How could I calibrate for 0-255? Are there any calibration patterns for it? - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 101 Old 12-17-2012, 07:09 PM
Light Illusion's Avatar
Quoted: 320 Post(s)
Liked: 627
Unfortunately no plasmas can ever be fully - and accurately - calibrated.
ABL prevents that. There is just no way around it.
Steve
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
post #92 of 101 Old 12-17-2012, 08:32 PM - Thread Starter
Tyrone Burton's Avatar
Hmm. Although I know plasmas are great. There is also a darkside to them called....ABL smile.gif
Tyrone Burton is offline
post #93 of 101 Old 12-17-2012, 09:22 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
Also image retention which can effect measurements.
LCDs also have issues with response time, black level and viewing angle.
Sadly there is no ideal display.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
post #94 of 101 Old 12-17-2012, 09:43 PM - Thread Starter
not even the cinemas screen?
post #95 of 101 Old 12-18-2012, 09:14 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 329
The trade off there of course is going to a projector you'll need to have a totally light controlled environment.
Older wheel based DLPs have the issue with people seeing rainbow effects (front or rear projection).
3 Chip DLPs have higher black level than single chip DLPs.
Joel Barsotti
SpectraCal
sotti is offline
post #96 of 101 Old 12-18-2012, 11:55 AM - Thread Starter
Well if what your saying is that all display devices are never full completely accurate, I'm happy. Because it can't be helped smile.gif
post #97 of 101 Old 12-18-2012, 05:56 PM - Thread Starter
Hi light illusion. I'd like to just ask a question about your brightness pattern? Does it have a BTB square at all, and if it does is it by any chance the last square on the image?
post #98 of 101 Old 12-19-2012, 10:23 AM
PlasmaPZ80U's Avatar
Quoted: 1962 Post(s)
Liked: 559
Originally Posted by Light Illusion View Post
The IPS panels we have tested and calibrated have been very good
what kind of native on:off and ansi contrast ratios are we talking about here?
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
post #99 of 101 Old 12-20-2012, 08:52 AM
Quoted: 320 Post(s)
Liked: 627
The patterns are all full data range, so they include 'sub-black' and 'super-white', which are the correct terms to use.
But this depends on how you display the images.
See: www.lightillusion.com/data_tv_levels.html
You need to understand if the workflow / signal path you are using is re-mapping the image levels/data, or clipping.
Most home systems will re-map, so there will be no sub-black, or super white.
Steve
Steve Shaw
LIGHT ILLUSION
post #100 of 101 Old 12-20-2012, 11:53 AM - Thread Starter
Steve
well using the brightness pattern on my PS3, while outputting TV legal levels, I can see all the squares and don't have any clipping going on with either the brightness or contrast images.
It's just I wanted to know this as Scotti has explained to me that alot of Oporating systems don't output BTB, so I should clip it using the brightness control. I'm currently showing the last square in your image barely.
post #101 of 101 Old 12-23-2012, 11:48 AM - Thread Starter
Hello again guys. I'm running into a bit of confusion at the minute. I need to ask questions in two different threads to get my problem strait.
I'm not sure but I think what scotti was saying about consoles being designed to run in 16-235 if I'm right, might be happening here. I'd just like to ask, what did you mean you said "that's the way they were designed to work"?
Reply Display Calibration
