632Us, and they calibrate well. The measurements are not as perfect as can be had on some displays, but they can still be good. More important, the overall image after calibration can be extremely impressive.
1) It can, though the calibrated modes will not be labelled as "day" and "night", and they will not be locked. Movie would be the most accurate "night" mode. Be sure to tell your calibrator you would like separate day and night modes.
2) Usually the same, but it could depend on the calibrator's pricing structure. They are very easy to calibrate once the calibrator has a good grasp on how it's CMS and gamut behave.
I reviewed the 80LE632U here on AVS: http://www.avsforum.com/t/1363281/official-sharp-aquos-lc-80le632u-owners-thread/30#post_21074429
I tour to Chicago several times a year, as do others.
Chad B is offline
post #3 of 5 Old 10-22-2012, 12:37 PM
Doug Blackburn's Avatar
Quoted: 188 Post(s)
Liked: 352
The whole day/night thing is massively overblown. You CANNOT calibrate for "day" because "day" is not consistent. Clouds come, clouds go, seasons change, sunlight is different at different times of day. Room lights are different than daylight. Anything in the room that is changed or moved will change the reflected light in the room. You simply cannot calibrate for a moving target. All you can do is find brighter settings that are still accurate (in a dark room) and call that "day" mode. Though it has nothing (really) to do with being CALIBRATED when there is light in the room. Light in the room de-calibrates a display, even if it is set brighter. I would set the TV somewhere close to 30-35 fL for a dark room, then find settings that get up to maybe 55 fL for a plasma (if it will even get that bright) or maybe 60 fL for an LCD panel. All "day" mode would be is a 60 fL mode that's accurate in a dark room because there's simply no way to know what light is going to be present in the room at any given moment.
"Movies is magic..." Van Dyke Parks
THX -- ISF -- HAA
Doug Blackburn is offline
post #4 of 5 Old 10-22-2012, 12:49 PM
Michael TLV's Avatar
Location: THX/ISF Calibrationist/Instructor, Calgary, AB, Canada
Quoted: 40 Post(s)
Liked: 142
Greetings
I just tell clients to bump up the backlight to get their "day" mode.
regards
Michael Chen @ The Laser Video Experience
ISF/THX/TLV Video Instructor
The Video Calibration Education Hub - www.TLVEXP.com
Michael TLV is offline
post #5 of 5 Old 10-22-2012, 01:44 PM - Thread Starter
dvzzz's Avatar
Quoted: 99 Post(s)
Liked: 31
Thanks, this makes sense. True, I need more light output from the set when daylight. Most of my movie watching is at night but I do watch fair amount during the day time on weekends on winter months. I will keep your suggestions in mind once I discuss it with the local calibrator. One more question: about calibration when everything is run through a DVDO Edge Green processor? I assume we still calibrate the set and processor is not a variable here? I know Edge has CMS capabilities built in not sure how to do it?
dvzzz is offline
Reply Display Calibration
