Looks like a new entry level meter. - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 12-28-2012, 02:23 PM
caeguy's Avatar
Just want to print standard reports. Can the Turorial license allow this?
Samsung PN60F8500, Panasonic TH-42PD25U/P, Pioneer VSX-1018TXH-K, Oppo BDP-93, Aperion Audio 5T&5C, HSU STF-2, PS3, Wii, HTPC, SD Homerun Prime, Ceton Echo
caeguy is offline
Old 12-28-2012, 02:42 PM
praz's Avatar
Liked: 26
As Turbe has already wrote you need Basic, Control or Enthusiast to print reports.
praz is offline
Old 12-28-2012, 02:56 PM
caeguy's Avatar
Yeah..I saw that. Wasnt clear but thanks for clarifying.
caeguy is offline
Old 12-28-2012, 03:00 PM
derekjsmith's Avatar
Liked: 116
Originally Posted by vincentprice View Post
Just got this meter how do I use it with HCHR?
The SpectraCal C3 only works with CalMAN 5. The C3 inlcudes a license for CalMAN 5 Tutorial which has full gamma/grayscale/cms so I'm not sure why you would need any other software.
Derek
CTO Portrait Displays Inc.
derekjsmith is offline
Old 12-28-2012, 03:05 PM
Liked: 116
No reports in CalMAN 5 Tutorial. You would need Basic, Control or Enthusiast license for that. But as pointed out you can always use print screen.
Derek
Old 12-28-2012, 05:55 PM
vincentprice's Avatar
I having trouble with the cms part of the software HRFR seems a bit some simplistic. I'm having no success with it until I research the matter more.
ÂI felt that here at last was a chance to expose the U.S. public to fine art at reasonable pricesÂ
vincentprice is offline
Old 12-31-2012, 09:48 PM
dvzzz's Avatar
Quoted: 98 Post(s)
Liked: 31
What is a drift on the i1 Display Pro? I understand that in about a year i1 Display 2 was in need of recalibration. Seems like a steep price to pay for something that I will need to pay for again to get it re-calibrated in 12 month. Please correct me. I am new to calibration but drift bothers me since I do plan on keeping this colormeter for longer than a year or two.
For sale Sony VPL-HW40ES Projector, 720 hours on Eco Mode http://www.avsforum.com/forum/252-fr...-oem-bulb.html
dvzzz is online now
Old 01-02-2013, 12:21 PM
I'm planning on storing mine in a cooler with silica desiccant to avoid drift. Any advise? Seems like a good way to keep it from outside air and moisture? I'm still having trouble understanding cms calibration. Since all I can see in this version of the software are graphs with no variables. I also uncertain of what patterns I should be using 75% color or 75% saturation patterns. Greyscale is simple enough but I have just playing with settings and watching the DeltaE as the only sign of which way to go. I can lower it down to 2 for all colors except red and cyan. I only have one master luminance control on my tv sets. Adjusting it seems to have no effect.
Old 01-02-2013, 12:54 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
If you only have color and tint controls there isn't too much you can do for CMS.
This recent thread might help:
http://www.avsforum.com/t/1448983/which-would-you-go-with-re-color-tint
The patterns to use are the 100% saturation, 75% stimulus patterns.
Basically, look only at luminance for red and adjust the color control.
Then look at hue for one of the secondaries (I like yellow myself, in the interest of optimizing for flesh tones) and adjust the tint control.
You can look at all the data for CMS and try and make a compromise if optimizing for red luminance and yellow hue causes large errors for other colors.
Joel Barsotti
SpectraCal
CalMAN Lead Developer
sotti is offline
Old 01-02-2013, 01:09 PM
No I have full cms. Tint and color saturation and master luminance which is default of 130 on LG sets. Newer sets have a luminance setting for each color.
Old 01-02-2013, 01:27 PM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Perhaps you could post a screen shot of your results, and we could see what might be causing the issue (alt-prtscn, then paste to an image editor)?
If you only have the one Color control for color luminance, you'll just have to make a compromise with it.
Saturation and hue can effect luminance, so try to get saturation and hue close first, then adjust the luminance.
It will likely take a few passes if you are trying to get everything completely dialed in.
Joel Barsotti
SpectraCal
sotti is offline
Old 01-11-2013, 04:02 PM
jdbimmer's Avatar
Quoted: 32 Post(s)
Appears to be the same hardware as the x-rite ColorMunki Smile:
http://xritephoto.com/ph_product_overview.aspx?id=1970
jdbimmer is offline
Old 01-11-2013, 06:21 PM
djams's Avatar
Originally Posted by derekjsmith View Post
It is a SpectraCal C3 built for us by X-Rite. Yes it does look like a D2 but it is basically the guts of a Chroma 5 with updated filters. The C3 is designed for flat panels in contact mode. So basically you are getting a meter that has improved accuracy for a fraction of the price. It is targeted as a affordable entry level meter.
djams is offline
Old 01-11-2013, 11:30 PM
jdbimmer's Avatar
Quoted: 32 Post(s)
jdbimmer is offline
Old 01-12-2013, 10:45 AM
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 562
what's your point?
