LightSpace CMS Now Supports Lumagen + eeColor 3D-LUT 4 All - Page 25 - AVS Forum | Home Theater Discussions And Reviews
 40Likes
post #721 of 765 Old 10-13-2014, 12:19 PM - Thread Starter
ConnecTEDDD's Avatar
Quoted: 1044 Post(s)
Liked: 1514
LightSpace CMS 6.6.3.1986 (13 October 2014)
A new version of LightSpace has just released.
This version includes:
-- Auto Close option added after Display Characterization
-- Lumagen Radiance 21xx 17^3 LUT support added
-- Additional EIZO integration added
-- BON display integration added
-- Additional Arri Look tools added
-- Support for NEC display calibration integration
-- Additional LUT formats added
Download LightSpace CMS Demo or Upgrade for Licensed Users
Request Free Version License for LightSpace DPS (Display Profiling System)
Ted's LightSpace CMS Calibration Disk Free Version for Free Calibration Software: LightSpace DPS / CalMAN ColorChecker / HCFR
S/W: LightSpace CMS, SpaceMan ICC, SpaceMatch DCM, CalMAN 5, CalMAN RGB, ChromaPure, ControlCAL
V/P: eeColor 3D LUT Box - P/G: DVDO AVLab TPG
Meters: JETI Specbos 1211, Klein K-10A, i1PRO2, i1PRO, SpectraCAL C6, i1D3, C5
ConnecTEDDD is online now
post #722 of 765 Old 11-12-2014, 09:48 AM - Thread Starter
Liked: 1514
LightSpace CMS 6.6.4.2004 (10 November 2014)
-- Upload thermometer added
-- Auto Close option added after Display Characterisation
-- Lumagen 17^3 LUT support added
post #723 of 765 Old 11-12-2014, 10:43 AM
Light Illusion's Avatar
Quoted: 320 Post(s)
Liked: 627
Just for the fun of it I ran some tests comparing 17^3 profiling and calibration, with a Quick Profile and calibration - all with the i1D3.
The 17^3 took 1 hour 20, and the QP 2 mins.
The results were rather interesting, with very little difference - both in the numbers and visually.
The display was a 'standard' LCD TV with acceptable RGB Separation, but does show what can be done with a very quick calibration process.
See: http://www.lightillusion.com/calibration_speed.html
Personally, on this display I normally use a 21^3 profile and calibration, as it takes just 2 hours 30, but it was an interesting comparison.
Steve
Steve Shaw
LIGHT ILLUSION
Light Illusion is offline
post #724 of 765 Old 11-12-2014, 11:54 PM
alex_t's Avatar
Quoted: 28 Post(s)
Liked: 57
Hi Steve,
There is an issue with your link. It should be: http://www.lightillusion.com/calibration_speed.html
alex_t is online now
post #725 of 765 Old 11-13-2014, 02:12 AM
Quoted: 320 Post(s)
Liked: 627
Thanks - missed that!
Steve Shaw
LIGHT ILLUSION
post #726 of 765 Old 11-13-2014, 03:41 AM
Quoted: 1392 Post(s)
Liked: 587
Steve
Hi Steve,
I was looking at the graphs on your link and it occurred to me that if your RGB seperation is that good to start with, why do a LUTs calibration? Isn't the main benefit of a LUTs calibration to correct for the non linearities?
JimP is offline
post #727 of 765 Old 11-13-2014, 04:15 AM
Quoted: 320 Post(s)
Liked: 627
Hi Jim,
That's a good question, and the simple answer is that while the display screen may have a 'linear' response to a change in input signal, very few in-built display colour management systems are themselves 'linear'.
This means the display's cms will introduce non-linear inaccuracies.
Unfortunately, this is all too common.
Also, the granularity of a 3D LUT is far greater across the full volumetric space than any display cms.
(Basically, in the example on the website page you have 17 point control over Red, Green, Blue, and Grey Scale, with the volumetric correction calculated between them - that is just no possible with basic display controls).
That will always produce a better final calibration.
Steve
Steve Shaw
LIGHT ILLUSION
post #728 of 765 Old 11-21-2014, 02:45 PM - Thread Starter
Liked: 1514
LightSpace CMS 6.6.4.2010 (19 November 2014)
-- Save Probe settings between program close/open
-- Colorimetry Research CR-250 integration added
post #729 of 765 Old 03-25-2015, 12:46 PM - Thread Starter
Liked: 1514
LightSpace CMS 6.6.7.2061 (24 March 2015)
Light Illussion has just released the Next Generation of Color Mathematics for it's advanced Color Engine, which is at the heart of the unparalleled calibration accuracy of LightSpace CMS.
