cant crush the whites - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-02-2012, 01:34 PM - Thread Starter
al210's Avatar
Quoted: 216 Post(s)
Liked: 103
Is it normal to be able to set the contrast all the way at max and not have any problem? When setting the contrast on my Samsung PN60E6500EF Plasma is see little difference between 90 and 100.
I set it at 99 and ran test patterns through Calman @ 100, 105 and 109% and showed no crushing. The RGB tracked on the Calman graph.
LG 65EF9500 OLED -- Samsung K8500 4K Blu-Ray Player
Denon X4200W AVR & Rogue Audio Atlas Tube Amp
Vienna Acoustics Mozart Grand SE Speakers--B&W HTM62 Center--Axiom QS4 surrounds
PSB Imagine XA Atmos Speaker Addons -- SVS PB-1000 SUBWOOFER
al210 is offline
post #2 of 3 Old 11-02-2012, 01:52 PM
rahzel's Avatar
Liked: 148
Yes, you can max the contrast on many sets without clipping (especially Samsung displays in my experience).
However, that doesn't mean 100 is the right setting. You also have to look for color shifting and/or see if you experience eye strain. Sometimes if you set the contrast too high, shades of white will start to turn pink or orange.
Knowing that the PNE6500 plasmas aren't that bright, I think you'll want to set the contrast as high as possible.
rahzel is offline
post #3 of 3 Old 11-02-2012, 02:02 PM - Thread Starter
al210's Avatar
Quoted: 216 Post(s)
Liked: 103
Knowing that the PN6500 plasmas aren't that bright, I think you'll want to set the contrast as high as possible.
Didn't see any color shifting. And your right about the brightness, I'm only getting 30 fl in movie mode after cal.
al210 is offline
Reply Display Calibration