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is online now
Old 03-20-2013, 09:45 AM
Anthony Collazo's Avatar
HI , yes I've heard of this new SpectraCal C3 and wondering if any one else has and if they found a price that is better than retail of $149.00 . I want to help my son out but thats a bit much for saome thing you only use once unless you move and need to re do the adjustments. If any one has any good info please contact me. anthonycollazo@snet.net, thank you guys very much, its a very nice sight, keep up the good work.
Anthony Collazo is offline
Old 03-20-2013, 10:37 AM
Rolls-Royce's Avatar
Quoted: 244 Post(s)
Liked: 359
The meter is from a single relatively low-volume source (SpectraCAL) with just a few sales outlets, so I don't believe you'll be able to find much price variation on it. Anyway, $149 is a bargain for the capability it offers. The first meter/software package expressly for display calibration that I ever bought was CRT-only (no LCD or Plasma), and cost about $1700...
Anyway, I seriously doubt it'll end up being only a one-time thing. Most of us that have been here on this part of AVS a while are using our meters and software quite often, seeking just that little bit of improvement. Sometimes it isn't just a little bit, either.
Kaldaien likes this.
...Royce...
"I never drink...wine."
Bela Lugosi, DRACULA, 1931
Rolls-Royce is online now
Old 03-20-2013, 11:51 AM
willieconway's Avatar
Quoted: 121 Post(s)
Liked: 130
I have the C3/Tutorial package. If you're interested in this kind of thing, then $149 is not 'a bit much'. I'm genuinely curious as to what you would consider a reasonable price for a piece of hardware like this with software included?
Adjusting settings according to personal preference is not calibration.
Epson 5030UB, 100" Carada Criterion with Classic Cinema White, Onkyo TX-NR818, NHT Classic 3s, Classic ThreeC, SuperZero 2.1s, Mirage Omni S10, Oppo 103D. Currently boxed up: Denon 1713, Klipsch SW-450,
NHT Absolute Center, Energy Veritas 5.1s, 5.2C, V-Mini-C.
willieconway is online now
Old 03-20-2013, 12:08 PM
praz's Avatar
Liked: 26
If this is a one time thing do the $129.00 rental with a better meter.
http://store.spectracal.com/c6-calibration-rental-kit.html
-Axle- likes this.
praz is offline
Old 04-17-2013, 08:57 PM
allargon's Avatar
Quoted: 52 Post(s)
Liked: 44
Originally Posted by guida74 View Post
Derek,
Can the C3 meter be used to calibrate rear projection mounted on a tripod?
+1
We know the C3 is for flat panels and *NOT* for front projectors. We never got a definitive yes or no on rear projectors. I have two Mitsubishi RP DLP's that I'd love to calibrate using the C3 if possible.
allargon is offline
Old 04-18-2013, 08:52 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
Originally Posted by allargon View Post
+1
While the meter would have no problem physically reading a rear projector (where it isn't designed physically for non-contact use), I don't believe it has a UHP table for the lamp on those sets, but I'll double check.
Joel Barsotti
SpectraCal
sotti is offline
Old 04-18-2013, 09:58 AM
Liked: 116
Correct just LED, LCD and Plasma
Derek
Old 04-18-2013, 10:40 AM
allargon's Avatar
Quoted: 52 Post(s)
Liked: 44
Thanks, Derek and Joel. I really appreciate it.
allargon is offline
Old 04-18-2013, 04:09 PM
sillycargt4cs's Avatar
Derek is there a uk supplier/agent I'm interested in this package
sillycargt4cs is offline
Old 04-24-2013, 06:22 AM
Watcher12's Avatar
Can the C3 be used to calibrate 3D on a plasma set? If not, is the C6 the way to go, or something else?
Watcher12 is offline
Old 04-24-2013, 06:40 AM
realzven's Avatar
Liked: 84
realzven is offline
Old 04-24-2013, 10:48 AM
sotti's Avatar
Quoted: 329 Post(s)
Liked: 330
You need something that can read through the glasses, which means a non-contact meter. So the i1 Display Pro would be your starting point there, with the C6 being the next step up.
Joel Barsotti
SpectraCal
sotti is offline
Old 04-24-2013, 01:19 PM
Watcher12's Avatar
Old 04-25-2013, 02:38 AM
2stroker's Avatar
I asked this question when they first came out, and no, one has to import from the US. I haven't got a problem with that, it's just that my laptop only has 500mb ram, so I'd need to upgade that as well.
2stroker is offline
Old 07-27-2013, 12:42 PM
defjamz's Avatar
Quoted: 43 Post(s)
Liked: 113
Just bought the C3 & Tutorial package. I was hoping to use it last night, but you have to call to download the software (have to wait till Monday).
I'm excited about learning how to calibrate flat panels myself, and this entry level combo seems like the perfect way to start out. Can't wait to test on my 3 plasmas!
Rec Room: Sony 75X940C/Yamaha A1050/Oppo UDP203/Klipsch RP280F, RP450C, RP140 Atmos, Definitive SM350/SVS SB2000/PS4
Living Room: Sony 75X940D/Yamaha A730/Samsung K8500/Definitive BP8040, BP6/Martin Logan Dynamo1000/Xbox One S
Bedroom: Samsung 75HU8550
defjamz is offline