The original Color Engine had previously proven to be the most accurate, as well as the fastest available for display calibration, LUT generation, LUT conversion and LUT manipulation. However, nothing is ever perfect, and Light Illusion knew they could do better. After over 6 man-months of work the algorithms and mathematics that are at the core of the LightSpace Color Engine have been totally re-written and enhanced, with visible and measurable improvements in final calibration results.
Note: for users that have performed a recent display profiling, they don't need to re-measure again their displays. It's required only to install the new LightSpace version, load their measurement file and generate the ColorSpace conversion to get the new 3D LUT correction file and then upload it to their 3D LUT hardware device or to their 3D LUT capable monitors. This saves a lot of time.
Full Release Notes @ available here.
-- New Colour Engine mathematics and algorithms
-- New LUT Format for Canon 4K Professional Displays
-- Changed operation of VideoScale functions
-- Changed defaults for Convert Colour Spaces
-- Added Differential Gamma graph
-- Added support for DVDO AVLab TPG patch generation
-- Corrected Active LUT effect on initial patch in Measure mode
-- Fixed error with Probe Settings not being remembered correctly
-- Small changes for CR-250 integration
-- Added error message if CDL/CCC file invalid
-- Corrected minor Convert Colour Space white loss
-- Changed UHDTV label to UHD Rec2020
-- Added ST2084 Gamma profiles for Rec709, Rec2020, and P3
-- Fixed error with Hubble probe connection
-- Fixed duplicate LUT being applied to Ref Image when exporting Arri Looks
W3Rman likes this.
post #730 of 765 Old 05-02-2015, 03:39 AM - Thread Starter
Liked: 1514
LightSpace CMS 7.0.0 is coming….
For LightSpace users, there some real interesting new features like these ones you can see below:
Quick Profiling
Additionally to the Quick Profiling of Primary/Secondary Colors measurements that were available since now, Gamut Saturations @ 75% or 100% Stimulus Level and Memory Colors (Color Checker Classic) options added, to quick overview the performance of any display.
Here is an example of the CIE chart after the Memory Colors measurement:
Gamut Triangle Level
The new Gamut Triangle Level function enables the visualization of a display's gamut at all matched RGB primary points throughout the full stimulus range. By cycling through list of available matched RGB primary points it is possible to see the shape and size of the Gamut, and see at what levels it is smaller or larger that the desired target.
When you will run a Quick Profiling of Primary Colors which measures 20-Point of Luminance per color channel @ 100% Saturation, you will be able later to check the 100% Saturation of any Luminance level to overview the gamut coverage triangle over these 20-Point Luminance levels to check if the gamut coverage remains the same or if is reduced; to find which pre-calibration settings give the largest coverage etc.
This is extremely helpful when it comes to understanding the underlying capabilities of a given display.
Stimulus Levels
The Stimulus Levels function is another of the 'filters' for the CIE graphs, and defines how the measured points are shown. As with all the points filters they are additive options, and will combine with any other filters selected. The Stimulus Levels filter will show any and all points that include the selected value within any R, G, or B stimulus data. This enables easier selection of a given point to enable it to be isolated via a double click to see the points associated measured color data and Delta-E values.
Delta-E
You can display at the CIE Chart only the colorpoints with the selected dE range, to check what areas of the display have more errors.
The Delta-E filter is also another of the 'filters' for the CIE graphs, and defines how the measured points are shown. As with all the points filters they are additive options, and will combine with any other filters selected. Therefore to see just the points within the available Delta-E ranges first disable all other filter tick boxes. The benefit of this filter function is that it enables a quick assessment of the spread of Delta-E values within the measured profile, allowing a very quick understanding of the overall accuracy of the display.
Reports
The new Reporting feature enables a .pdf export of the various graphs, as well as details on various aspects of the selected profile, including Luma range, contrast, Delta-E ranges, etc., as well as user editable sections for client name, display, probe data, and more.
post #731 of 765 Old 05-02-2015, 05:42 AM
alex_t's Avatar
Quoted: 28 Post(s)
Liked: 57
Hello everybody,
I have just put on line on my site an interview from Steve Shaw, CEO of Light Illusion : http://performances-home-cinema.fr/2...ec-steve-shaw/
Regards
Alexandre
post #732 of 765 Old 05-02-2015, 05:36 PM
W3Rman's Avatar
Quoted: 158 Post(s)
Liked: 131
Quick Profiling
Stimulus Levels
Delta-E
Reports
WoW
these look like really great updates. Thanks for the preview Ted and Steve.
Ted , I emailed you a couple of times (04/29 , 04/30) but no reply. Did you receive or are you busy ?
#1 Calibration Disk / Best Support: Ted's LightSpace CMS Calibration Disk
#1 Calibration Software / Best Support: LightSpace CMS - Calibration Comparison
W3Rman is offline
post #733 of 765 Old 05-02-2015, 05:56 PM - Thread Starter
Liked: 1514
Hi, I saw your emails and replied to them instantly, but by a weird issue you are not receiving them. I will try to locate the problem. Thanks
post #734 of 765 Old 05-02-2015, 06:10 PM
W3Rman's Avatar
Quoted: 158 Post(s)
Liked: 131
Ok!
W3Rman is offline
post #735 of 765 Old 06-16-2015, 03:15 PM - Thread Starter
Liked: 1514
LightSpace CMS 7.0.0.2155 (15 June 2015)
Light Illusion releases Version 7 LightSpace CMS – a major features update.
New features include:
-- Added new Maths functions for LUT Manipulations
-- Added ‘Sweeps’ to Quick Profiling options
-- Added memory Colours to Quick Profiling options
-- Added EBU TEC3320 colour space pre-set
-- Error message if Colour Space name invalid
-- Additional CIE graph display filters and features
-- Export PDF report capability
-- New LUT formats
-- BON 1D & 3D LUT Upload
-- ACES v1 fixes (for ACES not LightSpace)
-- Correction for madVR integration
-- Added gamut control for displays with limited gamut
-- New Manual Measure feedback Zoom graph
-- New Patch Colour section for Manual Measure
-- Added new AIO (all-in-one) mode for i1d3 RevB
Many if these new feature are all-new, and will be built upon in the coming weeks and months, with further updates being released for all LightSpace CMS users.
As is the case with all LightSpace updates, the new features are free to all users with valid option licenses that include the areas within which the new feature are contained.
The on-line user guides have been updated to include the new features, and it is recommended that all users refer to these, as some changes alter the previous operation of some LightSpace CMS features and functions.
alex_t and starbuck69 like this.
post #736 of 765 Old 06-16-2015, 03:24 PM
W3Rman's Avatar
Quoted: 158 Post(s)
Liked: 131
Ah..., its got everything ... I am really happy about this release
These are especially nice:
Thanks to all LS team
ConnecTEDDD and starbuck69 like this.
W3Rman is offline
post #737 of 765 Old 06-16-2015, 09:45 PM
oliverlim's Avatar
Quoted: 64 Post(s)
-- New LUT formats
Happy days ( or is it more headaches :-p) are here again! Thanks LS team!
oliverlim is offline
post #738 of 765 Old 06-17-2015, 05:41 AM
Quoted: 320 Post(s)
Liked: 627
LOL
Hopefully not more headaches, but I bet there will be some 'teething' issues to sort out!
So far, the feedback has been very positive, but we also have a list of additional improvements to be made - there are some limitations with the now features, but they will be improved/added to over the coming weeks, so keep an eye on the 'new version available' when you start LightSpace while on-line. As always, the upgrades are free to all licensed users.
For those using the i1 Display Pro OEM probe we have now switched over to the new RevB model, and that will be the probe supplied with all new orders. The new AIO mode (All In One) adds a level of improvement for all display types, with faster and improved measurement results.
Users with an original i1 Display Pro OEM will get a simple error message if they try to use the AIO mode.
Steve
starbuck69 likes this.
Steve Shaw
LIGHT ILLUSION
post #739 of 765 Old 06-17-2015, 09:43 AM
W3Rman's Avatar
Quoted: 158 Post(s)
Liked: 131
.................The new AIO mode (All In One) adds a level of improvement for all display types, with faster and improved measurement results.
Steve
The added dE Dist. graph is great along with the Min-Max-Avg. dE table at the bottom of the PDF reports, now I can delete all the folders I have filled with screenshots for Characterization/Verification Profiles.
Just amazingly simple yet thorough and pertinent information ....
Curious, what aspects influenced the choosing of the name "All In One" for this mode ?
W3Rman is offline
post #740 of 765 Old 06-17-2015, 09:50 AM
Quoted: 320 Post(s)
Liked: 627
Glad you like the changes - there is a lot more on the way...
(And we are happy for any feedback with suggestions and other ideas - not guarantees as to when any such feedback would be implemented, but we do listen to all users!)
Ah - that is an X-Rite name. It describes the function of the new mode...
Steve Shaw
LIGHT ILLUSION
post #741 of 765 Old 06-18-2015, 09:13 AM
starbuck69's Avatar
Liked: 29
I'm late but... downloaded.
Yeahaaa, what a great upgrade !!
My TV is grateful, thank you
ConnecTEDDD likes this.
starbuck69 is offline
post #742 of 765 Old 06-19-2015, 06:23 AM
Quoted: 320 Post(s)
Liked: 627
Glad you like the update!
There will be numerous additional updates over the coming few weeks, so keep an eye on the 'update' message that pops-up when you start LightSpace while on-line.
We are adding yet more new features, and enhancing the new options.
Steve
Steve Shaw
LIGHT ILLUSION
post #743 of 765 Old 06-19-2015, 07:16 AM
starbuck69's Avatar
Liked: 29
OMG ! "Numerous additional updates", "adding yet new features", "enhancing the new options"... seems that we all, calibrators, will have a lot of work in the coming few weeks, THAT'S COOL THANK YOU SIR !
And seems that Ted will have a lot of work too for the next release of the best calibration disk ever
post #744 of 765 Old 06-24-2015, 07:53 PM
oliverlim's Avatar
Quoted: 64 Post(s)
LOL
Steve
I got a new replacement i1 display pro retail. If I try out the AIO mode and do not get a error message, does it mean that I have a Rev B?
post #745 of 765 Old 06-24-2015, 07:58 PM
W3Rman's Avatar
Quoted: 158 Post(s)
Liked: 131
Look on the counter weight and at bottom of sticker you should see the Manufacture date and Rev. A OR B info.
W3Rman is offline
post #746 of 765 Old 06-25-2015, 01:20 AM
Quoted: 320 Post(s)
Liked: 627
The error essage will appear when you try to take a measurement, not when you select the AIO mode initially.
Steve
Steve Shaw
LIGHT ILLUSION
post #747 of 765 Old 06-26-2015, 04:01 AM
oliverlim's Avatar
Quoted: 64 Post(s)
Steve
Strange. I saw that my version on the weight holder says Rev A - 02. But when I try the AIO mode and do a measurement it works with no errors.
My initial unit that I bought in May was a Rev B unit. But as it had some issues with low light measurement (reporting failed read) I asked for a exchange. My replacement new unit was a Rev A. Now the AIO mode is not working.....
post #748 of 765 Old 06-30-2015, 10:45 PM
oliverlim's Avatar
Quoted: 64 Post(s)
A question regarding LS with Lumagen Mini 3D 125 points LUT.
I understand there are usually two ways to do adjustments.
First way is to use the display controls to adjust greyscale as best as possible, then run a cube for a 3d LUT for the 125 points on the Lumagen.
Second way is to leave all display controls alone except for brightness and contrast, and let LS/Lumagen do the rest via a cube calibration.
Assuming my display has a poor RGB separation, would it make more sense to use my display greyscale controls to balance this somewhat before the cube calibration? Or it does not matter ultimately. If so, I would like to understand why?
post #749 of 765 Old 07-01-2015, 02:51 PM - Thread Starter
Liked: 1514
LightSpace CMS 7.0.0.2164 (30 June 2015) just released.
New features
-- Added Konvision Broadcast Monitors Integration and Direct 3D-LUT Uploading
-- Added Prisma 3D-LUT Box Integration and Direct 3D-LUT Uploading
-- Changes of Sliders Link function
post #750 of 765 Old 07-02-2015, 01:56 AM
Gordon Fraser's Avatar
Quoted: 114 Post(s)
Liked: 149
I have never heard of just adjusting brightness and contrast. I would always advocate adjusting 100 percent white, at least, to D65.
My own procedure is to set brightness and contrast and set 100% stimulus to d65 then measure different gamma and colourspace settings to find one with best rgb separation and closest gamma, while having gamut larger than target. Then i run the lut. If greyscale is not very linear prior to LUT profile i will usually try to fix it by adjusting other points as well, providing it doesn't wreck rgb separation.
Convergent-AV
ISF, Home Theater Consultants and Distribution, U.K.
Gordon Fraser is offline
Reply Display Calibration
